thermostat operating state supported?
    wondering if thermostat operating state is supported with this plugin? I'm debating dumping the rest of my zwave equipment, but the one thing I like about the gocontrol tstats is that operating state is instantly reported.
    The thermostat I use is do reply as fast as the outer device of ra2 the one I use is Clear Connect RF Touch pro
      sorry, trying to understand your response... sounds like it does support the operating state instant reporting?
      Also, can you help me understand what I need to expand my Ra2 setup with a few thermostats? Do they talk with the main repeater, or do I need separate hardware? Also, are they supported in essentials?
      Thanks! This plugin rocks btw! Never misses a beat!
      edit: nevermind, looks like the hvac controller isnt required if using a regular t-stat like you suggested (according to this doc): http://www.lutron.com/TechnicalDocum...y/367-2020.pdf
        Correct, the TouchPRO Wireless™ thermostat is a Honeywell thermostat with the ra2 clear connect who communicate directly to the main repeater.
          I'm having some issues with the TouchPRO thermostat that I ordered to test things out. Particularly when I go to do something like change the Fan Mode to 'On' - the HVAC is replying (so I know the command is going through), but devices aren't updating in HS with the proper values. Fan Mode and Fan State both stay where they're at and don't change. Thoughts?
