Post your questions here.
QS Plug-In Question
This is a sticky topic.
Has anybody adopted QS in a Homeseer system? It looks like the Hi-Lume 1% LED driver is controlled via QS. Unless I am mistaken, this is the correct way to get digital dimming implemented in the driver, no mucking about with the line voltage. One just has to install remote power supply LED fixtures.
Is this the way to get proper LED dimming with a digital remote LED driver integrated to Homeseer?
For your questions you should search on google like Lutron hi-lume RA2, this is the result
http://www.lutron.com/TechnicalDocum...%20_RA%202.pdf
Ra2 is compatible with the hi-Lume, are you sure you need the QS? This is the high end, more complexes and more expensive.
Originally posted by DonMor View PostFor your questions you should search on google like Lutron hi-lume RA2, this is the result
Fantastic plug-in first of all. Secondly, I see version 3.0.0.94 in the updater, I'm running 3.0.0.92 now. I disable the plug-in, click the checkmark, install the update (and am told it was updated successfully), but it still shows 3.0.0.92 and that 3.0.0.94 is available for update. Any ideas on how to force the update?
Oh, one other question, when I am doing a discovery to create new devices I sometime get this error, is it anything to be concerned about?
"Posting back to plugin web page LutronQSConfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)"
Not sure if it is related, but I am always missing at least a few devices (maybe more, I have a lot of devices), after a scan.
Also see this error at the beginning of the scan:
Displaying remotely connected interfaces: Object reference not set to an instance of an object.
Originally posted by gbdesai View PostOh, one other question, when I am doing a discovery to create new devices I sometime get this error, is it anything to be concerned about?
I know the Ra2 repeaters are programmed with the Essentials/Inclusive software, how is the QSE-CI-NWK-E programmed with standalone sensors? Like the LRF2-DCRB-WH daylight sensors?
I thought I had some documentation on how to do this but can't seem to find it now. And my google searching isn't turning up results (but I'd welcome pointers!) I was under the impression that the NWK was the the right 'hub' to do this.
My goal is adding some of the daylight sensors in key places around the house and use their values to for HS3 events. Like opening/closing shades or raising/lowering lights depending on sun/cloud conditions.
