Hi Wim,
Last week I bought a hue starter pack and installed your plugin to give it a try.
Installation went succesfull. I'm using hs3 linux version 208, I installed your plugin by manually downloading it from homeseer.com because your plugin is not listed in the plugin packages list.
registering the bridge went fine. but every time I restart the plugin or restart homeseer I need to register the bridge again. Any ideas?
Zigmund
Oct-18 16:54:39 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:54:39 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:54:39 JowiHue + Unregistered bridge found on network at IP Oct-18 16:54:39 JowiHue Debug: :Probing Hue bridge at IP (removed) Oct-18 16:54:39 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:54:39 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:54:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:53:39 JowiHue RefreshWatchTimer: Error: Object reference not set to an instance of an object Oct-18 16:53:39 JowiHue Info: Unregistered bridges found on network Oct-18 16:53:39 JowiHue Debug: :RefreshWatchTimer: Checking for lights and groups, maintenance lifetime usage Oct-18 16:52:39 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:52:39 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:52:39 JowiHue + Unregistered bridge found on network at IP address: Oct-18 16:52:39 JowiHue Debug: :Probing Hue bridge at IP Oct-18 16:52:39 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:52:39 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:52:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:50:39 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:50:39 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:50:39 JowiHue + Unregistered bridge found on network at IP address: Oct-18 16:50:39 JowiHue Debug: :Probing Hue bridge at IP Oct-18 16:50:39 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:50:39 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:50:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:48:39 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:48:39 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:48:39 JowiHue + Unregistered bridge found on network at IP address: Oct-18 16:48:39 JowiHue Debug: :Probing Hue bridge at IP Oct-18 16:48:39 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:48:39 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:48:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:47:57 JowiHue Debug: :id:timer Oct-18 16:46:39 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:46:39 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:46:39 JowiHue + Unregistered bridge found on network at IP address Oct-18 16:46:39 JowiHue Debug: :Probing Hue bridge at IP Oct-18 16:46:39 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:46:39 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:46:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:44:39 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:44:39 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:44:39 JowiHue + Unregistered bridge found on network at IP address: Oct-18 16:44:39 JowiHue Debug: :Probing Hue bridge at IP Oct-18 16:44:39 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:44:39 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:44:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:42:39 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:42:39 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:42:39 JowiHue + Unregistered bridge found on network at IP address: Oct-18 16:42:39 JowiHue Debug: :Probing Hue bridge at IP Serial= (removed) Oct-18 16:42:39 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:42:39 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:42:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:40:39 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:40:39 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:40:39 JowiHue + Unregistered bridge found on network at IP address Oct-18 16:40:39 JowiHue Debug: :Probing Hue bridge at IP Serial= (removed) Oct-18 16:40:39 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:40:39 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:40:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:38:52 JowiHue Debug: :End search for bridges Oct-18 16:38:51 JowiHue Debug: :id:timer Oct-18 16:38:45 JowiHue Debug: :InitPlugin:Config Done InitOK=False Oct-18 16:38:45 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page Oct-18 16:38:45 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:38:45 JowiHue Debug: :InitDevices: Device checks done Oct-18 16:38:43 JowiHue Debug: :InitDevices: Searching