QS Plug-In Question
This is a sticky topic.
  • #16
    Is there any way to configure and run multiple instances of the plugin (so that each instance communicates/controls a specific qs processor)? I have 3 qs processors (two for lights and one for shades) that I need to control. Thanks.
    • #17
      Any instructions on setting this up with QSE-CI-NWK-E? I've readdressed the unit and put that IP into your program and used user/pswrd as NWK which are the defaults and I can telnet into it with. Question is the unit was programmed by electrician when installed and scenes are already programed. I don't want to cause any programing in the unit to be lost. Customer would just like to see the devices and control them through Homeseer app not build scenes and such. Your interface has boxes to "reset" this or that and then select system create. This makes my a bit weary as I don't anything to stop working that is already there. please advise.
      • #18
        Don’t worry, you can’t change anything with this Plugins in your QS, the reset is for homeseer only graphics or name in homeseer.
        after you enter the IP, user and pwd, enable the plugin after click create device, bingo you can control all the QS with homeseer.
        • #19
          I changed all network settings for theQSE-CI-NWK-E so it is on the correct subnet. I can telnet into the device and when i do i can see activity on the unit as people use the devices. I cannot however get the plug in to work with the unit. In the logs it shows "Start Importing", "connected to the telnet IP address: 10.10.10.70Port: 23", "Now try to Log in Lutron", "Lost connection with Telnet", "Error Creating device process stop :The operation has timed out" and then "Finish Importing". No matter what configuration I get the same. Any suggestions? I'd like to make sure this is going to work before I buy it for the customer.
          • #20
            When you press create it is normal the telnet connection lost, Can you post a picture of you config page
            • #21
              Screen shot attached
              Greg
              • #22
                Here is the log file as well
                Greg
                • #23
                  did you try with the user: lutron and the password integration ?
                  • #24
                    I did try your xml, and it process normally, try to export with chrome with your IP to see if you can import it, maybe a firewall block the port 80.
