errors updating to 1.6.4
that did the trick,it's working now
but no idea why of who of what placed a copy in the install directory
The dll should not be in the installation directory. If you remove it from the installation directory, which plugin or script is starting to protest.
Wim
both, in homeseer 3 directory and in homeseer3..../bin/jowihue directory
Akatar,
Did you check for the newtonsoft.json.dll? Where is it installed in your situation? Is it in the installation directory or the bin directory?
Wim
same problem here
error - De conversie van tekenreeks "" naar type Integer is ongeldig
<TABLE class=log_table_row style="WIDTH: 970px; WHITE-SPACE: normal; WORD-SPACING: 0px; TABLE-LAYOUT: fixed; TEXT-TRANSFORM: none; COLOR: rgb(0,0,0); FONT: 13px 'Lucida Console', Monaco, monospace; WIDOWS: 1; LETTER-SPACING: normal; BACKGROUND-COLOR: rgb(255,255,255); TEXT-INDENT: 0px; -webkit-text-stroke-width: 0px" cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime1" style="FONT-SIZE: 10pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 150px; BACKGROUND: rgb(255,255,255); WHITE-SPACE: nowrap; PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left>okt-18 12:18:01</TD> <TD class=LogPri1 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 30px; BACKGROUND: rgb(255,255,255); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left></TD> <TD class=LogType1 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 100px; BACKGROUND: rgb(255,255,255); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=3 align=left>JowiHue</TD> <TD class=LogEntry1 style="WORD-WRAP: break-word; FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; BACKGROUND: rgb(255,255,255); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=8 align=left>Bridge "" reconnected</TD></TR></TBODY></TABLE>
<TABLE class=log_table_row style="WIDTH: 970px; WHITE-SPACE: normal; WORD-SPACING: 0px; TABLE-LAYOUT: fixed; TEXT-TRANSFORM: none; COLOR: rgb(0,0,0); FONT: 13px 'Lucida Console', Monaco, monospace; WIDOWS: 1; LETTER-SPACING: normal; BACKGROUND-COLOR: rgb(255,255,255); TEXT-INDENT: 0px; -webkit-text-stroke-width: 0px" cellSpacing=0> <TBODY> <TR> <TD class="LogDateLong LogDateTime0" style="FONT-SIZE: 10pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 150px; BACKGROUND: rgb(239,239,239); WHITE-SPACE: nowrap; PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left>okt-18 12:18:01</TD> <TD class=LogPri0 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 30px; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" align=left></TD> <TD class=LogType0 style="FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; WIDTH: 100px; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=3 align=left>JowiHue</TD> <TD class=LogEntry0 style="WORD-WRAP: break-word; FONT-SIZE: 9pt; FONT-FAMILY: Courier-New, Monaco, monospace; BACKGROUND: rgb(239,239,239); PADDING-LEFT: 3px; PADDING-RIGHT: 3px" colSpan=8 align=left>GetBridgeConfig:Error:GetBridgeConfig: Is bridge reachable? Kan bestand of assembly Newtonsoft.Json, Version=7.0.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed of een van de afhankelijkheden hiervan niet laden. De manifestdefinitie van de gevonden assembly komt niet overeen met de assembly-verwijzing. (Uitzondering van HRESULT: 0x80131040)</TD></TR></TBODY></TABLE>
Originally posted by w.vuyk View PostBart,
I guess you had the same lines for the import before too?
Do you have more scripts using the newtonsoft.json.dll or is this the only one?
If it is the only one, do you have the line for scriptingreferences correct? Watch the comma and semicolon sequences. Here is my complete line for reference:
ScriptingReferences=System.Drawing;System.Drawing.dll,System .Web;System.web.dll,System.Data.SQLite;c:\hs3\bin\System.Dat a.SQLite.dll
(ignore the weird space near system.web, this board has this issue for years already )
Although I would not promote it, a work around for now could be done by restoring the original line as you had it and copy the newtonsoft.json.dll from the bin\jowihue to the installation directory, that way making sure the versions match.
