I have become involved with low cost IoT devices with MQTT being the primary means for non-cloud (or cloud) communication and integration. To make it easy to fit into my existing Homeseer environment I have developed mcsMQTT.
This plugin retains HS as the central node in the automation environment and allows MQTT-literate devices to be utilized. While HS Events can be triggered based upon MQTT Topics and Event Actions can publish Topics, the primary integration is with the HS DeviceValue and DeviceString. Changes in HS devices or changes in MQTT Topic payloads are seamlessless reflected with the mcsMQTT bridge.
Change Log
PR 1 12/20/2017 3.0.1.0 Add optional payload specification in MQTT event trigger
PR 2 12/20/2017 3.0.1.0 Define payload OPEN/CLOSE, ON/OFF Device-Status-Graphics pairs for DeviceValue 1/0, map these payloads to 1/0 DeviceValue updates
PR 3 12/20/2017 3.0.1.0 Honor "SET_DOES_NOT_CHANGE_LAST_CHANGE" device property checkbox when updating DeviceLastChange
PR 4 12/21/2017 3.0.1.1 Device Value and String changes not being reflected in new MQTT messages
PR 5 12/21/2017 3.0.1.2 Add debug focused around HSEvent processing
PR 6 12/22/2017 3.0.2.0 Provide bidirectional status and control in single HS3 device
PR 7 12/29/2017 3.0.3.0 JSON parsing of MQTT payload results in exception and log message
PR 8 12/29/2017 3.0.3.0 "A"ccept set true on initialization based upon presence of HS device with the associated Device Ref property
PR 9 12/29/2017 3.0.3.0 Backup of database created on each plugin start, backup retained for 6 months
PR10 1/3/2018 3.0.4.0 Add info to HS3 Device PED and synchronize with database
PR11 1/3/2018 3.0.4.0 Improve initial creation of database so restart is not needed
PR12 1/3/2018 3.0.4.1 Change HS3 connection from 192.168.0.194 to localhost
PR13 1/3/2018 3.0.4.2 Protect Topic from single and double quote in database operations
PR14 1/7/2018 3.0.4.3 Parsing error with training JSON } not removed
PR15 1/8/2018 3.0.4.4 Parsing error reversion, broke earlier correct parsing
PR16 1/9/2018 3.0.5.0 Add ability to specify arbitrary subscription topics
PR17 1/9/2018 3.0.6.0 Parsing exception ala PR7
PR18 1/9/2018 3.0.6.0 Provide Regular Expression replacement on Payload to Device
PR19 1/9/2018 3.0.6.1 Subscription does not include both $SYS and # Topics
PR20 1/10/2018 3.0.7.0 Provide Extract vs. Replace option on regular expressions
PR21 1/18/2018 3.0.7.1 Numbers in payload exceeding 2^32 generate an Int32 exception
PR22 2/14/2018 3.0.8.0 Provided the option to reduce traffic with subscription to only accepted topics
PR23 2/14/2018 3.0.8.0 Fixed broker authentication and used *** for password on setup page
PR24 2/20/2018 3.0.8.1 Settings other than default sometimes not remembered
PR25 2/26/2018 3.0.9.0 Add option to publish button label or button value
PR26 3/5/2018 3.0.9.1 Correct version number (3 to 4 digits) showing in HS log at startup
PR27 3/5/2018 3.0.9.1 Split Topic and JSON filter into two rows to reduce column width
PR28 3/5/2018 3.0.9.1 Fix Install.txt vs. install.txt to allow updater on Linux to work correctly
PR29 3/8/2018 3.0.9.2 Plugin not connecting to HS (hardcoded IP used for testing)
PR30 3/13/2018 3.0.9.3 HS3 device changes on Linux not being published as MQTT topics
PR31 3/13/2018 3.0.9.3 RegEx boxes removed for non-plugin devices
PR31 3/13/2018 3.0.9.3 Debug adjusted to assist with timing measurements
PR32 3/13/2018 3.0.9.4 HS3 source devices auto accepted on startup
PR33 3/14/2018 3.0.10.0 Streamline HS Event callback CPU use
PR34 3/14/2018 3.0.10.0 Add tool tips for hover on browser page
PR35 3/14/2018 3.0.10.0 Change QOS radio style to traditional rendering
PR36 3/14/2018 3.0.10.0 Allow user to select value/status/string on non-plugin device publishing
PR37 3/14/2018 3.0.10.0 Allow user to specify the non-plugin device topics being published
PR38 3/15/2018 3.0.10.1 Add protection for reading null database fields caused by adding new fields in 3.0.10.0
