New feature request
This is a sticky topic.
    #16
    Originally posted by DonMor View Post
    Please post a screen shot, I don't understand what you mean
    I did, in post #12, above in this thread.
    Here's a shot of the Status tab.
Name:	hybrid range 1.JPG
    The device has always been set to LED Switched, so I don't know how HS3 decided to use the slider setup.
      #17
      I'm assuming I can 'correct' this by removing the Include Values check and the start/end range. It just seems odd the device got set up this way. I'm assuming it's been that way for a while, I'm just now noticing it.
        #18
        I'll pm you
          #19
          Yes you can delete it, something I don't understand is your device type string is appliance module, this is correct but should not have the dim,
            #20
            Can you try this before you delete set the Id to 68 instead of all and check reset graphics, then import to see if it remove the dim
              #21
              An other way to reset an ID is to go to the property of the device in the LutronRA2 tab and press Reset Graphics.
                #22
                Don—the Radio RA2 Essentials software has the ability to have a light turn on to its last level. Is there a way to have that option in HS3? I know I can accomplish this with a virtual device that remembers the last level, but if it could be native to the plugin, it would save the effort of setting that up on each device. I think Zwave devices also have this native ability. Thanks.
                  #23
                  Please guide me, I never sad this
                    #24
                    I’m not sure what you mean. I’m trying to find out if you could add an option to the plug in that would allow the light level to be set to its last level. This would be used in an event that turned on the light.
                      #25
                      I’ll work to integrate the last level as soon I’m finishing the multi-instance.
                        #26
                        I did incorporate the Last function in the beta ver. 106.
