Does Caseta plugin work with RA2 Select
    RA2 Select appears to be in the Caseta family and has Telnet capabilities like the bridge pro. I have RA2 (RRD-PRO) switches and dimmers and need to control them with a Z-Wave keypad.
    Can I do it with one of your plugins?
    I don't think the select publishes anything over telnet. You need the main repeater.
      Yes the RA2 Select use the same plug-in as the Caseta, you will be able to control your device with the Telnet.
        I am using both Ra2 Select and Caseta on the same plugin. Works Great
          You guys are referring to this? I didn't think this had telnet integration.
            Yes it does, same as the Caseta.
            The TCP Address should match the address of the Caseta/RA2 Select. Port 23 is used for the telnet session between the driver and Caseta/RA2 Select.
              Well this is news to me.
              i ended up buying the main repeater for use with the Lutron motion sensors.
              so you’re telling me I could if got select and paired up the motion sensors instead ?