Regards,
Wim
Wim,
Yes the script is unchanged.
I tried also putting the dll in C:\test and checked upper/lower case. Still no luck
looking like this for now:
ScriptingReferences=System.XML;System.XML.dll,System.Data;Sy stem.Data.Dll,System.Web;System.Web.dll,System.Web.DataVisua lization;System.Web.DataVisualization.dll,System.Drawing;Sys tem.Drawing.dll,Newtonsoft.Json;C:\Program Files (x86)\Homeseer HS3\Bin\newtonsoftJSON\Newtonsoft.Json.dll
and i tried this in the HS3.exe.config;
HTML Code:<?xml version="1.0"?> <configuration> <startup> <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.0"/> </startup> <runtime> <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1"> <probing privatePath="bin"/> <dependentAssembly> <assemblyIdentity name="Newtonsoft.Json" publicKeyToken="30ad4fe6b2a6aeed" culture="neutral" /> <!-- Assembly versions can be redirected in application, publisher policy, or machine configuration files. --> <bindingRedirect oldVersion="0.0.0.0-6.0.0.0" newVersion="7.0.1.18622"/> </dependentAssembly> </assemblyBinding> </runtime> </configuration>
Bart
Bart,
Another possibility could be to check the casing in the references line. Would it respond different if instead of c:\program files(x86)\.... you use the correct casing like C:\Program Files(x86)....... ?
Wim
Bart,
Regards,
Wim
wim,
however, I still have one script that is causing issues, not sure if the scripting references are ok. I have spaces in the path. but same when I put it in c:\test\*.dll, so i guess thats not the issue. scripting references are:
Code:Newtonsoft.Json;c:\program files (x86)\Homeseer HS3\bin\newtonsoftJSON\Newtonsoft.Json.dll
Code:okt-05 19:29:43 Error 1 Running script C:\Program Files (x86)\HomeSeer HS3\scripts\ThinkingCleaner.vb :Exception has been thrown by the target of an invocation.Could not load file or assembly 'Newtonsoft.Json, Version=4.5.0.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The system cannot find the file specified.
Code:Imports Newtonsoft.Json Imports Newtonsoft.Json.Linq Sub Main(params as object) 'Control Thinking cleaner Roomba Control For Homeseer3 'Made by Bart Bakels/ Promedes.nl 'ONLY USE With HS3 v81 and above 'Enable Debug Messages Level '0=None '1=Info '2=All Dim Debug = 0 '===================================================================== 'Get parameters Dim parameters(3) as String parameters = params.Split("|") Dim scriptaction As String = parameters(0) If Debug = 2 Then hs.WriteLog("Thinking cleaner Action requested", scriptaction) End If '==================================== 'DIM Parameters '==================================== Dim indexstart Dim indexend Dim errorflag Dim response Dim subresponse Dim success 'Roomba statusses Dim IP dim batterycharge dim cleanerstate dim modelnr dim name dim cleaningdistance dim cleaningtimetotal dim binstatus dim cleaningtime 'JSON Dim json As String 'this is the string of json data that needs decoding Dim obj As New Object 'homeseer connection Declaring Dim dv As Scheduler.Classes.DeviceClass = Nothing Dim Value Dim ValueText Dim ValueTextOld Dim Graphic Dim DevExists Dim GPair = New VGPair Dim Ref '====================== 'Find Roomba '====================== If errorflag = 0 Then 'errorcheck response = hs.URLAction("http://tc.thinkingsync.com/api/v1/discover/devices","GET", "", "") response=response.Replace("[", "") response=response.Replace("]", "") indexstart = InStr(response, "uuid") If indexstart = 0 Then hs.WriteLog("Thinking cleaner Error", "Find roomba, No reponse") errorflag = 1 End If If response = Nothing Then hs.WriteLog("Thinking cleaner