Did you disable the caseta before update?
Caseta Plug-in Randomly Dies
Lutron Caseta Plug-in Randomly Dies
DonMor,
I disabled the Lutron Caseta Plug-in and it updated fine. I thought I had done that before, both with and without disabling before attempting the update. I guess not. In any case, thanks for your patience. I will keep you posted as to how things work in the days and weeks ahead.
Justin in Dallas
DonMor,
Within minutes of updating to the lastest plug-in, Ver 3.0.0.80, I observed lots of the following:
<style> <!-- /* Font Definitions */ @font-face {font-family:Times; panose-1:2 0 5 0 0 0 0 0 0 0; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:3 0 0 0 1 0;} @font-face {font-family:"MS 明朝"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-charset:128; mso-generic-font-family:roman; mso-font-formatther; mso-font-pitch:fixed; mso-font-signature:1 134676480 16 0 131072 0;} @font-face {font-family:"MS 明朝"; panose-1:0 0 0 0 0 0 0 0 0 0; mso-font-charset:128; mso-generic-font-family:roman; mso-font-formatther; mso-font-pitch:fixed; mso-font-signature:1 134676480 16 0 131072 0;} @font-face {font-family:Cambria; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:auto; mso-font-pitch:variable; mso-font-signature:-536870145 1073743103 0 0 415 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0in; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:Cambria; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"MS 明朝"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-family:Cambria; mso-ascii-font-family:Cambria; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"MS 明朝"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Cambria; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} @page WordSection1 {size:8.5in 11.0in; margin:1.0in 1.25in 1.0in 1.25in; mso-header-margin:.5in; mso-footer-margin:.5in; mso-paper-source:0;} div.WordSection1 {page:WordSection1;} --> </style> <table class="MsoNormalTable" style="mso-cellspacing:0in;mso-yfti-tbllook:1184" cellspacing="0" cellpadding="0" border="0"> <tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes;mso-yfti-lastrow:yes"> <td style="padding:.75pt .75pt .75pt .75pt" nowrap=""> Mar-02 09:25:12
</td> <td style="padding:.75pt .75pt .75pt .75pt">
</td> <td style="padding:.75pt .75pt .75pt .75pt"> LutronCaseta Debug
</td> <td style="padding:.75pt .75pt .75pt .75pt"> Receive: ~ERROR,1
</td> </tr> </tbody></table>
<table class="MsoNormalTable" style="mso-cellspacing:0in;mso-yfti-tbllook:1184" cellspacing="0" cellpadding="0" border="0"> <tbody><tr style="mso-yfti-irow:0;mso-yfti-firstrow:yes;mso-yfti-lastrow:yes"> <td style="padding:.75pt .75pt .75pt .75pt" nowrap=""> Mar-02 09:24:42
Not sure what to make of these, but one batch of them seems to be coming in every 90 seconds or so.....see attached PDF. Other functions seem to be working OK.
Is this really a problem, other than clogging up my LOG file?
Justin
This is normal in the debug mode, to be able to monitor is the telnet is still connected I need to send a command that return an error. To de sable this unchecked the debug log.
If you want to log the change of the device do not use the debug, but unchecked the "Do not log commands from this device:" instead in the device configuration from the home page.
