Can't add 2nd Hub
  • Can't add 2nd Hub
    so far the first hub i've added is working OK, but when i go to create another instance of the plug-in, i enter all the IP info, but it doesn't stay.
    It will act like it saves, but when i close out and go back it's all gone. Instead of saving the data to the config of the second instance, it's overwriting the IP info of the first instance.
    i'm using version 3.1.0.0
    any ideas?
    any ideas?
    That a bug, Ill look into that...
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      This is solved in the upcoming release (this week)
      Rien du Pre
      The Netherlands
      Using:
      Plugin's:
        Still receive error in Version: 3.3.0.0 with 2nd instance:
        Error Calling SetIOMulti in plugin LimitlessLED:Conversion from string "" to type 'Double' is not valid.
          Hi I need more logging with debug enabled, plus the content of your ini file (for the 2nd instance)
          Rien du Pre
          The Netherlands
          Using:
          Plugin's:
            I removed everything and reinstalled plugin and got it to work using a number for instance name (if I use a word I get the error once started
            So if I use a number to create instance it works.
            Now issue is all the zone control and colors use the number of the instance instead of zone
            example This is power on for zone 2 and 3 on instance 1:
            Mar-24 2:07:34 PM LimitlessLED Plugin: LimitlessLED Received: 88 0 0 0 3 0 2 0
            Mar-24 2:07:34 PM LimitlessLED Plugin: LimitlessLED Command SUCCESSFUL.
            Mar-24 2:07:34 PM LimitlessLED Plugin: LimitlessLED Send command: 80 0 0 0 11 35 0 0 2 0 31 0 0 8 4 1 0 0 0 1 0 3F
            Mar-24 2:07:34 PM LimitlessLED Plugin: LimitlessLED IP Address is 10.0.1.93
            Mar-24 2:07:34 PM LimitlessLED Plugin: LimitlessLED Received: 28 0 0 0 11 0 2 F0 FE 6B 62 E0 BC 45 9D 2A DE 0 1 35 0 0
            Mar-24 2:07:34 PM LimitlessLED Plugin: LimitlessLED Test input is -10.0.1.93-5987-31 00 00 08 04 01 00 00 00-01
            Mar-24 2:07:34 PM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-100-Zone 3 Control - 1-0-1328-01
            Mar-24 2:07:31 PM LimitlessLED Plugin: LimitlessLED Received: 88 0 0 0 3 0 1 0
            Mar-24 2:07:31 PM LimitlessLED Plugin: LimitlessLED Command SUCCESSFUL.
            Mar-24 2:07:31 PM LimitlessLED Plugin: LimitlessLED Send command: 80 0 0 0 11 30 0 0 1 0 31 0 0 8 4 1 0 0 0 1 0 3F
            Mar-24 2:07:31 PM LimitlessLED Plugin: LimitlessLED IP Address is 10.0.1.93
            Mar-24 2:07:31 PM LimitlessLED Plugin: LimitlessLED Received: 28 0 0 0 11 0 2 F0 FE 6B 62 E0 BC 45 9D 2A DE 0 1 30 0 0
            Mar-24 2:07:31 PM LimitlessLED Plugin: LimitlessLED Test input is -10.0.1.93-5987-31 00 00 08 04 01 00 00 00-01
            Mar-24 2:07:31 PM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-100-Zone 2 Control - 1-0-1327-01
            If I create and instace 2 same number chages to 2 and so on
            Let me know if you need more not sure if I am explaining correctly
              Can you try the version located here -->https://www.dropbox.com/s/hrsobxgeza...ssLED.exe?dl=0
              Rien du Pre
              The Netherlands
              Using:
              Plugin's:
                I installed new version and restarted everything.
                Lost ability to modify plugin thru UI. (had to update ini files manually)
                I receive this now for original instance and added instance. (no zones work with this version)
                Mar-26 8:59:26 AM Error Calling SetIOMulti in plugin LimitlessLED:Conversion from string "" to type 'Double' is not valid.
                Mar-26 8:59:26 AM LimitlessLED Plugin: LimitlessLED Test: -
                Mar-26 8:59:26 AM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-0-Zone 1 Control - 1-100-1295-
                Mar-26 8:59:13 AM Error Calling SetIOMulti in plugin LimitlessLED:Conversion from string "" to type 'Double' is not valid.