PR39 3/16/2018 3.1.0.0 Revamped UI to improve understandability
PR40 3/16/2018 3.1.0.0 Added manual topic entry/edit
PR41 3/16/2018 3.1.0.0 Added options to manage HS device enumeration and subscription display
PR42 3/16/2018 3.1.0.0 Improved startup timing and page build timing
PR43 3/18/2018 3.1.1.0 Dynamic updates of UI based upon user interaction
PR44 3/20/2018 3.1.2.0 Provided tabbed setup page
PR45 3/20/2018 3.1.2.0 Add retain default and topic-specific user input
PR46 3/20/2018 3.1.2.0 Add default QOS user input
PR47 3/20/2018 3.1.2.0 Add message and connection statistics
PR48 3/20/2018 3.1.2.0 Add LWT provisions
PR49 3/20/2018 3.1.2.0 Robust reconnection on dropped connection
PR50 3/20/2018 3.1.2.0 Removed dual purpose of all Association table columns
PR51 3/20/2018 3.1.2.0 Made 0 & 1 Payloads default to Button Off/On devices
PR52 3/21/2018 3.1.3.0 Add Broker Connection Event Trigger
PR53 3/21/2018 3.1.3.0 Add option to create individual mcsMQTT Status Devices in HS
PR54 3/23/2018 3.1.4.0 Add History retention with display filtering
PR55 3/25/2018 3.2.0.0 Completed bidirectional parent/child status relationships
PR56 3/25/2018 3.2.0.0 Color coded table rows to show plugin vs non-plugin rows
PR57 3/25/2018 3.2.0.0 Rebuilt database on initial startup of this version
PR58 3/25/2018 3.2.0.0 Added ability to specify command topics for existing HS devices
PR59 3/25/2018 3.2.0.0 Modified cosmetics for improved understandability
PR60 3/25/2018 3.2.0.0 Included both Sub and Pub topics in pulldown filters
PR61 3/25/2018 3.2.0.0 Added option to prefix with INFO/ or STAT/ (Tasmota convention)
PR62 3/25/2018 3.2.0.0 Added periodic status reporting option
PR63 3/25/2018 3.2.0.0 Removed PED contents and no longer maintain redundancy of data
PR64 3/26/2018 3.2.1.0 Added debug to Event Trigger setup
PR65 3/26/2018 3.2.1.0 Optimized trigger process for received messages
PR66 3/26/2018 3.2.1.0 Added Association filter based upon HS device categories
PR67 3/26/2018 3.2.1.1-3 Debug added to assist in understand disconnect from HS\
PR68 3/27/2018 3.2.2.0 Added receive queue to buffer incoming rates from HS processing rates
PR69 3/27/2018 3.2.2.0 Made JSON payload decoding optional
PR70 3/27/2018 3.2.2.1 Console writes inserted in each HS API call to help debug disconnect
PR71 3/28/2018 3.2.2.2 Postback error when Association Table requested
PR72 3/28/2018 3.2.3.0 Misc cleanup as devices are associated between manual and Assoc tabs
PR73 3/28/2018 3.2.3.0 Added ability to structure JSON devices as parent/child
PR74 3/28/2018 3.2.3.1 Association table does not appear unless browser previously open to mcsMQTT page
PR75 3/28/2018 3.2.3.1 Improved robustness of Association filters being updated as content changes
PR76 3/28/2018 3.2.3.1 Added purple row color for non-plugin devices mapped directly to MQTT topics
PR77 3/28/2018 3.2.4.0 Provided option for parent/child associations on JSON payloads
PR78 3/29/2018 3.2.5.0 Provided ability to display multiple mcsMQTT browser pages at the same time
PR79 3/29/2018 3.2.5.1 Additional debug around SetIOMulti, HSEvent, Triggers, and message reception & action
PR80 3/30/2018 3.2.5.2 RegEx stopped working with 3.5.0.0 (Replace pattern not retained)
PR81 3/30/2018 3.2.5.3 Disconnect flag true does not persist restarts
PR82 3/30/2018 3.2.5.3 Association filter not cleared when topics no longer present
PR83 3/30/2018 3.2.5.3 Subscription to no topics and no discovery causes .net error traps
PR84 3/30/2018 3.2.5.3 Database non-plugin devices are overwritten when an Accept is done ... need to go back to prior database
PR85 4/1/2018 3.2.6.0 Association table does not render unless a receive message has been accepted
PR86 4/1/2018 3.2.6.0 Concurrent thread protection added while topic and dictionaries are being modified
PR87 4/1/2018 3.2.6.0 Feedback provided on table size for larger tables when Show button is pressed
PR88 4/1/2018 3.2.6.0 Database fix only worked for the 3.1.x.x to 3.2.0.0. Not for subsequent 3.2.x.x.
