I am trying to link/associate a RA2S switch to the light switch in a HS-FLS100. The result is:
RA ON -> FLS no response
RA OFF -> FLS no response
Nothing in HS log (with Lutron PI set to no debug logging)
If I then use an event:
IF Exterior Den RA2S NorthEast Flood Switch changes and becomes On
THEN Set Device: Exterior Den NE Floodlight Sensor NE Floodlight to On
The results are:
RA ON -> FLS ON
RA OFF -> FLS OFF
Which works, but the question is "why do I need an event to trigger an ON, but the linking works fine with an OFF?" I now think it may be a bug in the PI.
I turned on debug logging in the PI, disabled the above event (so I am depending on the linking/association only) and toggled the RA switch On, wait about 10s, Off. Again, the Floodlight did not respond. Here is the log:
08/16/21 07:40:26 Legacy-Plugin LutronCaseta Debug ~ERROR,Enum=(1, 0x00000001)
08/16/21 07:40:25 Legacy-Plugin LutronCaseta Debug Set Hs device on Caseta- Exterior Den NorthEast Flood Switch ref#:103 to :0.00
08/16/21 07:40:25 Legacy-Plugin LutronCaseta Debug Set Hs4 device on Caseta- to :0.00
08/16/21 07:40:25 Legacy-Plugin LutronCaseta Debug go to ~output18 1 0.00
08/16/21 07:40:25 Legacy-Plugin LutronCaseta Debug Receive: ~OUTPUT,18,1,0.00
08/16/21 07:40:25 Legacy-Plugin LutronCaseta Debug ~OUTPUT,18,1,0.00
08/16/21 07:40:13 Legacy-Plugin LutronCaseta Debug Set Hs device on Caseta- Exterior Den NorthEast Flood Switch ref#:103 to :100.00
08/16/21 07:40:13 Legacy-Plugin LutronCaseta Debug Set Hs4 device on Caseta- to :100.00
08/16/21 07:40:13 Legacy-Plugin LutronCaseta Debug go to ~output18 1 100.00
08/16/21 07:40:13 Legacy-Plugin LutronCaseta Debug Receive: ~OUTPUT,18,1,100.00
08/16/21 07:40:13 Legacy-Plugin LutronCaseta Debug ~OUTPUT,18,1,100.00
08/16/21 07:40:02 Legacy-Plugin Z-Wave Device: Zwave Node 4 SE Motion Sensor Set to NOTIFICATION for type Home Security, Event: No Event
08/16/21 07:39:55 Legacy-Plugin LutronCaseta Debug ~ERROR,Enum=(1, 0x00000001)
I believe you can ignore the notification ffrom SE Motion Sensor.
The results are:
RA ON -> FLS ON
RA OFF -> FLS OFF