                Mar-26 8:59:13 AM LimitlessLED Plugin: LimitlessLED Test: -
                Mar-26 8:59:13 AM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-0-Cabinet Upper Lights-100-1044-
                HSPI_LimitlessLED.ini
                [Settings]
                OS version=Windows
                Architecture=x86
                cb_debug_checked=1
                IPPort=5987
                Type=2
                IPAddress=XX.XX.XX.XX (REAL IP IS HERE)
                ZType1=8
                ZType2=8
                ZType3=8
                ZType4=8
                HSPI_LimitlessLED_1.ini
                [Settings]
                OS version=Windows
                Architecture=x86
                cb_debug_checked=1
                IPPort=5987
                Type=2
                ZType1=8
                I removed zones I am not using in the ini files, plugin still builds 8 zones with restart.
                  That's odd, because I have no errors anymore
                  You better hide unused zones.
                  What error do you get when you want to use the GUI to set the config
                  And is it possible to delete al you devices ?
                  Rien du Pre
                  The Netherlands
                  Using:
                  Plugin's:
                    I removed everything (LimitlessLED) and reinstalled and restarted HS.
                    For the UI there are no links and nothing in the Plugins drop down.
                    Here is results on new install with manual entries in ini file:
                    [Settings]
                    OS version=Windows
                    Architecture=x86
                    cb_debug_checked=1
                    IPPort=5987
                    Type=2
                    ZType1=8
                    IPAddress=xx.xx.xx.xx (real ip here)
                    ZType2=8
                    ZType3=8
                    ZType4=8
                    Zone 4 Control On:
                    Mar-26 3:37:41 PM Error Calling SetIOMulti in plugin LimitlessLED:Conversion from string "" to type 'Double' is not valid.
                    Mar-26 3:37:41 PM LimitlessLED Plugin: LimitlessLED Test: -
                    Mar-26 3:37:41 PM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-100-Zone 4 Control-0-1396-
                    Zone 3 Control On:
                    Mar-26 3:37:39 PM Error Calling SetIOMulti in plugin LimitlessLED:Conversion from string "" to type 'Double' is not valid.
                    Mar-26 3:37:39 PM LimitlessLED Plugin: LimitlessLED Test: -
                    Mar-26 3:37:39 PM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-100-Zone 3 Control-0-1395-
                    Zone 2 Control On:
                    Mar-26 3:37:36 PM Error Calling SetIOMulti in plugin LimitlessLED:Conversion from string "" to type 'Double' is not valid.
                    Mar-26 3:37:36 PM LimitlessLED Plugin: LimitlessLED Test: -
                    Mar-26 3:37:36 PM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-100-Zone 2 Control-0-1394-
                    Zone 1 Control On:
                    Mar-26 3:39:47 PM Error Calling SetIOMulti in plugin LimitlessLED:Conversion from string "" to type 'Double' is not valid.
                    Mar-26 3:39:47 PM LimitlessLED Plugin: LimitlessLED Test: -
                    Mar-26 3:39:47 PM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-100-Zone 1 Control-0-1393-
                    Zone 1 Control (Slider):
                    Mar-26 3:44:49 PM Error Calling SetIOMulti in plugin LimitlessLED:Conversion from string "" to type 'Double' is not valid.
                    Mar-26 3:44:49 PM LimitlessLED Plugin: LimitlessLED DimLevel in HEX is : 3C
                    Mar-26 3:44:49 PM LimitlessLED Plugin: LimitlessLED Test: -
                    Mar-26 3:44:49 PM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Control-60-Zone 1 Control-0-1393-
                    Confirmed Color for zones is working
                    Zone 1 Color (Green):
                    Mar-26 3:42:29 PM LimitlessLED Plugin: LimitlessLED Received: 88 0 0 0 3 0 1 0
                    Mar-26 3:42:29 PM LimitlessLED Plugin: LimitlessLED Command SUCCESSFUL.
                    Mar-26 3:42:29 PM LimitlessLED Plugin: LimitlessLED Send command: 80 0 0 0 11 B6 0 0 1 0 31 0 0 8 1 54 54 54 54 1 0 8B
                    Mar-26 3:42:29 PM LimitlessLED Plugin: LimitlessLED IP Address is xx.xx.xx.xx (real ip here)
                    Mar-26 3:42:29 PM LimitlessLED Plugin: LimitlessLED Received: 28 0 0 0 11 0 2 F0 FE 6B 2D BD FE 5F B8 69 FB 0 1 B6 0 0
                    Mar-26 3:42:29 PM LimitlessLED Plugin: LimitlessLED Test input is -xx.xx.xx.xx (real ip here)-5987-31 00 00 08 01 54 54 54 54-01
                    Mar-26 3:42:28 PM LimitlessLED Plugin: LimitlessLED Test: 8-
                    Mar-26 3:42:28 PM LimitlessLED Plugin: LimitlessLED CAPIcontrol values: LimitlessLED Zone Color-204-Zone 1 Color-207-1401-01
                    Please let me know if you need anything.
