Hi,
I'm trying to run the JowiHue plugin on Linux.
I had it working before, but there was a lot of messing around I had to do just to get JowiHue to discover the bridge. From what I recall, part of this was because I've had some strict iptables rules in place, and part of it seemed to be some confusion about which interface (eth0 or eth1) to broadcast on.
Since then, I've upgraded to the new square bridge and lost my JowiHue connection again.
In case it helps: I stopped the plugin and then deleted all of the old devices. I have also added two rules to the top of my input and output iptables, which grants access both ways for any IP on my internal network (eth0; internet is on eth1).
After more fiddling and frustration (ie. couldn't even find the bridge), I decided to upgrade to the latest beta; version 1.0.6.11.
This version was able to find the bridge and accept the "registration" (ie. pressing the button), but then it would throw an exception. The bridge device would be added to my Devices page, but I couldn't go into the configuration for the plugin without stopping and restarting it. When I went back in, it lost its registration.
Here's a sample of my debug logs, latest entry first, with some duplicate lines removed and the username vetted out:
Any ideas?
Thanks in advance!
Dec-22 8:28:06 PM JowiHue Webconfig: Error: BuildContent: Object reference not set to an instance of an object Dec-22 8:27:58 PM JowiHue UpdateConfigDevices called for unknown reason. Ref = 216 change Dec-22 8:27:36 PM JowiHue Debug: :id:timer Dec-22 8:27:36 PM JowiHue Debug: :Createuser BridgeRow.User:7ed7aab214a0ed015db4czzzzzzzzzzz Dec-22 8:27:36 PM JowiHue Registering bridge was succesfull Dec-22 8:27:36 PM JowiHue Debug: :Createuser response:[{"success":{"username":"7ed7aab214a0ed015db4czzzzzzzzzzz"}}] Dec-22 8:27:36 PM JowiHue Debug: :Createuser response:[{"error":{"type":101,"address":"","description":"link button not pressed"}}] Dec-22 8:27:33 PM JowiHue Debug: :id:timer Dec-22 8:27:30 PM JowiHue Debug: :Createuser response:[{"error":{"type":101,"address":"","description":"link button not pressed"}}] Dec-22 8:27:30 PM JowiHue Debug: :id:timer Dec-22 8:27:27 PM JowiHue Debug: :Createuser response:[{"error":{"type":101,"address":"","description":"link button not pressed"}}] Dec-22 8:27:27 PM JowiHue Debug: :BridgeReg_001788FFFE23611D:Submit Dec-22 8:27:27 PM JowiHue Debug: :registrationstring:{"devicetype": "JowiHue"} Dec-22 8:27:27 PM JowiHue Debug: :id:oBridgeReg_btnBridge_001788FFFE23611D Dec-22 8:27:16 PM JowiHue Debug: :End search for bridges Dec-22 8:27:16 PM JowiHue ============================================================================================ Dec-22 8:27:16 PM JowiHue ------------------------------------------NEW Bridge --------------------------------------- Dec-22 8:27:16 PM JowiHue Info: Unregistered bridge found at IP address 192.168.84.185 Dec-22 8:27:16 PM JowiHue Please register this bridge in the configuration page Dec-22 8:27:16 PM JowiHue ============================================================================================ Dec-22 8:27:15 PM JowiHue Debug: :btnScan:Submit Dec-22 8:27:15 PM JowiHue Debug: :id:obtnScan Dec-22 8:27:12 PM JowiHue Debug: :id:timer Dec-22 8:27:11 PM JowiHue Debug: :id:Debug Dec-22 8:27:11 PM JowiHue Debug: :Debug:checked Dec-22 8:26:58 PM JowiHue MainWatchThread: No bridge found, plugin will scan until found Dec-22 8:26:58 PM JowiHue Upgrading devices to latest version 7 Dec-22 8:26:58 PM JowiHue FindBridgesSelf error: Column 'BridgeSerial' does not allow nulls. Dec-22 8:26:58 PM Plug-In Finished initializing plug-in JowiHue Dec-22 8:26:58 PM JowiHue InitIO:Plugin basic initialisation done Dec-22 8:26:58 PM JowiHue Starting plugin JowiHue 1.0.6.11 Dec-22 8:26:57 PM Info Plugin JowiHue has connected. IP:127.0.0.1:52247 Dec-22 8:26:53 PM Info Plugin JowiHue with instance: has disconnected Dec-22 8:26:53 PM JowiHue could not close normally Dec-22 8:26:53 PM Plug-In Shutting down Plug-In: JowiHue Dec-22 8:26:49 PM JowiHue Webconfig: Error: BuildContent: Object reference not set to an instance of an object Dec-22 8:26:19 PM JowiHue Webconfig: Error: BuildContent: Object reference not set to an instance of an object
Thanks in advance!