Error", "Find roomba, No reponse") errorflag = 1 End If If Debug = 2 Then hs.WriteLog("Thinking cleaner Find Roomba", response) End If End If ' errorcheck '====================== 'Find IP '====================== If errorflag = 0 Then 'errorcheck obj = JsonConvert.DeserializeObject(response) IP = obj.Item("local_ip").ToString If Debug > 1 Then hs.WriteLog("Thinking cleaner IP", IP) End If End If ' errorcheck '====================== 'Get Roomba status '====================== If errorflag = 0 Then 'errorcheck response = hs.URLAction("http://" & IP & "/status.json","GET", "", "") If Debug = 2 Then hs.WriteLog("Thinking cleaner Status", response) End If obj = JsonConvert.DeserializeObject(response) success = obj.Item("result").ToString If Debug > 1 Then hs.WriteLog("Thinking cleaner simple status", success) End If if NOT success = "success" errorflag = 1 End if End If ' errorcheck '====================== 'Decode Roomba status '====================== 'status JSON string '--------------------------- If errorflag = 0 Then 'errorcheck response = obj.Item("status").ToString If Debug = 2 Then hs.WriteLog("Thinking cleaner deserialize status", response) End If obj = JsonConvert.DeserializeObject(response) End If ' errorcheck 'find name '--------------------------- If errorflag = 0 Then 'errorcheck obj = JsonConvert.DeserializeObject(response) name = obj.Item("name").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner name", name) End If End If ' errorcheck 'find batterycharge '--------------------------- If errorflag = 0 Then 'errorcheck batterycharge = obj.Item("battery_charge").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner battery charge", batterycharge) End If End If ' errorcheck 'find capacity '--------------------------- If errorflag = 0 Then 'errorcheck dim capacity = obj.Item("capacity").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner capacity", capacity) End If End If ' errorcheck 'find cleaner state '--------------------------- If errorflag = 0 Then 'errorcheck cleanerstate = obj.Item("cleaner_state").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner state", cleanerstate) End If End If ' errorcheck 'find cleaner cleaning '--------------------------- If errorflag = 0 Then 'errorcheck dim cleaning = obj.Item("cleaning").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner cleaning", cleaning) End If End If ' errorcheck 'find cleaner near_homebase '--------------------------- If errorflag = 0 Then 'errorcheck dim nearhomebase = obj.Item("near_homebase").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner near_homebase", nearhomebase) End If End If ' errorcheck '====================== 'Get Roomba FULL status '====================== If errorflag = 0 Then 'errorcheck response = hs.URLAction("http://" & IP & "/full_status.json","GET", "", "") If Debug = 2 Then hs.WriteLog("Thinking cleaner FULL Status", response) End If obj = JsonConvert.DeserializeObject(response) success = obj.Item("result").ToString If Debug > 1 Then hs.WriteLog("Thinking cleaner full status", success) End If if NOT success = "success" errorflag = 1 End if End If ' errorcheck '====================== 'Decode Roomba FULL status '====================== 'tc_status JSON string '--------------------------- If errorflag = 0 Then 'errorcheck subresponse = obj.Item("tc_status").ToString If Debug = 2 Then hs.WriteLog("Thinking cleaner deserialize tc_status", subresponse) End If obj = JsonConvert.DeserializeObject(subresponse) End If ' errorcheck 'find modelnr '--------------------------- If errorflag = 0 Then 'errorcheck modelnr = obj.Item("modelnr").