Hello,
I have an HS4 system using the RadioRA2 plugin. I use this plugin on a few HS3 systems and it's rock solid reliable. The issue I'm having on HS4 is very strange and it's happened 3 times now.
I'll set up the event shown below. It works great, and then all of a sudden the customer reports it's not working. I log in and check, and the event is disabled. The log shows a few comm errors, but they only last for a minute or so.
Any idea how that would cause the event to become disabled?
Here's the event and the log file:
Any help would be greatly appreciated.
Brian
8/19/2021 5:06:00 PM HomeSeer Energy DB Info All energy database compacting routines completed. 8/19/2021 5:06:00 PM HomeSeer Energy DB Info No Records. Vacuuming database to condense. 8/19/2021 5:06:00 PM HomeSeer Energy DB Info Energy database compaction initiated. 8/19/2021 1:06:00 PM HomeSeer Energy DB Info All energy database compacting routines completed. 8/19/2021 1:06:00 PM HomeSeer Energy DB Info No Records. Vacuuming database to condense. 8/19/2021 1:06:00 PM HomeSeer Energy DB Info Energy database compaction initiated. 8/19/2021 12:45:16 PM HomeSeer Info System connected to MyHS Service successfully with license ID 693130. 8/19/2021 12:45:16 PM HomeSeer Info System connected to MyHS Service, waiting for acknowledge... 8/19/2021 12:45:04 PM HomeSeer Warning Have not heard from MyHS in over 3 minutes, disconnecting for re-connection. 8/19/2021 12:33:36 PM HomeSeer Info System connected to MyHS Service successfully with license ID 693130. 8/19/2021 12:33:36 PM HomeSeer Info System connected to MyHS Service, waiting for acknowledge... 8/19/2021 12:33:15 PM Legacy-Plugin LutronRA2 Telnet Login succesfull 8/19/2021 12:33:12 PM Legacy-Plugin LutronRA2 Now try to Log in Lutron 8/19/2021 12:33:12 PM Legacy-Plugin LutronRA2 connected to the telnet IP address: 192.168.1.3Port: 23 8/19/2021 12:33:06 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....No route to host 8/19/2021 12:32:57 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....No route to host 8/19/2021 12:32:47 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....No route to host 8/19/2021 12:32:38 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....No route to host 8/19/2021 12:32:29 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....No route to host 8/19/2021 12:32:20 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....Network is unreachable 8/19/2021 12:32:13 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....Network is unreachable 8/19/2021 12:32:07 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....Network is unreachable 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Found 0 device group value conditions that need monitoring 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Found 0 device group value triggers 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Refreshing list of device group value triggers to monitor 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Found 0 random triggers 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Refreshing list of random triggers to monitor 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Found 0 schedule triggers 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Refreshing list of schedule triggers to monitor 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Found 0 device's value conditions that need monitoring 8/19/2021 12:32:03 PM Legacy-Plugin EasyTrigger INFO Found 1 device's value triggers 8/19/2021 12:32:02 PM Legacy-Plugin EasyTrigger INFO Refreshing list of device's value triggers to monitor 8/19/2021 12:32:02 PM Legacy-Plugin EasyTrigger INFO Found 0 device's string triggers 8/19/2021 12:32:02 PM Legacy-Plugin EasyTrigger INFO Refreshing list of device's string triggers to monitor 8/19/2021 12:32:01 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....Network is unreachable 8/19/2021 12:31:56 PM HomeSeer Startup Start up complete. 8/19/2021 12:31:56 PM HomeSeer Info Found 1 issue(s) with devices 8/19/2021 12:31:56 PM HomeSeer Warning Device (5) LUTRONRA2 Equipment Room MAIN_REPEATER is marked as child, but does not reference any parent 8/19/2021 12:31:56 PM HomeSeer Warning Issue checking parent device (6) LUTRONRA2 Equipment Room MAIN_REPEATER 8/19/2021 12:31:56 PM HomeSeer Warning Device (5) LUTRONRA2 Equipment Room MAIN_REPEATER does not reference a parent, it should reference one parent 8/19/2021 12:31:56 PM HomeSeer Warning Issue checking child device (5) LUTRONRA2 Equipment Room MAIN_REPEATER 8/19/2021 12:31:56 PM HomeSeer Info Checking device parent child relationships... 8/19/2021 12:31:56 PM HomeSeer Error Downloading update control file 8/19/2021 12:31:56 PM HomeSeer TTS Speak ():Welcome to Home-Seer 8/19/2021 12:31:56 PM HomeSeer Warning MyHS could not connect to server: Could not resolve host 'connected2.homeseer.com' 8/19/2021 12:31:56 PM HomeSeer Info Checking for updates... 