new plug-in checkboxes?
    I notice the plug-in now has checkboxes for Renaming room, name and button.
Name:	lutron plug-in checkboxes.JPG
    Room and Name seem obvious, but where is Button stored?
    Also, how do I use the "ID Lutron device to reset (All for All):" option?
    I'm starting to make use of Phantom Buttons on the Main Repeaters. Is is possible to import/rename JUST those items? Not everything else?
    Is there a way to have the HS3 devices update just the Main Repeater buttons?
    The Room and Name reset is to be able to bring back from RA2 software if someone change the name in RA2,
    Changing the "All" for the ID of your main_repeater, in your case it is ID 1, then click Systems Create All new Devices that don't exist. it should create your new Phantom. and only the ID 1.
    in my case the ID of my main_repeater is 59
    Connect
    LUTRONRA2 Equipment Room MAIN_REPEATER LutronRA2-Device-19
    What do you mean where is Button stored? If you mean Phantom yes this come from the ID of the main_repeater
      This checkbox:
      Where is "Button Name"?
        it is in the device property, it will reset the graphics/status
Name:	reset button name.png
        Also you can do it in the LutronRA2 tab of the device property
