3.0.0.104 - In the config page you can UnGroup the device from the Caseta Plugin so it will work more friendly in the new Mobile Apps
New Version description
can you please advise how to use plugin to add a "Pico shade controller"
item pj2-3brl-gwh-s01
I can add the Pico controller to the lutron app, and I can have a device created in HomeSeer using the plugin, but the device statut does not get updated when I press the buttons on the pico
I'm guessing one or DeviceType is wrong, but I've tried most or all of the combinations in the plugin
the wireless pico will NOT control lutron shades. I will use HomeSeer Events to respond to changing value of the HS device, and those events will control Somfy Shades using the ZRTSI
thanks
chris
To be sure uncheck thein the configuration of the device, then check the log, also the last change should also change.Do not log commands from this device:
to control your somfy use the events, you can see an exemples in the post 7 https://forums.homeseer.com/forum/lighting-primary-technology-plug-ins/lighting-primary-technology-discussion/lutron-caseta-donmor/1256449-no-on-off-functions-on-my-pico-remote-please-help
Is your Smartbrige connect?Telnet Connected LutronCaseta LutronCaseta Scenes Caseta-1 LutronCaseta Scenes