for Hue devices Oct-18 16:38:42 JowiHue SetLightSuspected: Bridge has been reset, setting all bridge lights suspected, so original settings can be restored later if needed Oct-18 16:38:42 JowiHue Debug: :GetLightsFromBridge: Building list of lights connected to bridge '""' Oct-18 16:38:42 JowiHue Debug: :Searching for bridges Oct-18 16:38:42 JowiHue Debug: :Scanning for bridges starting Oct-18 16:38:42 JowiHue * Connected to bridge "" at (removed) Oct-18 16:38:41 JowiHue bridge Philips hue ip adress is (removed) Oct-18 16:38:41 JowiHue bridge Philips hue is known as bridge, but is now unregistered. Please reregister through the configuration page. Oct-18 16:38:40 JowiHue Debug: :InitDevices: Searching for Hue devices Oct-18 16:38:39 JowiHue Debug: :InitPlugin:initial checks Oct-18 16:38:39 JowiHue InitIO:Plugin basic initialisation done Oct-18 16:38:39 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:37:32 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:37:11 JowiHue Debug: :id:oRefreshRate Oct-18 16:37:11 JowiHue Debug: :RefreshRate:4.0 Oct-18 16:36:57 JowiHue Debug: :id:timer Oct-18 16:35:33 JowiHue Debug: :UpdateStatusThread:Start with refreshrate set to 2000 ms Oct-18 16:35:33 JowiHue Plugin succesfully started Oct-18 16:35:32 JowiHue Debug: :InitPlugin:Config Done InitOK=True Oct-18 16:35:32 JowiHue ============================================================================================== Oct-18 16:35:32 JowiHue Device of reporting bridge and light firmware updates is enabled Oct-18 16:35:32 JowiHue 0 Animations available for use in this plugin Oct-18 16:35:32 JowiHue 15 Local scenes available for use in the JowiHue plugin Oct-18 16:35:32 JowiHue -------------------------------------Plugin info --------------------------------------------- Oct-18 16:35:32 JowiHue 3 Groups available on bridge 'Philips hue' Oct-18 16:35:32 JowiHue 4 lights connected to bridge 'Philips hue' Oct-18 16:35:32 JowiHue -------------------------------------Bridge info --------------------------------------------- Oct-18 16:35:32 JowiHue ============================================================================================== Oct-18 16:35:32 JowiHue Debug: :GetAnimations finished normal Oct-18 16:35:32 JowiHue Debug: :GetScenes finished normally Oct-18 16:35:32 JowiHue Debug: :RefreshDevices finished succesfully for bridge Philips hue Oct-18 16:35:32 JowiHue Debug: :GetScenesFromBridge: Building list of scenes found on bridge 'Philips hue' Oct-18 16:35:32 JowiHue Debug: :GetSensorsFromBrige: Building list of sensors connected to bridge 'Philips hue' Oct-18 16:35:32 JowiHue Debug: :GetRulesFromBrige: Building list of Rules connected to bridge 'Philips hue' Oct-18 16:35:32 JowiHue Debug: :GetGroupsFromBridge: Building list of groups on bridge 'Philips hue' Oct-18 16:35:32 JowiHue Debug: :checking suspected lights Oct-18 16:35:32 JowiHue Debug: :checking suspected lights Oct-18 16:35:32 JowiHue Debug: :checking suspected lights Oct-18 16:35:32 JowiHue Debug: :checking suspected lights Oct-18 16:35:32 JowiHue Debug: :checking suspected lights Oct-18 16:35:32 JowiHue Debug: :GetLightsFromBridge: Building list of lights connected to bridge 'Philips hue' Oct-18 16:35:32 JowiHue Debug: :InitPlugin:Starting Bridge Oct-18 16:35:32 JowiHue Debug: :InitPlugin: 1 registered bridge(s) found Oct-18 16:35:32 JowiHue Debug: :SearchAndCheckBridges::1 bridge(s) found in this network Oct-18 16:35:32 JowiHue Debug: :InitPlugin:Starting Device checks Oct-18 16:35:32 JowiHue Debug: :MainWatchTimer: Checking plugin health Oct-18 16:35:25 JowiHue Debug: :id:timer Oct-18 16:34:06 JowiHue Debug: :RefreshDevices finished succesfully for bridge Philips hue Oct-18 16:34:06 JowiHue Debug: :GetScenesFromBridge: Building list of scenes found on bridge 'Philips hue' Oct-18 16:34:06 JowiHue Debug: :GetSensorsFromBrige: Building list of sensors connected to bridge 'Philips hue' Oct-18 16:34:06 JowiHue Debug: :GetRulesFromBrige: Building list of Rules connected to bridge 'Philips hue' Oct-18 16:34:06 JowiHue Debug: :GetGroupsFromBridge: Building list of groups on bridge 'Philips hue' Oct-18 16:34:06 JowiHue Debug: :checking suspected lights Oct-18 16:34:06 JowiHue Debug: :checking suspected lights Oct-18 16:34:06 JowiHue Debug: :checking suspected lights Oct-18 16:34:06 JowiHue Debug: :checking suspected lights Oct-18 16:34:06 JowiHue Debug: :checking suspected lights Oct-18 16:34:06 JowiHue Debug: :GetLightsFromBridge: Building list of lights connected to bridge 'Philips hue' Oct-18 16:34:06 JowiHue Debug: :Createuser BridgeRow.User:xxxxx Oct-18 16:34:06 JowiHue Registering bridge was succesfull
Zigmund
