New feature request
This is a sticky topic.
    New feature request
    Please post your request for new feature or amelioration here.
    Compatible with seeTemp wall control?
    Hi
    Does it work with the seeTemp control?
    http://www.lutron.com/en-US/Products.../Overview.aspx
    Best Regards
    Mikkel GP
      Originally posted by zzapper77 View Post
      Hi
      Best Regards
      Mikkel GP
      Mikkel
      It is easy for me to add it but will need your help, I don't have that in my house
        I would have my thermostat in about a week, will update you when I integrate this fonction
        Please post everything that can improve this plugin.
          seetemp should be integrate, I don't have one so please reply is you have one with a positive or negative description
            HS3 Plug-In support for the new Lutron RadioRA 2 Select Main Repeater
            Greetings - I've been a HomeSeer evangelist and Lutron RadioRA 2 fan for years - back when the only Lutron / HomeSeer PI offered was for the 1st Gen RadioRA. Seems it never got updated to support the nextgen RadioRA 2 or Caseta wireless systems... that is until DonMor's fresh work! At CEDIA 2017 in San Diego, Lutron introduced their RadioRA 2 SELECT Main Repeater which comes in at about one half the cost of previous RA2 Main Repeaters and maintains full compatibility with existing RadioRA2 switches and dimmers. And its operation and limited programming only works with iOS and Android Apps - but its extremely easy to deploy and manage.
            I have tested the new Lutron RadioRA 2 Select Main Repeater (RR-SEL-REP2-BL) with DonMor's two Lutron-focused PI's and I am happy to say the Caseta PI seems functional. There may be some quirks plus unknown errors are being logged, but I do have interactive bidirectional communications and control between HS3 and a test bed consisting of one Lutron dimmer (RRD-6ND-WH) and one Lutron Pico wireless control keypad (PJ2-3BRL-GWH-L01).
            In a simple demonstrations, I am able to ask Alexa to "Turn on the Vanity Lights" controlled by the (RRD-6ND-WH). Likewise, a button press of the inexpensive Pico keypad can trigger dissimilar HomeSeer devices and events. Its wonderful! This opens a new door and far exceeds what can be done with Lutron's current iOS and Android Apps for the RadioRA 2 Select DIY programming.
            The HS3 Event Log shows a recurring pair of entries like this:
            Nov-09 02:50:55 LutronCaseta Debug ~ERROR,1
            for which I have no clue what to look for as the cause.
            (NOTE: I also tested DonMor's LutronRA 2 PI with the RadioRA 2 Select MR, but I wasn't certain how to configure the PI thus it failed to communicate in the manner the Caseta PI does.)
            If I can assist with field testing to eliminate the event log errors and implement (or correct) other aspects of the Lutron PI's let me know! I do plan to purchase the PI when my eval period expires in a few days.
            Thank you!
            Danne - Dan the LAN MAN
            HS3 Plug-Ins Enabled: Global Cache Pro; Restart; drhsIpPlugIn; UltraLighting3; Insteon; Nest; UltraMon3; Ultra1Wire3; Z-Wave; NetCAM; RFXCOM; EasyTrigger; BLOnkyo; UPBSpud; LutronCaseta; MCSSPRINKLERSP; UltraWeatherWU3.
            Number of Devices: 519
            Number of Events: 308
              Dan, the error log in debug mode is normal, with the telnet I need to send a bad command that return this error to be sure the communication still on, if I don't receive that error I restart the telnet communicating.
                Thanks for the speedy reply. I now understand the error and its purpose. Today I have now unchecked the Debug logging option.
                I am using these settings in the Caseta PI:
                SmartBridgeS1 Enabled: [YES]
                SmartBridgeS1 SSH Enabled: [NO]
                Lutron IP Address (xxx.xxx.xxx.xxx): 192.168.0.21
                Lutron Telnet Port (Default 23): 23
                Lutron SSH Port (Default 22): 22
                Arrive Home Scene Id: 254
                Live Home Away Scene Id: 255
                Hub Model:
                Hub Model: is blank. Also - Not being a Lutron HEAVY, I don't understand your RED instruction "*** For Pro only: ver 94 had an error, if a device doesn't match apps report ID with the HS3 address, erase device and re-create it ***"
                ALSO - Should I be doing more experimenting with your RadioRA 2 PI and its broader settings? Or is the Caseta PI the correct for me using the RadioRA 2 Select MR?
                Danne - Dan the LAN Man
                  Hub Model: is blank. This won't be back until I finalise the new communication with SSL to replace the SSH
                  Also - Not being a Lutron HEAVY, I don't understand your RED instruction "*** For Pro only: ver 94 had an error, if a device doesn't match apps report ID with the HS3 address, erase device and re-create it ***". This was after an update from a previous version that could corrupt some device, I should now remove that
                  ALSO - Should I be doing more experimenting with your RadioRA 2 PI and its broader settings? Or is the Caseta PI the correct for me using the RadioRA 2 Select MR? I think the caseta is the correct PI for the select, I will send you a pm to make a test to see if the select have an xml in the bridge.
                    I realize this thread is old but hopefully still the correct place for feature requests / questions about features (specific to Grafik Eye units):
                    - For Grafik Eye keypads, the Led on indicators are different than for regular keypads. Just curious if this is intentional.
                    - I noticed that my seetouch keypads have device for led indication of buttons labeled "off" but the "off" buttons for Grafik Eye keypads don't show up. Is this intentional? can it be changed (either by changing the name or other means)?
                      As a follow up to the "off" button not being created on the Grafik Eye units, I changed the "off" button to "1 Off" and added a shade column with a button labeled "2 off". The shade column as added to the GE device, but instead of adding a "2 off" button device, it added a "raise" device. On the main button column, it renamed "night" (the 2nd button from the bottom) to "2 off", but it still functions like "night". Something seems odd on the lowermost button on both columns (see attachment - you can see the device and the labels of all the buttons, but the corresponding devices created aren't quite right). Thanks
                        Small UI request, 8ANS switches (simple on/off, no dimmer) are showing up as "Appliance Module" in the Type column. I also see some VCRX contact open/close set this way. Are supposed to?
                        Other items are showing as "Lamp Module", "LutronRA2 MAIN_REPEATER", "LutronRA2 MOTION", "LutronRA2 TimeClockEvent" and the like.
                        The Type column is just a label, right? So it doesn't really matter what string is in the field, correct?
Name:	appliance modules.JPG
                          Be sure to not change it, it is use for HSTouch
                            How does HSTouch use this?
                            Also, the 'Foosball Table' device is an H6BRL dimmer, configured as "LED Switched" in the Ra2 software. But it's got a range set up for it in HS3?
                              This is from homeseer 3 years ago:
                              Set the device type string on your HS device to "Lamp Module", that will allow the dimming screen to display. On the Android client, we are also looking at the ControlUse property as we are getting away from using the device type string. However, I see that the Windows client has not been updated yet.
                              Please post a screen shot, I don't understand what you mean