                      Hi,
                      What HS version do you use ?
                      Rien du Pre
                      The Netherlands
                      Using:
                      Plugin's:
                        HomeSeer Version: HS3 Standard Edition 3.0.0.402 (Windows)
                          Hmmm, beta version.
                          I'll wait till the new version is officially available, which is soon.
                          Maybe it has something to do with it.
                          Rien du Pre
                          The Netherlands
                          Using:
                          Plugin's:
                            I had some time and removed everything and went back to version 3.3.0.0. I have everything working as it should be for main instance, then added 2nd instance and looks like send commands are using version 5 (number 7) even though I have specified version 6 (number 8).
                            I ran commands on main instance and 2nd instance results are below as well as .ini files
                            Zone 1 OFF
                            2nd: 80 0 0 0 11 CC 0 0 4 0 31 0 0 7 3 2 0 0 0 3 0 40
                            1st: 80 0 0 0 11 AC 0 0 10 0 31 0 0 8 4 2 0 0 0 1 0 40
                            Zone 1 ON
                            2nd: 80 0 0 0 11 20 0 0 5 0 31 0 0 7 3 1 0 0 0 3 0 3F
                            1st: 80 0 0 0 11 D6 0 0 11 0 31 0 0 8 4 1 0 0 0 1 0 3F
                            Zone 2 OFF
                            2nd: 80 0 0 0 11 5C 0 0 6 0 31 0 0 7 3 2 0 0 0 3 0 40
                            1st: 80 0 0 0 11 3C 0 0 12 0 31 0 0 8 4 2 0 0 0 2 0 41
                            Zone 2 ON
                            2nd: 80 0 0 0 11 8D 0 0 7 0 31 0 0 7 3 1 0 0 0 3 0 3F
                            1st: 80 0 0 0 11 61 0 0 13 0 31 0 0 8 4 1 0 0 0 2 0 40
                            Zone 1 Color (BLUE)
                            2nd: 80 0 0 0 11 B3 0 0 8 0 31 0 0 7 1 AA AA AA AA 3 0 E4
                            1st: 80 0 0 0 11 8E 0 0 14 0 31 0 0 8 1 AA AA AA AA 1 0 E3
                            Zone 1 Color (WHITE)
                            2nd: 80 0 0 0 11 DC 0 0 9 0 31 0 0 7 5 64 0 0 0 3 0 A4
                            1st: 80 0 0 0 11 B1 0 0 15 0 31 0 0 8 5 64 0 0 0 1 0 A3
                            Zone 2 Color (BLUE)
                            2nd: 80 0 0 0 11 F8 0 0 A 0 31 0 0 7 1 AA AA AA AA 3 0 E4
                            1st: 80 0 0 0 11 D1 0 0 16 0 31 0 0 8 1 AA AA AA AA 2 0 E4
                            Zone 2 Color (WHITE)
                            2nd: 80 0 0 0 11 17 0 0 B 0 31 0 0 7 5 64 0 0 0 3 0 A4
                            1st: 80 0 0 0 11 FC 0 0 17 0 31 0 0 8 5 64 0 0 0 2 0 A4
                            2nd:
                            [Settings]
                            OS version=Windows
                            Architecture=x86
                            cb_debug_checked=1
                            IPAddress=X.X.X.X
                            IPPort=5987
                            Type=2
                            ZType1=8
                            ZType2=8
                            ZType3=0
                            ZType4=0
                            ZType5=0
                            ZType6=0
                            ZType7=0
                            ZType8=0
                            1st:
                            [Settings]
                            OS version=Windows
                            Architecture=x86
                            cb_debug_checked=1
                            IPAddress=X.X.X.X
                            IPPort=5987
                            Type=2
                            ZType1=8
                            ZType2=8
                            ZType3=8
                            ZType4=8
                            ZType5=0
                            ZType6=0
                            ZType7=0
                            ZType8=0
                              Any update with the above post
