Send Command to Pico Remote?
    I have recently installed a 4-button Pico Remote to control Lutron shades in my Family Room. The pico buttons are open, close, raise and lower. The pico is programmed within the RA2 software, and when I press open or close on the pico, the shades go up or down in unison, which is very nice.
    I would like to create events within HS3 to open or close the shades, using the pico. I could of course control the shades directly within HS3 (not using the pico) but there is a slight delay in HS3 sending the open/close command to the shades, and they do not go up and down in unison. However, when I create an event in HS3 and send the open or close command to the pico, the shades do not move. The pico status changes, so I know that the event is sending the command to the pico (at least within HS3), but somehow the Lutron repeater is not getting the message.
    Is it possible to issue commands to the pico for control of RA2 devices?
    DonMor Can you please respond to this question? Thanks.
      It should work, are you using press or release, if I remember the action with the Pico is with the release. Also you can create the action in the RA2 software with the phantom button
        I tried sending every possible command to the pico through HS3, and nothing has any effect. when I press the physical pico button, the shades go up and down just fine.The log and a screenshot of my devices is attached. Also, I would think that the shade devices would have a percentage status/control, rather than off/on/last?
ID:	1344327Click image for larger version
          DonMor Any thoughts on this?
            Thank you for the log, I’ll test it tomorrow and get back
              I did fix in the version 116, but HS have issue with the updater, as soon they fix that you will be able to update.
                you should see the version 116 in the beta section, tell me if it work than I'll post it in the updater.
                  I'll test it tonight and let you know.
                    Hi DonMor I tested the new Plug In and it still doesn't rake commands from the Pico. Here is a screenshot of the device.
                    I pressed the following buttons, and this is the resulting log:
                    -Open
                    -Open Release
                    -Close
                    -Close Release
                     [TABLE="border: 0, cellpadding: 0, cellspacing: 0"]
                    [TR]
                    [TD]Dec-15 10:50:55 AM[/TD]
                     			[TD] [/TD]
                     			[TD]LutronRA2 Debug[/TD]
                     			[TD]Send: #DEVICE,86,114,4[/TD]
                     		[/TR]
                    [/TABLE]
                    [TR]
                     			[TD] [/TD]
                     		[/TR]
                    [/TABLE]
                    [TR]
                    [TD]Dec-15 10:50:52 AM[/TD]
                     			[TD] [/TD]
                     			[TD]Send: #DEVICE,86,113,4[/TD]
                     		[/TR]
                    [/TABLE]
                    [TR]
                     			[TD] [/TD]
                     			[TD]Send: #DEVICE,86,113,3[/TD]
                     		[/TR]
                    [/TABLE]
                    [TR]
                    [TD]Dec-15 10:50:49 AM[/TD]
                     			[TD] [/TD]
                     			[TD]Send: #DEVICE,86,84,4[/TD]
                     		[/TR]
                    [/TABLE]
                    [TR]
                     			[TD] [/TD]
                     		[/TR]
                    [/TABLE]
                    [TR]
                    [TD]Dec-15 10:50:45 AM[/TD]
                     			[TD] [/TD]
                     			[TD]Send: #DEVICE,86,83,4[/TD]
                     		[/TR]
                    [/TABLE]
                    [TR]
                     			[TD] [/TD]
                     			[TD]Send: #DEVICE,86,83,3[/TD]
                     		[/TR]
                    [/TABLE]
                      can you try the ver. 117 in the beta section
                        Thanks DonMor . That worked. I am now able to issue commands directly to the Pico.
