Hue plugin not showing on Linux SEL plugins download
  • Hue plugin not showing on Linux SEL plugins download
    I thought I saw it, recently when I finally got my Hue system I went back to plugins on my Linux SEl unit and it no longer shows.
    thanks
    thanks
    Mpvolo,
    You are right. I have a few customers complaining about a memory leak under mono. I am seeing the same memory leak also on my tests, but have not been able to find the cause of this. Ben searching and testing since May this year, so I decided to withdraw the support for Linux for now until I solve this memory leak.
    Sorry for that, but I think this is better than causing the memory issues.
    Wim
    -- Wim
      I use JowiHue (installed a few months ago, licensed since august 25th) with HS3 on a rpi 2.
      Because of an issue I encountered, I decided to remove and re-install the plugin.
      I didn't see the plugin in the installer anymore, searched on the forum and came across this thread.
      Can you help get JowiHue installed again? Thanks.
        akkie71,
        I am on travel at the moment, so can only respond now and then.
        I could send you the plugin directly to install on linux systems, but it will still have a memory leak, which means you would have to restart your plugin every now and then to free memory when needed. How often depends on your system.
        I can send it when I am back homeafter September 26. If you want this, please send me a pm with your mail address, so I can send the files and instructions for manual install?
        Wim
        -- Wim
          Thanks Wim, I've sent you a pm.
