if after you restart it does kick in and start working, you should get an entry in the debug line showing the Model, Mac and Firmware Version. if you give me that i can pin the Model and Firmware version to default to legacy bulb in future and over time i can grow that matrix
Magic Color Controllers
Originally posted by fuzzysb View Postok that drop down in the settings after discovery, can you change the selection to LegacyBulb then restart the plugin. does that kick it in to start working?
Ok understood, i will work on a new version and try to resolve the high CPU version, however i do not have time today to work on it as i am travelling.
but before i do, I really need the result of the test, so could you please edit your MagicHome.ini file in the config directory and add the [MAGICHOME] section if it doesnt Exist, your file should look something like this (from your screenshot that is the correct MAC)
Code:[GENERAL] log_level=Debug [MAGICHOME] ACCF232F50A0=LegacyBulb
Originally posted by fuzzysb View PostOk understood, i will work on a new version and try to resolve the high CPU version, however i do not have time today to work on it as i am travelling.
My ini file contains:
[GENERAL]
log_level=Debug
log_to_file_enabled=True
[MAGICHOME]
But I don't see any devices created, so not sure exactly what I should do next....
hi, i've released a new beta 1.0.0.213 which i am hoping will stop High CPU Usage, so now it should not cause you any issues. it seems to work ok, but i need you do check against your device.
i now check the number of bytes in the status, now the request should timeout and not increase CPU usage if the device is offline or not responding. and this should cater as well for you.
from your response above though, you do get a response from the device for the get status, but please let me know if the behaviour changes with this ver
Ok that is strange. Can you get me the extract of the debug log that also includes the plugin startup where it lists the model and firmware version of your device? Best to log to a file and then pm me that file zipped up
Does the colour picker work?, or does that have the same issue?
RK15 I am just doing some research on this issue with some LEDNET 5 channel controllers. Can i confirm that you did set the drop down in the settings of the plugin for your device to RgbWarmwhiteCoolwhite after discovery has occurred? as i believe from my reading for lednet should work as i am sending 9 bytes in all colour change sliders. if you did not set the drop down, then this will not work. please note you will need to restart the plugin after selecting the drop down
I've been traveling, but back home. I installed the latest version, but why I have the drop down combo I still do not have any devices. I tried raising the timeout to see if that helps, but the setting does not stick if you don't have devices (apparently) it keeps resetting to 100ms. It should probably be disabled if not usable or at least remember the setting.
What else can I check to help you solve the no devices issue?
Originally posted by bsobel View Postbut the setting does not stick if you don't have devices (apparently) it keeps resetting to 100ms. It should probably be disabled if not usable or at least remember the setting.
I think i have found further info on your specific device and firmware. try the latest beta (v1.0.0.148) i've just posted, the dropdown for timeout should work now, and i am hoping finally you should now have devices created, if you don't have devices discovered please increase the timeout until you do. I have also added a Retry Discovery button to retry the discovery once you change the timeout. it's worth noting this won't actually create any new discovered devices until the next device status poll interval which will be shown in the log. (however the last debug line will show how many new devices were discovered if indeed they were)