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner modelnr", modelnr) End If End If ' errorcheck 'find cleaning_time '--------------------------- If errorflag = 0 Then 'errorcheck cleaningtime = obj.Item("cleaning_time").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner cleaning time", cleaningtime) End If End If ' errorcheck 'find cleaning_time_total '--------------------------- If errorflag = 0 Then 'errorcheck cleaningtimetotal = obj.Item("cleaning_time_total").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner cleaning time total", cleaningtimetotal) End If End If ' errorcheck 'find cleaning_distance '--------------------------- If errorflag = 0 Then 'errorcheck cleaningdistance = obj.Item("cleaning_distance").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner cleaning distance", cleaningdistance) End If End If ' errorcheck 'find bin_status '--------------------------- If errorflag = 0 Then 'errorcheck binstatus = obj.Item("bin_status").ToString If Debug > 0 Then hs.WriteLog("Thinking cleaner bin status", binstatus) End If End If ' errorcheck '====================== 'Create/Update HomeseerDevices '====================== If errorflag = 0 Then 'errorcheck 'Current batterycharge '------------------------- Value = batterycharge ValueText = Value & " %" If Value <> Nothing Then DevExists = hs.DeviceExistsAddress("ThinkingCleaner-Batterycharge", False) If DevExists = -1 Then dv = hs.NewDeviceEx("Roomba Batterij niveau") dv.Location(hs) = "Roomba" dv.Location2(hs) = "Status" dv.Address(hs) = "ThinkingCleaner-Batterycharge" dv.Device_Type_String(hs) = "Thinking Cleaner" dv.Image(hs) = "/images/thinkingcleaner/thinkingcleaner.png" Ref = hs.GetDeviceRef("ThinkingCleaner-Batterycharge") GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 90 GPair.RangeEnd = 100 GPair.Graphic = "/images/thinkingcleaner/battery-full.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 50 GPair.RangeEnd = 89 GPair.Graphic = "/images/thinkingcleaner/battery-75.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 11 GPair.RangeEnd = 49 GPair.Graphic = "/images/thinkingcleaner/battery-50.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 0 GPair.RangeEnd = 10 GPair.Graphic = "/images/thinkingcleaner/battery-empty.png" hs.DeviceVGP_AddPair(ref, GPair) hs.WriteLog("Thinking cleaner device creation", "Battery charge device") End If Ref = hs.GetDeviceRef("ThinkingCleaner-Batterycharge") ValueTextOld = hs.DeviceString(Ref) if NOT ValueTextOld = ValueText Then hs.SetDeviceString(Ref, Valuetext , True) hs.SetDeviceValueByRef(Ref, Value , False) End If End If 'Current cleanerstate '------------------------- Valuetext = "Error: onbekende status" Value = 100 if cleanerstate = "st_base" then Valuetext = "Gedocked: niet aan het laden" Value = 1 end if if cleanerstate = "st_base_recon" then Valuetext = "Gedocked: Reconditioning accu" Value = 2 end if if cleanerstate = "st_base_full" then Valuetext = "Gedocked: Accu Vol" Value = 3 end if if cleanerstate = "st_base_trickle" then Valuetext = "Gedocked: Accu Druppelladen" Value = 4 end if if cleanerstate = "st_base_wait" then Valuetext = "Gedocked: In Wacht" Value = 5 end if if cleanerstate = "st_plug" then Valuetext = "Aan lader: niet aan het laden" Value = 6 end if if cleanerstate = "st_plug_recon" then Valuetext = "Aan lader: Reconditioning accu" Value = 7 end if if cleanerstate = "st_plug_full" then Valuetext = "Aan lader: Accu Vol" Value = 8 end if if cleanerstate = "st_plug_trickle" then Valuetext = "Aan lader: Accu Druppelladen" Value = 9 end if if cleanerstate = "st_plug_wait" then Valuetext = "Aan lader: In Wacht" Value = 10 end if if cleanerstate = "st_stopped" then Valuetext = "Gestopt" Value = 11 end if if cleanerstate = "st_clean" then Valuetext = "Stofzuigen Actief" Value = 12 end if if cleanerstate = "st_cleanstop" then Valuetext = "Stofzuigen gestopt" Value = 13 end if if cleanerstate = "st_clean_spot" then Valuetext = "Spot cleaning Actief" Value = 14 end if if cleanerstate = "st_clean_max" then Valuetext = "Max cleaning Actief" Value = 15 end if if cleanerstate = "st_delayed" then Valuetext = "vertraagd schoonmaken start binnenkort" Value = 16 end if if cleanerstate = "st_dock" then Valuetext = "Zoekt dockingstation" Value = 17 end if if cleanerstate = "st_pickup" then Valuetext = "Roomba opgepakt; Wielen Los" Value = 18 end if if cleanerstate = "st_remote" then Valuetext = "Wordt remote bestuurd" Value = 19 end if if cleanerstate = "st_wait" then Valuetext = "Wacht op commando" Value = 20 end if if cleanerstate = "st_off" then Valuetext = "Uitgeschakeld" Value = 21 end if If Valuetext <> Nothing Then DevExists = hs.DeviceExistsAddress("ThinkingCleaner-Status", False) If DevExists = -1 Then dv = hs.NewDeviceEx("Roomba Status") dv.Location(hs) = "Roomba" dv.Location2(hs) = "Status" dv.Address(hs) = "ThinkingCleaner-Status" dv.Device_Type_String(hs) = "Thinking Cleaner" dv.Image(hs) = "/images/thinkingcleaner/thinkingcleaner.png" dv.MISC_Set(hs, Enums.dvMISC.SHOW_VALUES) Ref = hs.GetDeviceRef("ThinkingCleaner-Status") GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 0 GPair.RangeEnd = 200 GPair.Graphic = "/images/thinkingcleaner/status.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 1 GPair.RangeEnd = 5 GPair.Graphic = "/images/thinkingcleaner/docked.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.SingleValue GPair.Set_Value = 100 GPair.Graphic = "/images/thinkingcleaner/error.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.SingleValue GPair.Set_Value = 1 GPair.Graphic = "/images/thinkingcleaner/error.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.SingleValue GPair.Set_Value = 11 GPair.Graphic = "/images/thinkingcleaner/stop.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.SingleValue GPair.Set_Value = 12 GPair.Graphic = "/images/thinkingcleaner/clean.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.SingleValue GPair.Set_Value = 13 GPair.Graphic = "/images/thinkingcleaner/stop.png" hs.DeviceVGP_AddPair(ref, GPair) GPair = New VGPair GPair.PairType = VSVGPairType.SingleValue GPair.Set_Value = 21 GPair.Graphic = "/images/thinkingcleaner/off.png" hs.DeviceVGP_AddPair(ref, GPair) 'Button Test hs.DeviceScriptButton_AddButton(ref, "Clean","0","thinkingcleaner.vb","Actions","Clean",1,1,0) hs.DeviceScriptButton_AddButton(ref, "CleanMAX","1","thinkingcleaner.vb","Actions","CleanMax",1,2,0) hs.DeviceScriptButton_AddButton(ref, "CleanSpot","2","thinkingcleaner.vb","Actions","Spot",1,3,0) hs.DeviceScriptButton_AddButton(ref, "Dock","3","thinkingcleaner.vb","Actions","Dock",1,4,0) hs.DeviceScriptButton_AddButton(ref, "FindMe","4","thinkingcleaner.vb","Actions","FindMe",1,5,0) hs.WriteLog("Thinking cleaner device creation", "Status device") End If Ref = hs.GetDeviceRef("ThinkingCleaner-Status") ValueTextOld = hs.DeviceString(Ref) if NOT ValueTextOld = ValueText Then hs.SetDeviceString(Ref, Valuetext , True) hs.SetDeviceValueByRef(Ref, Value , False) End If End If 'name and type '------------------------- Valuetext = "name: "& name & " type: " & modelnr If Valuetext <> Nothing Then DevExists = hs.DeviceExistsAddress("ThinkingCleaner-nametype", False) If