Multi Bridge
  • Multi Bridge
    Wim,
    Is the multibridge functionality implemented yet? I am still thinking of creating an Dummy Bridge, to control devices in HS3 via my Harmony remote and my Toon thermostat (which both have HUE support).
    I want to use your plugin to interface the dummy bridge (software emulated bridge) and trigger events on state change of the dummy bulbs
    Bart
    Regards Bart
    Win7 64Bit on Intel NUCI7 with SSD
    HSPRO 3.
    Devices; 1370 Events; 691
    Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
    Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
    Bart,
    Sorry for the late reply. Had to do long posponed jobs in the house which took much of my attention and made me miss your mail on this
    Work in the house is almost done, so next replies should be sooner again....
    Multibridge is working for the plugin, you can attach any number of bridges to the plugin. As far I know now there is at least one user using 3 bridges now with the plugin and everything is running smooth. So you can go ahead and test with it
    Keep me posted on your results?
    Wim
    -- Wim
      wim,
      I cannot get a hue emulator to work, It has something todo with upnp discoverablility. However i can access the emulator remote on IP.
      Maybe its possibly to connect to a fixed ip and port in the plugin...?
      Or have any other bridge emulator suggestions now, im trying this one:
      http://steveyo.github.io/Hue-Emulator/
      I also tried a js.node emulator, but also not discoverable using upnp...:S,
      https://www.npmjs.com/package/huemulator
      also changed hostsystem, and firewall etc, no luck...
      Bart
      Regards Bart
      HSPRO 3.
        If those emulators are not using upnp then it is hard to do with the current version as it is depending on upnp to find the bridge.
        I see what I can do for an emulator. I guess I can add an ini file and let you input the emulated ip address?
        I will see what I can do and send you a beta version ok?
        Wim
        -- Wim
          wim,
          they use upnp, however the upnp is having some diddficulties, the developer states only the android sdk works for now. however dont see the bridge in netwroklocations either. Maybe i am going to try to load it up on my rpi, maybe its a windows related issue.
          bart
          Regards Bart
          HSPRO 3.
            I am currenty running 3 bridges n this plug in with approx 70 bulbs and it never misses a beat
            Cheer Ken
            HSPRO,HS3PRO, BLsecurity, , MCSxap, HSTouch Android, UltraGCIR, CM15a, USBUIRT, BLUSBUIRT, WIFIRGB, BLAB8SS, BLcontrol, BLGData, BLLAN,BLOccupied, BLRadar, BLVolume, iTunesDAAP, UltraGCIR3, Airplayspeak, BLalarm, BLbackup, BLLED, BLrandom, BLReminders, BLRF, BL Speech, Hyperion, IFTTT, KINECT, XBMC, MCSprinkers PRO, PHLocation, ULtrapioneer, Ultralog, ultraweatherbug, Z,troller, GC-100, GC WIFICC, GC-WIFI SERIAL, Nitrogen logic depth camera controllers,
