I've got a couple keypads in different locations each with an "ALL ON/OFF" button and buttons controlling various loads. I can easily set the ALL ON/OFF to use the LAST attribute that is native to that keypad. I'm trying to figure out how to send the attribute to other keypads.
Example:
Keypad one controls ALL ON/OFF with LAST settings along with a couple can lights and raise/lower buttons.
Keypad two controls ALL ON/OFF with LAST settings along with a table light and raise lower buttons.
If I adjust the lights on one keypad with the raise/lower buttons then trigger the ALL ON/OFF button, it responds by turning on both lights, but only uses the LAST setting for the load on the keypad with the pressed button. For the other load, it defaults to the load programmed in RadioRA2 even if I tell it to use the LAST setting.
Is there a way to make devices read the LAST settings for loads from other keypads? Thanks!
Example:
