Hi guys,
I guess my setup is missing something. Just found out after 3 weeks of using RR2 with Homeseer that I can control all lights from HS flawlessly. I can see on, off, dimmed status etc. But when I use switch manually device status will not update in HS. Am I missing some setting?
I tried to reset main repeater and hub with no change. That makes me think that I messed up something in my setup somewhere.
What did I miss? Is there a step that allows feedback to HS when switch is used manually? I did not have this problem when I was using RA2 Select plugin.
Thanks, Charles
Thanks, Charles
