Script error after the update
  • Script error after the update
    After updating the plugin to 1.0.6.1, I'm getting these messages in the log.
    <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>May-02 6:49:18 PM </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry1 colSpan=8 align=left>Please check parameters with documentation? </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="WHITE-SPACE: nowrap" align=left>May-02 6:49:18 PM </TD> <TD class=LogPri0 align=left></TD> <TD class=LogType0 colSpan=3 align=left>JowiHue </TD> <TD class=LogEntry0 colSpan=8 align=left>Error in PluginFunction calling SetLightsHueSat: Exception has been thrown by the target of an invocation. </TD></TR></TBODY></TABLE> <TABLE class=log_table_row cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="WHITE-SPACE: nowrap" align=left>May-02 6:49:18 PM </TD> <TD class=LogPri1 align=left></TD> <TD class=LogType1 colSpan=3 align=left>Daytime </TD> <TD class=LogEntry1 colSpan=8 align=left>Daytime </TD></TR></TBODY></TABLE>
    PHP Code:
     Sub Main(ByVal parm As Object
    Dim level As Integer
            Dim LightlevelStatus
    As String ""
    Dim SunsetTime As DateTime
            Dim SunriseTime
    As DateTime
            Dim DateRightNow
    As DateTime
            Dim SuccessLight
    As Boolean
            SunsetTime
    hs.SunsetDt
            SunriseTime
    hs.SunriseDt
            DateRightNow
    DateTime.Now
    If SunriseTime <= DateRightNow And SunsetTime >= DateRightNow Then
    'Daytime
                hs.WriteLog ("Daytime" , "Daytime")
                LightlevelStatus = hs.PluginFunction("Insteon", "", "GetDeviceSetting", New Object() {"13.EE.B4", "Current Light Level"})
    hs.writelog ("test"lightlevelstatus
    level CInt(LightlevelStatus
                 If
    level >= 100 Then
    ' Set Hue Studio Light to Low light
                    SuccessLight = hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {False, "Hue Lamp Studio", 1, 8239, 200, 10})
                    hs.WriteLog("StudioLight", level)
                ElseIf level >= 80 Then
    set Hue Studio Light to Low light
                    SuccessLight
    hs.PluginFunction("JowiHue""""SetLightsHueSat", {False"Hue Lamp Studio"102510020010})
    hs.WriteLog("StudioLight"level
                ElseIf
    level >= 60 Then
    ' set Studio Hue Lamp to Yellow
                    SuccessLight = hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {False, "Hue Lamp Studio", 100, 42000, 255, 10})
                ElseIf level >= 40 Then
    set Studio Hue Lamp to White
                    SuccessLight
    hs.PluginFunction("JowiHue""""SetLightsHueSat", {False"Hue Lamp Studio"2003400025510})
                Else
    ' set Studio Hue Lamp to High White
                    SuccessLight = hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {False, "Hue Lamp Studio", 255, 35100, 255, 10})
                End If
            Else
    Nighttime
                hs
    .WriteLog ("Nighttime" "Nightime")
    SuccessLight hs.PluginFunction("JowiHue""""SetLightsHueSat", {False"Hue Lamp Studio"2551192925510})
    End If
    End Sub
    Not sure what I'm doing wrong.
    Aldo
    Aldo,
    I have checked the statement and there is nothing wrong with it. But if you perform this command while the lights are off, it errors. Appearently I am missing some error catching in this part.
    But if you change your statements in :
    SuccessLight = hs.PluginFunction("JowiHue", "", "SetLightsHueSat", {True, "Hue Lamp Studio", 1, 8239, 200, 10})
    It should work. I will check why it does now error while lights are off.
    -- Wim
      As always, thank you for the quick response. I changed to True and I'm still having the same error.
      <TABLE class=log_table_row style="WIDTH: 970px; WHITE-SPACE: normal; WORD-SPACING: 0px; TABLE-LAYOUT: fixed; TEXT-TRANSFORM: none; COLOR: rgb(0,0,0); FONT: 13px 'Lucida Console', Monaco, monospace; WIDOWS: 1; LETTER-SPACING: normal; BACKGROUND-COLOR: rgb(255,255,255); TEXT-INDENT: 0px; -webkit-text-stroke-width: 0px" cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="FONT-SIZE: 10pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 150px; BACKGROUND: rgb(239,239,239); WHITE-SPACE: nowrap; PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left>May-03 9:52:19 AM</TD> <TD class=LogPri0 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 30px; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left></TD> <TD class=LogType0 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 100px; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=3 align=left>JowiHue</TD> <TD class=LogEntry0 style="WORD-WRAP: break-word; FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=8 align=left>Please check parameters with documentation?</TD></TR></TBODY></TABLE> <TABLE class=log_table_row style="WIDTH: 970px; WHITE-SPACE: normal; WORD-SPACING: 0px; TABLE-LAYOUT: fixed; TEXT-TRANSFORM: none; COLOR: rgb(0,0,0); FONT: 13px 'Lucida Console', Monaco, monospace; WIDOWS: 1; LETTER-SPACING: normal; BACKGROUND-COLOR: rgb(255,255,255); TEXT-INDENT: 0px; -webkit-text-stroke-width: 0px" cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="FONT-SIZE: 10pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 150px; BACKGROUND: rgb(255,255,255); WHITE-SPACE: nowrap; PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left>May-03 9:52:19 AM</TD> <TD class=LogPri1 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 30px; BACKGROUND: rgb(255,255,255); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left></TD> <TD class=LogType1 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 100px; BACKGROUND: rgb(255,255,255); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=3 align=left>JowiHue</TD> <TD class=LogEntry1 style="WORD-WRAP: break-word; FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; BACKGROUND: rgb(255,255,255); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=8 align=left>Error in PluginFunction calling SetLightsHueSat: Exception has been thrown by the target of an invocation.</TD></TR></TBODY></TABLE> <TABLE class=log_table_row style="WIDTH: 970px; WHITE-SPACE: normal; WORD-SPACING: 0px; TABLE-LAYOUT: fixed; TEXT-TRANSFORM: none; COLOR: rgb(0,0,0); FONT: 13px 'Lucida Console', Monaco, monospace; WIDOWS: 1; LETTER-SPACING: normal; BACKGROUND-COLOR: rgb(255,255,255); TEXT-INDENT: 0px; -webkit-text-stroke-width: 0px" cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="FONT-SIZE: 10pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 150px; BACKGROUND: rgb(239,239,239); WHITE-SPACE: nowrap; PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left>May-03 9:52:19 AM</TD> <TD class=LogPri0 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 30px; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left></TD> <TD class=LogType0 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 100px; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=3 align=left>Daytime</TD> <TD class=LogEntry0 style="WORD-WRAP: break-word; FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=8 align=left>Daytime</TD></TR></TBODY></TABLE>
      Aldo
        So sorry, it was my fault, I changed the name of the lamp few days back and I forgot to change it in the script. Coincidence, I updated the plugin and I got mislead.
        Aldo
          Aldo,
          Maybe only partly your fault. The plugin should have reported that the light was unknown. I will work on that.
          Wim
          -- Wim
