Hi,
And thanks Wim for a great plugin :-)
I have some bulbs attached to a normal ceiling socket, and wit ha manual on/off switch by the door. problem is, that when turned off (no power to the bulb at all). Jowihue still sees the last status for the bulb, but the hue app states the bulb unreachable, though it is on in the app.
Is it possible to make the bridge recognize that the bulb is powerless = unreachable, for then, when the light switch is turned on again, make Jowihue see this, and then set colors etc.??
Jowihue updates the bulb status fine if turned on/off in the app, but not when power is removed and bulb get "unreachable".
Does is make sense? :-)
Br. Martin
Br. Martin
