If updating to the latest firmware of the Phillips Hue bridge
  • If updating to the latest firmware of the Phillips Hue bridge
    I have send an corrected version for the plugin to the updater.
    If you are planning to upgrade the bridge to the latest version, please install the version 1.0.5.11 also!
    There are no other changes in this version.
    Wim
    -- Wim
    It's taken 2 years but, I see Philips have finally added a way to delete a bulb!!
    Better late than never I suppose
      Jason,
      Correct. I - and others - made this request some time ago. Am glad it is enabled now. I will finish the current changes to the plugin and will then work on incorporating the delete function in the plugin.
      Have to do some testing to decide if the plugin should allow the deletion of bulbs while still active and reachable or only the unreachable ones.
      Wim
      -- Wim
        Hi Wim,
        Im on the latest PI and also the latest bridge firmware. I noticed this in the logs, although everything seemed to work as it should. I run a red alert on the lights before it switches everything off downstairs, just in case I'm still awake
        Just thought I'd let you know, have a good weekend!!
        <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:16 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>Event </TD> <TD class=LogEntry1 colSpan=8 align=left>Event Trigger "!Control Events ALL OFF (cancel delay)" </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry0 colSpan=8 align=left>PUT Command send was {"on":false,"bri":1} </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry1 colSpan=8 align=left>Warning sending bridge command: type:901 address:/lights/7/state/on description:Internal error, 404 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry0 colSpan=8 align=left>PUT Command send was {"on":false,"bri":1} </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry1 colSpan=8 align=left>Warning sending bridge command: type:901 address:/lights/6/state/on description:Internal error, 404 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry0 colSpan=8 align=left>PUT Command send was {"on":true,"bri":2,"hue":37084,"sat":94,"xy":[0.3337,0.377]} </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry1 colSpan=8 align=left>Warning sending bridge command: type:901 address:/lights/5/state/bri description:Internal error, 404 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry0 colSpan=8 align=left>Warning sending bridge command: type:901 address:/lights/5/state/xy description:Internal error, 404 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry1 colSpan=8 align=left>Warning sending bridge command: type:901 address:/lights/5/state/sat description:Internal error, 404 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry0 colSpan=8 align=left>Warning sending bridge command: type:901 address:/lights/5/state/hue description:Internal error, 404 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry1 colSpan=8 align=left>Warning sending bridge command: type:901 address:/lights/5/state/on description:Internal error, 404 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry0 colSpan=8 align=left>PUT Command send was {"on":false,"bri":1,"hue":47104,"sat":254,"ct":500,"xy":[0.167,0.04]} </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry1 colSpan=8 align=left>Warning sending bridge command: type:901 address:/lights/4/state/on description:Internal error, 404 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:15 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry0 colSpan=8 align=left>Animation Red alert Finished </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:14 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>ECHO </TD> <TD class=LogEntry1 colSpan=8 align=left>Echo for Dining Room PIR, No Echo (21 mins, 12 secs) </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:14 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>Device Control </TD> <TD class=LogEntry0 colSpan=8 align=left>Device: MediaController Philips TV State to Pause (3) </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:14 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>Event </TD> <TD class=LogEntry1 colSpan=8 align=left>Event Trigger "AV Lounge TV PIR Pause" </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:10 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>Z-Wave </TD> <TD class=LogEntry0 colSpan=8 align=left>Device: Downstairs Back Passage Luminance Set to 0 (%) </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:10 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JW </TD> <TD class=LogEntry1 colSpan=8 align=left>Back Passage Luminance written to virtual device : 1 </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:10 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>Z-Wave </TD> <TD class=LogEntry0 colSpan=8 align=left>Device: Downstairs Back Passage Luminance Set to 1 (%) </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:10 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>ACTIVE ZONE </TD> <TD class=LogEntry1 colSpan=8 align=left>BLRadar Downstairs PIR Zone has changed to Active Zone On, Active Zone Off (8 secs) </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:10 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>ECHO </TD> <TD class=LogEntry0 colSpan=8 align=left>Echo for Lounge Aeon PIR, No Echo (21 mins, 8 secs) </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:02 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry1 colSpan=8 align=left>Starting animation Red alert </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:02 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>Pushover 3P </TD> <TD class=LogEntry0 colSpan=8 align=left>Pushover Notification Sent </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:02 </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>ACTIVE ZONE </TD> <TD class=LogEntry1 colSpan=8 align=left>BLRadar Downstairs PIR Zone has changed to Active Zone Off, Active Zone On (2 hrs, 56 mins) </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>Apr-04 00:29:02 </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>Event </TD> <TD class=LogEntry0 colSpan=8 align=left>Event Trigger "PIR Downstairs PIR OFF" </TD></TR></TBODY></TABLE>
          Jason,
          The 901 code is coming back from the bridge, if I interpret the api documentation right, Philips states this message is not due to something incorrectly formatted by the plugin, but an internal error on the bridge.
          The extra code, 404 is not documented for the API, but Philips yet has to update its documentation to the latest version.
          So, it is not an error from the plugin, but some internal error in the bridge itself. I will monitor the updates by Philips to see if some more clarity is coming up in the documentation. I am hoping it will be a one time issue for you... I for one do not like internal errors
          Wim
          -- Wim
            Ok no probs
