That way I would know when my my appliances have updated.
Possibility to add firmware in a device string
GuestTags: None
Never mind my previous (deleted) message. I didn't realize I was already showing the firmware in the setup, were I assumed the modem version to be the firmware version.
Small challenge is that I am only getting this information at plugin startup. It isn't part of the device status I get every xx seconds.
See the latest beta (4.0.4.4) for a first attempt. It will get the device info every hour (instead of only at startup) which I guess should be sufficient to check for firmware versions anyway. Bonus is that if you add a new device while the plugin is already running, it should be automatically detected and added within the hour as well.stefxx
Guest