PR89 4/1/2018 3.2.6.0 Protected Topic text in database should quote or single quote happen to be in Topic
PR90 4/1/2018 3.2.6.1 Added debug to isolate object missing message on Build Association Table
PR91 4/2/2018 3.2.7.0 Added special keyword 'change' in Payload of MQTT Receive Trigger to cause trigger on change of payload
PR92 4/2/2018 3.2.7.0 Changed behavior of SetDeviceValueByRef to always trigger rather than only triggering on a change of value
PR93 4/2/2018 3.2.7.1 Debug data file in DatamcsMQTT_Debug.txt rather than Data\mcsMQTT_Debug.txt
PR94 4/2/2018 3.2.7.1 Locate the data files in \Data\mcsMQTT rather than \Data
PR95 4/3.2018 3.2.8.0 Add page scroll buttons on Association tab and limit table size to 20 rows
PR96 4/3/2018 3.2.9.0 Increment DeviceValue if String Payload received and it changed the DeviceString
PR97 4/3/2018 3.2.9.1 Association Page number of rows availalbe is not shown on initial page rendering
PR98 4/3/2018 3.2.9.2 Use same color scheme of pink/green on history as is used on Association and Manual tabs
PR99 4/3/2018 3.2.9.2 Update Manual to 3.2.9 capability
PR100 4/3/2018 3.2.9.3 Duplicate debug files with second at parent directory folder
PR100 4/5/2018 3.2.10.0 Add Config Link to Plugin Page
PR102 4/5/2018 3.2.10.0 Add List Status/Control Type and generalize text to value mapping
PR103 4/6/2018 3.2.11.0 Added "H"istory checkbox on Association tab (and General tab) to select topic to be included in History collection
PR104 4/6/2018 3.2.11.0 Fixed "R"eject button not being accepted on Association tab. Broke in 3.2.5.0
PR105 4/6/2018 3.2.12.0 Updated concurrency (thread protection) logic to allow nested/multilevel protections
PR106 4/6/2018 3.2.12.0 Numeric payloads are being treated as VSP list enumeration
PR107 4/6/2018 3.2.12.0 Add Echo option on General Tab to allow published topics to be seen as subscriptions
PR108 4/7/2018 3.2.12.1 Fix Echo enable
PR109 4/7/2018 3.2.12.1 Improve auto VSP logic when devcie accepted from Association tab
PR110 4/7/2018 3.2.12.1 Provide compatibility with earlier versions of Mono on Linux
PR111 4/7/2018 3.2.12.2 Use default QOS rather than Exactly for Event Publish Actions
PR112 4/7/2018 3.2.12.2 Update manual to 3.2.12 capability
PR113 4/8/2018 3.2.13.0 Provided same page scrolling for History as Association tab to avoid browser overload
PR114 4/8/2018 3.2.13.2 Event MQTT Receive Trigger fails if same topic used in multiple events
PR115 4/9/2018 3.2.14.0 Added substitution variables for use in templates for published topic and payload formats
PR116 4/10/2018 3.2.14.1 Statistics Accept counts incorrect and no History records for accepted topics
PR117 4/10/2018 3.2.14.2 History date range does not default to valid range so filtered records to not show
PR118 4/11/2018 3.2.14.3 Error trap during MQTTSubscribe does not properly manage sync flags
PR119 4/11/2018 3.2.15.0 Allow entry of Broker port other than 1883
PR120 4/11/2018 3.2.15.1 Text Status/Control type creates VSP so even when DeviceString is set it does not appear
PR121 4/12/2018 3.2.16.0 First segment of substitution template not include in topic or payload
PR122 4/12/2018 3.2.16.0 Encode topic reserved symbols per HTML %## convention
PR123 4/12/2018 3.2.16.0 Added SSL support, testing limited to UI
PR124 4/12/2018 3.2.16.1 Forced On/Open=1, Off/Closed=2 when these payloads are available
PR125 4/12/2018 3.2.16.2 Manual tab entry of Ref number will populate either plugin or nonplugin table
PR126 4/13/2018 3.2.17.0 Compiled with .NET 4.5 vs. prior .NET 4.0
PR127 4/13/2018 3.2.17.0 Added table at top of Manual tab to allow user to select either Ref or Sub Topic
PR128 4/13/2018 3.2.18.0 Made List control/status UI only manual user select, Text is now default
PR129 4/13/2018 3.2.18.0 Added Color Picker as Control UI option
