A/C setpoint , down button below 18 celcius
    Hi Stef, I remember in our discussion that you said that the api was not consistent with the control available for the ac.
    So, here i can set the ac to watever value i want with the dropdown box. But if the setpoint is at 18 celcius and I hit the down button it does not go to 17 or 16 (this is the lower limit)
    I wonder, sicne i can hear the bip from the ac ( but this is a bip like if the same command as the real status was sent), if the down and up buttons is something coded in the plugin ( and maybe the lg app too) and the plugin actually send a real number to the api instead of a lower or upper command? And/or if this is just a limit of the inconsistency in the api?
    thanks
    Scratch that. actually i can't send values under 18 with the dropdown box too.
      Yes, that was still on my list. Please try 4.0.0.10.
      As I can't find a reliable way to detect cool and heat limits, I just assume 16-30 as the a/c will simply use the upper or lower limit when exceeding those limits.
      stefxx
        It is not working
          The success rate today is quite low
          stefxx
            I don't get it. But in 4.0.0.12 I removed all upper and lower limits (you can even press down when at 16 and it will attempt to set the a/c at 15, but the a/c should "protest" by beeping 5 times). Hope this works for you...
            stefxx
              Sorry Stef , I wanted to write ‘’ it is *now* working. ‘’
                Sorry again. I wrote this fast , since I was doing multiple things at the same time yesterday .I think you can revert the behavior when you have time .
                  Originally posted by MattL0 View Post
                  Sorry again. I writed this fast , since I was doing multiple thing at the same time yesrerday. I think uou can revert the behavior when you have time .
                  stefxx
                    Here it is not going to 15. It’s stays at 16 if i press the down button 1 time. But if I press it two times it goes back to 30.
                      Well, You did well and fast again. Just tested V 4.0.0.14 and all is good now .Thank for being so fast and effective.
                        I released beta 14 also as release 4.0.1.0. Should be available soon.
                        Thanks for testing!
                        stefxx
