Event using preset error
  • Event using preset error
    I get this error when trying to pick preset in a event, using ver
    1.0.0.290
    vent Name: Type Group Reassign:
    (Enter New Type Name) (Create A New Group)AIR COMPRESSORALARMALARM BOARD 6AMBIENT WEATHERARDUINOBACKUPBACKUP ALL HOMESEER FILESBarbeque GrillBEERBLUE IRISCAMERACOAL STOVEDOORSFISH TANKFISH TANK LIGHT MAGIC HOMEFREZZERFuranceGARAGEHAMSACKHOT WATER LOOPHS-200 LED LIGHTIPJon00 IPLAUNDRYLCDLIGHTSLIVING ROOMLOCATIONLOCKLOGMAGIC HAT LIGHTSMASTER BEDROOMmusicOFFICEPATIOPHILPHONEPONDPOWERREF KITCHENSPEAKERSSPRINKLERSSTATUST STATtalkTESTTIMETIMERS VIRTUAL FOR HS TOUCHTODAY TALKWATER SENSORWEATHERWELLXMASS
    Voice Command:
    IF This event is MANUALLY triggered
    THENNEVER Control a DeviceControl a TimerControl a CounterControl the TelephoneSpeak SomethingPlay an Audio FileSend an EmailWaitRun Another EventRun a Script or Script CommandRun Commands from a Received EmailRun Another Program or ProcessRun The Event Group ActionsCancel Another Running EventCancel a Delayed Device ActionCancel a Delayed EventChange the System's Audio OutputBLBackup: Start BackupBLBackup: Abort BackupBLLAN: Send WOLBLShutdown: ShutdownBlue-Iris: Server ActionsBlue-Iris: Camera ActionsBlue-Iris: Set BI MacroEasyTrigger: Set Device to VariableEasyTrigger: Set Device to another DeviceEasyTrigger: Set Device's stringEasyTrigger: Set Device to ExpressionEasyTrigger: Toggle DeviceEasyTrigger: Set Schedule to another ScheduleEasyTrigger: Set Group of Devices to ExpressionEasyTrigger: Enable EventEasyTrigger: Disable EventEasyTrigger: Push Device's value to stackEasyTrigger: Pop Device's value from stack and Set DeviceEasyTrigger: Clear StackMagicHome ActionNetCAM: Take PictureUltraLog3: Export LogsweatherXML ActionsZ-Wave ActionsHSTouch Actions
    Error calling the plug-in to get the Action UI: Input string was not in a correct format.
    Options >
    On let me test today and I will get back to you.
      RK15 I've just release v1.0.0.294 Beta which should fix the issue above.