PR130 4/14/2018 3.2.19.0 Converted Association Ref to a button that will populate Manual Tab
PR131 4/15/2018 3.2.19.1 Prefix Color Picker publish RGB payload with # (e.g. #AAFF20)
PR132 4/15/2018 3.2.19.1 Remove debug output for Name and InterfaceStatus calls
PR133 4/16/2018 3.2.19.4 Additional debug during storing payloads in HS devices
PR134 4/17/2018 3.2.20.0 Added MISC properties as user-settable
PR135 4/17/2018 3.2.20.0 Cleared MISC NO-STATUS_DISPLAY for most UI's
PR136 4/17/2018 3.2.20.0 Assured Association & History filters are not masked by prior selection that are no longer availalbe
PR137 4/24/2018 3.3.0.0 Added Chart tab
PR138 4/24/2018 3.3.0.0 removed Label/Number radio for publish, now use payload template with $$value: to publish number
PR139 4/24/2018 3.3.0.0 removed string, status, value publish checkboxes, now use payload template
PR140 4/26/2018 3.3.0.1 corrected tool tip typos and added tool tip reference to the manual
PR141 4/26/2018 3.3.0.2 Added DISARMED/ARMED and OFFLINE/ONLINE as additional special case two-state pairs
PR142 4/26/2018 3.3.0.2 fixed button type when transitioning from number to button and no VSP have yet been recorded
PR143 4/29/2018 3.3.0.3 Changed Manual tab to Edit tab nomenclature
PR144 4/29/2018 3.3.0.3 Added text and figures to Section 10 of manual for tool tip reference
PR145 5/4/2018 3.3.1.0 Added popup window for edit of association properties
PR146 5/5/2018 3.3.2.0 Added HTTP request for chart build with querystring parameters
PR147 5/8/2018 3.3.3.0 Added chart definition and expanded options for chart appearance
PR148 5/8/2018 3.3.3.0 Added ability to popup chart by clicking Association tab payload
PR149 5/9/2018 3.3.3.1 Publish topics not appearing on chart topic selector
PR150 5/11/2018 3.3.4.0 Added Expressions, Filter, Derivative and Integral numeric transforms
PR151 5/12/2018 3.3.4.1 Publish from HS device control no longer works
PR152 5/12/2018 3.3.4.2 Added debug around browser postback
PR153 5/14/2018 3.3.5.0 Added Publication List tab
PR154 5/14/2018 3.3.5.1 Removed debug for WebPage and Register events
PR155 5/15/2018 3.3.6.0 Populate Non-plugin devices from database when Enumerate with button is selected
PR156 5/15/2018 3.3.6.0 Add Time base option for rate device
PR157 5/15/2018 3.3.6.0 Add Delta from midnight option for accum device
PR158 5/16/2018 3.3.6.1 Protection for divide by zero does not exist in rate calculation
PR159 5/17/2018 3.3.7.0 Substitution variables added to publication list file
PR160 5/17/2018 3.3.7.0 Manual updated for Irrigation Control with mcsTasmota firmware
PR170 5/18/2018 3.3.8.0 Added plugin link to mcsMQTT Doc
PR171 5/18/2018 3.3.8.0 Improved alignment of HTML pages to match size of tab canvas
PR172 5/19/2018 3.4.0.0 VSP Topics protected from special database characters in the database
PR173 5/19/2018 3.4.0.0 Improved reliability of filter pulldowns on Association tab
PR174 5/19/2018 3.4.0.0 Added charting for HS Device Values ... including mcsMQTT rate and accum devices
PR175 5/20/2018 3.4.0.2 VSP edit broke for case of deleting VSP entries
PR176 5/20/2018 3.4.0.3 Transform table topics protected from special characters in the database
PR177 5/20/2018 3.4.0.4 Protect from access of objects for chart before chart objects created
PR178 5/20/2018 3.4.1.0 Add delete button on Edit tab to remove obsolete topics and devices from database
PR179 5/31/2018 3.4.2.0 Encrypted broker passwords in mcsMQTT.ini
PR180 5/31/2018 3.4.2.0 New SSL implementation provided by vasrc
PR181 6/17/2018 3.4.2.1 Association filter for second JSON position does not appear, but still used in filter
PR182 6/19/2018 3.4.3.0 Add clear button on the pulldown filters
PR183 6/19/2018 3.4.3.0 Don't publish is subscribe topic is same as publish topic and subscribe message received within 15 seconds.