8/19/2021 12:31:56 PM HomeSeer Startup Starting the HS4 Sentry EXE 8/19/2021 12:31:56 PM Script Startup Scripting is OK and is now running Startup.vb 8/19/2021 12:31:56 PM HomeSeer Startup Starting HSSentry watchdog. 8/19/2021 12:31:56 PM HomeSeer Startup Starting Event Scheduler... 8/19/2021 12:31:55 PM Legacy-Plugin LutronRA2 ERROR Unable connect to the telnet check the IP address. Error: 192.168.1.3:23....Network is unreachable 8/19/2021 12:31:50 PM HomeSeer Startup Running the startup script Startup.vb 8/19/2021 12:31:50 PM HomeSeer Startup HStouch server started, waiting for clients to connect. 8/19/2021 12:31:50 PM HomeSeer HSTouch Server Server started on port 10200 8/19/2021 12:31:50 PM HomeSeer Plug-In Finished initializing plug-in LutronRA2 8/19/2021 12:31:50 PM HomeSeer Starting Plug-In LutronRA2 loaded in 3905 milliseconds 8/19/2021 12:31:50 PM HomeSeer Starting Plug-In Plugin LutronRA2 started successfully in 2500 milliseconds 8/19/2021 12:31:50 PM Legacy-Plugin LutronRA2 Initializing done! Ready... Telnet 8/19/2021 12:31:48 PM Legacy-Plugin LutronRA2 Starting initializiation. Telnet Ver.: 3.0.0.132 8/19/2021 12:31:48 PM HomeSeer Starting Plug-In Initializing plugin LutronRA2 ... 8/19/2021 12:31:48 PM HomeSeer Info Plugin LutronRA2 has connected. IP:127.0.0.1:53768 8/19/2021 12:31:46 PM HomeSeer Plug-In Finished initializing plug-in EasyTrigger 8/19/2021 12:31:46 PM HomeSeer Starting Plug-In EasyTrigger loaded in 1503 milliseconds 8/19/2021 12:31:46 PM HomeSeer Starting Plug-In Plugin EasyTrigger started successfully in 303 milliseconds 8/19/2021 12:31:46 PM Legacy-Plugin EasyTrigger INFO EasyTrigger version 3.0.0.73 8/19/2021 12:31:46 PM HomeSeer Starting Plug-In Initializing plugin EasyTrigger ... 8/19/2021 12:31:46 PM HomeSeer Info Plugin EasyTrigger has connected. IP:127.0.0.1:53764 8/19/2021 12:31:45 PM HomeSeer Startup Initializing Plug-Ins 8/19/2021 12:31:45 PM HomeSeer Plug-In Found plug-in: LutronRA2, version: 3.0.0.132 8/19/2021 12:31:43 PM HomeSeer Plug-In Found plug-in: EasyTrigger, version: 3.0.0.73 8/19/2021 12:31:42 PM HomeSeer Plug-In Found plug-in: Z-Wave UI, version: 1.0.0.0 8/19/2021 12:31:40 PM HomeSeer Plug-In Found plug-in: Z-Wave, version: 3.0.7.0 8/19/2021 12:31:38 PM HomeSeer Startup Checking for available plug-ins 8/19/2021 12:31:38 PM HomeSeer Info Remote plug-in API interface started on port 10400 8/19/2021 12:31:38 PM HomeSeer Startup Starting Find service... 8/19/2021 12:31:38 PM HomeSeer Startup Updater services starting... 8/19/2021 12:31:38 PM HomeSeer Database Opening (Mode=Read/Write) up HomeSeer Energy database /usr/local/HomeSeer/Data/Energy/Energy.hsd 8/19/2021 12:31:38 PM HomeSeer Speech Listening for remote speaker connections on port 10401 8/19/2021 12:31:38 PM HomeSeer Startup Initializing Speaker Client Interface 8/19/2021 12:31:38 PM HomeSeer Startup Start automation engine... 8/19/2021 12:31:38 PM HomeSeer Web Server Web Server started on port 80 8/19/2021 12:31:38 PM HomeSeer Web Server Local IP address is: 127.0.0.1 8/19/2021 12:31:38 PM HomeSeer Startup This version of HomeSeer is registered as a HS4ZEES2_PIHUB version. 8/19/2021 12:31:38 PM HomeSeer Startup Creating Speaker Client Interface Object... 8/19/2021 12:31:38 PM HomeSeer Startup HomeSeer version is: 4.1.18.0 8/19/2021 12:31:38 PM HomeSeer Info Loaded 1 Events. 8/19/2021 12:31:38 PM HomeSeer Info Loaded 28 Devices. 8/19/2021 12:31:37 PM HomeSeer Startup Loading configuration file ... 8/19/2021 12:31:37 PM HomeSeer Startup Local voice recognition class started. 8/19/2021 12:31:37 PM HomeSeer Startup Plug-In Interface class started. 8/19/2021 12:31:37 PM HomeSeer Startup E-Mail RECEIVE class started. 8/19/2021 12:31:37 PM HomeSeer Startup E-Mail SEND class started. 8/19/2021 12:31:37 PM HomeSeer Startup Web server class started. 8/19/2021 12:31:37 PM HomeSeer Startup Application interface class started. 8/19/2021 12:31:37 PM HomeSeer Startup COM port classes started. 8/19/2021 12:31:37 PM HomeSeer Startup Creating Class Objects... 8/19/2021 12:31:36 PM HomeSeer Startup 8/19/2021 12:31:36 PM HomeSeer Startup ************************************************************ ******************** 8/19/2021 12:31:36 PM HomeSeer Startup HomeSeer version 4.1.18.0 Edition: HomeSeer HS4 Pi Hub G2 Starting Now 8/19/2021 12:31:36 PM HomeSeer Startup ************************************************************ ******************** 8/19/2021 12:31:36 PM HomeSeer Startup 8/19/2021 12:31:36 PM HomeSeer Startup Settings Loaded. 8/19/2021 12:31:36 PM HomeSeer Warning HomeSeer was not shut down successfully the previous time it was started. 8/19/2021 12:31:36 PM HomeSeer Startup Loading Settings
Brian
