Per your advice updating the software and then the repeater did fix my issue. Thank you for the great support with this!
Darren
New install - Can't import devices
It seemed to access it fine so I've attached it to see if you see any issues with it.Attached Files
Can you try to access the XML http://www.lutron.com/TechnicalDocum...action_FAQ.pdf
i did this plugin with the ver. 8
Yes - Essentials v6.0 though as it was set up initially about 6 years ago.
I am testing the plugin to see if it will work with a simple RadioRA2 setup. The RadioRa2 setup consists of about 10 dimmer switches.
I installed the plugin, configured it and it seems to log in but when I try to create devices I get the following error. No devices are created in Homeseer.
Any ideas?
2 PhotosTags: None
