Hi Wim,
After returning yet another 2 hue bulbs, Philips sent me some new ones thankfully!!
Anyway, I tried to switch the new ones with the two broken ones I sent back.
This is what I did.
1. Shut down your PI.
2. Deleted the bad bulbs (ID1 & ID2) using the iPhone Philips App.
3. Re-added the two new bulbs with the Philips App and give them the SAME NAME hoping your PI would use the same devices (I thought the bridge would use ID1 and ID2 - it didn't - it used the next ID's 8 and 9)
4. Restarted your PI - it complained of same name lights but created a new set of devices.
5. Re-named the old light root device to "Hue Lamp 1xx"
6. Restart PI etc.
Then I got the error below
Apr-28 07:53:57 JowiHue ============================================================ =============================
Apr-28 07:53:57 JowiHue You can savely remove the devices belonging to this light
Apr-28 07:53:57 JowiHue Dynamic deletion of light not yet implemented in plugin; please notify plugin owner
Apr-28 07:53:57 JowiHue GetLightsFromBridge: Found light no longer defined on bridge: 2 -- Hue Lamp 2xx -- 388
Apr-28 07:53:57 JowiHue GetLightsFromBridge: Found light no longer defined on bridge: 1 -- Hue Lamp 1xx -- 384
So I deleted the devices because all my hue lights aren't updating in the PI. I can control them from the PI but they don't seem to poll anymore.
Even though I have deleted the old light devices, I still keep getting the above error and none of the devices update.
I've probably screwed the .db ... again
Any ideas??
Cheers
J
This is what I did.
6. Restart PI etc.
Any ideas??
Cheers
J
