WiFi Bridge
  • WiFi Bridge
    Does the plugin support more than 1 WiFi Bridge?
    Robert
    Yes via multiple instances
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Not sure I understand. The plugin only allows for 1 ip address.
        Never mind. New to HS3
        Ty
          @ the plugin page you can get an extra instance by clicking on the "plus".
            I added a second instance of the plugin. The problem I am having is when I add the ip address of the second wifi box it changes the first instance to the same ip address.
              Ah that's a bug....
              What exact version are you using?
              Rien du Pre
              The Netherlands
              Using:
              Plugin's:
