Plugin support
This topic is closed.
This is a sticky topic.
  • Plugin support
    The LimitlessLED plug-in is based on a open source API.
    So be aware of every API, it might prevent the plugin from accessing the Wifi bridge or any other issues.
    If an update breaks the plugin, I will try and fix this as soon as possible. But I cannot make any promises of how fast it will be solved or even in the worst case scenario it cannot be solved at all.
    Thank you for understanding.
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
