UpdateStatusTimer errors in HomeSeer log
  • UpdateStatusTimer errors in HomeSeer log
    Hi Wim,
    All of a sudden jowihue pulgin is logging errors repeately. Any idea what can be the cause? Of course a restart of the plugin solves the problem.
    Zigmund
    09:36:02:1673:[JowiHue]->RefreshDevices: Error: Object reference not set to an instance of an object
    09:36:02:1753:[JowiHue]->Error in EnergyProcessThread:Object reference not set to an instance of an object
    09:36:03:3103:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:05:3100:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:07:3099:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:09:3099:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:11:3101:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:13:3101:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:15:3101:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:17:3101:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:19:3102:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:21:3104:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:23:3104:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:25:3104:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:27:3105:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:29:3105:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:31:3106:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:33:3105:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:35:3106:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:37:3107:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    09:36:39:3108:[JowiHue]->UpdateStatusTimer: Unexpected result in polling, plugin will reinitialise
    Zigmund,
    This one is a surprise to me. With this error the plugin should restart itself, but it did not. I will have to look deeper into this one why it did not do it.
    Wim
    -- Wim