DevExists = -1 Then dv = hs.NewDeviceEx("Roomba Name/Type") dv.Location(hs) = "Roomba" dv.Location2(hs) = "Status" dv.Address(hs) = "ThinkingCleaner-nametype" dv.Device_Type_String(hs) = "Thinking Cleaner" dv.Image(hs) = "/images/thinkingcleaner/thinkingcleaner.png" Ref = hs.GetDeviceRef("ThinkingCleaner-nametype") GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 0 GPair.RangeEnd = 200 GPair.Graphic = "/images/thinkingcleaner/status.png" hs.DeviceVGP_AddPair(ref, GPair) hs.WriteLog("Thinking cleaner device creation", "Name and Type device") End If Ref = hs.GetDeviceRef("ThinkingCleaner-nametype") ValueTextOld = hs.DeviceString(Ref) if NOT ValueTextOld = ValueText Then hs.SetDeviceString(Ref, Valuetext , True) End If End If 'distance '------------------------- Value = cleaningdistance Valuetext = cleaningdistance & " m" If Valuetext <> Nothing Then DevExists = hs.DeviceExistsAddress("ThinkingCleaner-distance", False) If DevExists = -1 Then dv = hs.NewDeviceEx("Roomba Totale Afstand") dv.Location(hs) = "Roomba" dv.Location2(hs) = "Status" dv.Address(hs) = "ThinkingCleaner-distance" dv.Device_Type_String(hs) = "Thinking Cleaner" dv.Image(hs) = "/images/thinkingcleaner/thinkingcleaner.png" Ref = hs.GetDeviceRef("ThinkingCleaner-distance") GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 0 GPair.RangeEnd = 100000000 GPair.Graphic = "/images/thinkingcleaner/distance.png" hs.DeviceVGP_AddPair(ref, GPair) hs.WriteLog("Thinking cleaner device creation", "Distance device") End If Ref = hs.GetDeviceRef("ThinkingCleaner-distance") ValueTextOld = hs.DeviceString(Ref) if NOT ValueTextOld = ValueText Then hs.SetDeviceString(Ref, Valuetext , True) hs.SetDeviceValueByRef(Ref, Value , False) End If End If 'cleaningtime '------------------------- Value = cleaningtimetotal Valuetext = "laatste Run: " & cleaningtime & " min, totaal: "& cleaningtimetotal & " min" If Valuetext <> Nothing Then DevExists = hs.DeviceExistsAddress("ThinkingCleaner-cleaningtime", False) If DevExists = -1 Then dv = hs.NewDeviceEx("Roomba Totale schoonmaak Tijd") dv.Location(hs) = "Roomba" dv.Location2(hs) = "Status" dv.Address(hs) = "ThinkingCleaner-cleaningtime" dv.Device_Type_String(hs) = "Thinking Cleaner" dv.Image(hs) = "/images/thinkingcleaner/thinkingcleaner.png" Ref = hs.GetDeviceRef("ThinkingCleaner-cleaningtime") GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 0 GPair.RangeEnd = 100000000 GPair.Graphic = "/images/thinkingcleaner/time.png" hs.DeviceVGP_AddPair(ref, GPair) hs.WriteLog("Thinking cleaner device creation", "total cleaning time device") End If Ref = hs.GetDeviceRef("ThinkingCleaner-cleaningtime") ValueTextOld = hs.DeviceString(Ref) if NOT ValueTextOld = ValueText Then hs.SetDeviceString(Ref, Valuetext , True) hs.SetDeviceValueByRef(Ref, Value , False) End If End If 'binstatus '------------------------- if binstatus = 0 then value = 0 Valuetext = "Leeg" end if if binstatus = 1 then value = 100 Valuetext = "Vol" End If If Valuetext <> Nothing Then DevExists = hs.DeviceExistsAddress("ThinkingCleaner-binstatus", False) If DevExists = -1 Then dv = hs.NewDeviceEx("Roomba Opvangbak") dv.Location(hs) = "Roomba" dv.Location2(hs) = "Status" dv.Address(hs) = "ThinkingCleaner-binstatus" dv.Device_Type_String(hs) = "Thinking Cleaner" dv.Image(hs) = "/images/thinkingcleaner/thinkingcleaner.png" Ref = hs.GetDeviceRef("ThinkingCleaner-binstatus") GPair = New VGPair GPair.PairType = VSVGPairType.Range GPair.RangeStart = 0 GPair.RangeEnd = 100000000 GPair.Graphic = "/images/thinkingcleaner/bin.png" hs.DeviceVGP_AddPair(ref, GPair) hs.WriteLog("Thinking