Issue & Feature Request
  • Issue & Feature Request
    Got the new controllers V6 installed and everything is working except brightness
    Code looks like its missing version: 31 0 0 0 3 63 0 0 0
    Also if dim less than 15% you get:
    Exception in HandleAction: The hex string cannot have an odd number of digits
    Few Request:
    1) Tried to purchase but not in store yet - Just FYI
    2) Zone names can you add to admin to be able to change these or at least if you change them in device management they do not add new ones when plugin restarted. (This is for voice control so you can say Turn on Kitchen cabinets instead of turn on zone 1 control)
    3) Saturation control would be a nice feature as well
    4) Mode control would be a nice feature as well
    Thanks for all your help, love being able to control my lights now via Echo/Alexa
    Steven G
    Few Request:
    Steven G
    I started the plugin simple, but adding functionality is no problem. I will add this in a couple of days.
    See https://shop.homeseer.com/products/l...nt=38051357260 for product purchase.
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Just checking in, any movement on a version that doesn't add devices after restart if you renamed original device?
      Steven G
        Steven G
        I have a version in which this is solved, but I was planning to add some more feature request before making a new version available in the updater.
        If you want I can sent you a interim release.
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
          That would be great
          Stevenggiles @ gmail
          Thanks Steven G
            Just checking in
            Any update.
            Steven G
              Just checking in
              Any update.
              Steven G
              Please try this version https://www.dropbox.com/s/n5gj5ip94y...ssLED.exe?dl=0
              You have to delete your existing devices first!
              Rien du Pre
              The Netherlands
              Using:
              Plugin's:
                That worked to retain the names
                did you take a look at the dimming/brightness? Should be an easy fix as its only missing version in the send code. That is the only issue remaining I found.
                Steven G
                  Rien,
                  Did you have any luck with the dimming/brightness that is the last broken item on the plugin. Just need it to set timers for dimming zones at night
                  Steven G
                    Rien,
                    Any timeline to get the plugin fully functional?
                    Steven G
