My RR2 thermostat device in HS3 has rails and lower by 1 degree buttons. They all work except raise cool setpoint. Is this unique to my installation or a common problem? I'm trying to implement this in HSTouch but it doesn't even work in the regular UI. Thanks
Increase Cool Setpoint
Not many feedback on the thermostat, I need to rework that part to be more compatible with mobile and hst, I did use the same status/graphics number as the lutron integration. The standard of HS don't match with the lutron, so I need to twik it. So in future update if you have event you may need to check it.
I'll check at the same time your issue
