Illume Lights and MagicHome App work but Homeseer not changing colors
    I bought a few Illume Lights that are driven by the MagicHome app. I downloaded the PI from fuzzy, but it seems that changing colours and using the HomeSeer mobile are not working yet. Has anyone ran into this issue? Also, it looks like the Firmware for these lights are V8. Not sure if this is supported yet. Any help would be appreciated! Thanks everyone
    Here is my log:
    Sep-13 22:33:58 INFO MagicHome version 1.0.0.335
    Sep-13 22:33:59 DEBUG MagicHome Device Poll Inititated.
    Sep-13 22:33:59 DEBUG Discovery will run on on NIC Adapter Ethernet 2
    Sep-13 22:34:00 DEBUG Running Discovery on on NIC Adapter Ethernet 2 and will target broadcast address 192.168.0.255
    Sep-13 22:34:05 DEBUG Discovery will not run on on NIC Adapter Wi-Fi as it is either in a non operational state, Does not support Multicast, or we have failed to get IPv4 Properties
    Sep-13 22:34:05 DEBUG Discovery will not run on on NIC Adapter Local Area Connection* 1 as it is either in a non operational state, Does not support Multicast, or we have failed to get IPv4 Properties
    Sep-13 22:34:05 DEBUG Discovery is not running on NIC Adapter Loopback Pseudo-Interface 1 as it is the Loopback Interface
    Sep-13 22:34:05 DEBUG Discovery is not running on NIC Adapter Teredo Tunneling Pseudo-Interface as it is not an Ethernet or Wireless Interface
    Sep-13 22:34:11 DEBUG Device model AK001-ZJ200 with Mac Address DC4F22D0F0DE and Firmware Version 8, proceeding to update Homeseer devices.
    Sep-13 22:34:12 DEBUG Updating Device DC4F22D0F0DE Root Device Value Pairs
    Sep-13 22:34:12 DEBUG Updating Device DC4F22D0F0DE Value Pairs
    Sep-13 22:34:13 DEBUG Updating Device DC4F22D0F0DE Colour Value Pairs
    Sep-13 22:34:13 DEBUG Updating Device DC4F22D0F0DE Red Value Pairs
    Sep-13 22:34:13 DEBUG Updating Device DC4F22D0F0DE Green Value Pairs
    Sep-13 22:34:13 DEBUG Updating Device DC4F22D0F0DE Blue Value Pairs
    Sep-13 22:34:13 DEBUG Updating Device DC4F22D0F0DE Warm White Value Pairs
    Sep-13 22:34:13 DEBUG Updating Device DC4F22D0F0DE Cool White Value Pairs
    Sep-13 22:34:13 DEBUG Updating Device DC4F22D0F0DE Preset Value Pairs
    Sep-13 22:34:13 DEBUG Device model AK001-ZJ200 with Mac Address DC4F2288C4C7 and Firmware Version 8, proceeding to update Homeseer devices.
    Sep-13 22:34:14 DEBUG Updating Device Pot Light 3 Root Device Value Pairs
    Sep-13 22:34:14 DEBUG Updating Device Pot Light 3 Value Pairs
    Sep-13 22:34:15 DEBUG Updating Device Pot Light 3 Colour Value Pairs
    Sep-13 22:34:15 DEBUG Updating Device Pot Light 3 Red Value Pairs
    Sep-13 22:34:15 DEBUG Updating Device Pot Light 3 Green Value Pairs
    Sep-13 22:34:16 DEBUG Updating Device Pot Light 3 Blue Value Pairs
    Sep-13 22:34:17 DEBUG Updating Device Pot Light 3 Warm White Value Pairs
    Sep-13 22:34:17 DEBUG Updating Device DC4F2288C4C7 Cool White Value Pairs
    Sep-13 22:34:17 DEBUG Updating Device Pot Light 3 Preset Value Pairs
    Current Date/Time: 9/16/2019 4:31:05 PM
    System Uptime: 0 Days 23 Hours 13 Minutes 23 Seconds
    IP Address: 127.0.0.1
    Number of Devices: 402
    Number of Events: 41
    Available Threads: 399
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    In Virtual Machine: No MFG: intel corporation
    Enabled Plug-Ins
    1.0.0.336: MagicHome
    2.19.0.4: MyZwaveTool
    3.0.1.262: Z-Wave
    In the magichome settings what do you have the type set to? If you are unable to set colours this is because the bulb type needs to be set to one of the bulb values. Try choosing just bulb. And then try and select a colour. Does that work? If it does then try selecting the white value. If that doesn't work try selecting bulb and cool white and try again.
      i am using v8 devices, first thing i would suspect is that for bulbs you should not be using anything with Cool white, as usually the cool white is created from the RGB all on. so if have this set you have the wrong number of bytes in the request. these IMHO should be set to bulb, then stop and restart the plugin and wait for discovery. then try again
        Thanks fuzzy, I will give that a try.
          So, it turns out that I have to initially set the option to "Preset Mode' once that is active, I was able to change the colours!!! Man this has been kicking my *** for the longest time. I did make sure that the device type is set to BULB only as well. Thanks dude. Now I can finally finish up my HS Touch design project.
          Also,on a side note: so anything that runs on the ESY controller I am able to use your plugin, correct?
            ESY controller? you will need to clarify, dont know what you mean?
              Sorry I meant ESP8266 controller!