cleaner device creation", "binstatus device") End If Ref = hs.GetDeviceRef("ThinkingCleaner-binstatus") ValueTextOld = hs.DeviceString(Ref) if NOT ValueTextOld = ValueText Then hs.SetDeviceString(Ref, Valuetext , True) hs.SetDeviceValueByRef(Ref, Value , False) End If End If 'end error check End If ' errorcheck '================================================================== 'ACTIONS '================================================================== '====================== 'Dock '====================== if scriptaction = "Dock" then If errorflag = 0 Then 'errorcheck response = hs.URLAction("http://" & IP & "/command.json?command=dock","GET", "", "") If Debug = 2 Then hs.WriteLog("Thinking cleaner Dock", response) End If hs.WriteLog("Thinking cleaner dock", "success") End If ' errorcheck End If '====================== 'Maxclean '====================== if scriptaction = "Maxclean" then If errorflag = 0 Then 'errorcheck response = hs.URLAction("http://" & IP & "/command.json?command=max","GET", "", "") If Debug = 2 Then hs.WriteLog("Thinking cleaner Start Maxclean", response) End If hs.WriteLog("Thinking cleaner Start Maxclean", "success") End If ' errorcheck End If '====================== 'clean '====================== if scriptaction = "Clean" then If errorflag = 0 Then 'errorcheck response = hs.URLAction("http://" & IP & "/command.json?command=clean","GET", "", "") If Debug = 2 Then hs.WriteLog("Thinking cleaner Start clean", response) End If hs.WriteLog("Thinking cleaner Start clean", "success") End If ' errorcheck End If '====================== 'Spot '====================== if scriptaction = "Spot" then If errorflag = 0 Then 'errorcheck response = hs.URLAction("http://" & IP & "/command.json?command=spot","GET", "", "") If Debug = 2 Then hs.WriteLog("Thinking cleaner Spot Clean", response) End If hs.WriteLog("Thinking cleaner Spot clean", "success") End If ' errorcheck End If '====================== 'FindMe '====================== if scriptaction = "Findme" then If errorflag = 0 Then 'errorcheck response = hs.URLAction("http://" & IP & "/command.json?command=find_me","GET", "", "") If Debug = 2 Then hs.WriteLog("Thinking cleaner Find Me", response) End If hs.WriteLog("Thinking cleaner Find Me", "success") End If ' errorcheck End If end sub 'End Main routine '================================================================ 'Actions from device routine '================================================================ Sub Actions(modeparams as object) Dim DevID As Integer = modeparams(0) 'Integer - The device reference ID. Dim ModeButton As String = modeparams(1) hs.WriteLog("Thinkingcleaner", "Action requested by button press: " & ModeButton) If ModeButton = "Clean" Then hs.RunScriptFunc("thinkingcleaner.vb", "Main", "Clean", True, False) End If If ModeButton = "CleanMax" Then hs.RunScriptFunc("thinkingcleaner.vb", "Main", "Maxclean", True, False) End If If ModeButton = "Dock" Then hs.RunScriptFunc("thinkingcleaner.vb", "Main", "Dock", True, False) End If If ModeButton = "FindMe" Then hs.RunScriptFunc("thinkingcleaner.vb", "Main", "Findme", True, False) End If If ModeButton = "Spot" Then hs.RunScriptFunc("thinkingcleaner.vb", "Main", "Spot", True, False) End If hs.RunScriptFunc("thinkingcleaner.vb", "Main", "", True, False) End Sub ''End actions routine
wim,
great, added the full path to the scripting refrences which was looking just at the root, also rmoved the dll from the bin directory, and until now no errors.
(needed to change one of my scripts)
jowihue instaled without issues and strange log entrys
thnks
bart