PR184 6/21/2018 3.4.3.1 Debug added around database operations
PR185 6/22/2018 3.4.3.2 Overcame issue with redundant records being stored in database
PR186 6/23/2018 3.4.3.3 Association and Edit tabs not properly synchronized for non-plugin device records
PR187 6/24/2018 3.4.3.4 Investigation for lack of published messages
PR188 6/24/2018 3.4.4.0 Add provisions for six levels of JSON in Topic and History select filters
PR189 6/25/2018 3.4.4.1 Update Payload/LastDate for subscriptions associated with non-plugin devices
PR190 6/25/2018 3.4.4.1 Fix Edit Page popups to show selected device properties
PR191 6/25/2018 3.4.4.1 Rename Device filter to Room/Floor and fix filter to return only selected records
PR192 6/25/2018 3.4.5.0 Provided RGB to Integer translation on subscription to allow HS device to reflect selected color
PR193 6/25/2018 3.4.5.0 Added ability to use arithmetic and regular expressions on received payloads for non-plugin devices
PR194 6/26/2018 3.4.5.1 Changed colorization on Edit tab for subscribed non-plugin devices to match Association tab
PR195 6/26/2018 3.4.5.1 Added Rebuild buttons to Filters and removed some auto rebuild to improve performance
PR196 6/27/2018 3.4.5.2 JSON parsing fixed for cases of more than two levels of nesting (Tasmota 1-wire sensors)
PR197 6/27/2018 3.4.5.2 Color picker RGB to Integer order reversed and debug added to HS save of RGB value
PR198 6/27/2018 3.4.5.2 Cleanup of non-plugin device mapped to MQTT subscription
PR199 7/6/2018 3.4.6.0 Replace use of GNUPlot for Linux with .NET datavisualization
PR200 8/6/2018 3.4.6.1 Unable to save second axis selection on Chart setup
PR201 8/22/2018 3.4.6.2 Retain flag hard-coded false for event action messages
PR202 8/27/2018 3.4.7.0 Include Regular and Numeric expressions in chart data
PR203 9/3/2018 3.4.7.1 Only one of duplicate event triggers result in HS event trigger
PR204 9/9/2018 3.4.8.0 Event action substitution variables cause log error
PR205 9/9/2018 3.4.8.0 Protect HSEvent from non-numeric device reference parameter from HS
PR206 9/9/2018 3.4.8.0 Event action substitution Value/String/Status can use any of Reference/Address/Code
PR207 9/10/2018 3.4.8.1 Eliminate DeviceStatus extraction on HSEvent callbacks
PR208 9/11/2018 3.4.9.0 Topics published for HS devices that have not been selected
PR209 9/11/2018 3.4.9.0 Add user selection of DeviceValue vs. DeviceString change trigger to publish
PR210 9/11/2018 3.4.9.0 Add visualizations for sort direction and field
PR211 9/26/2018 3.4.10.0 Add user-defined device grouping for improved Device Management display
PR212 10/7/2018 3.4.11.0 Assure VSP display below chart page is shown in sorted numeric order
PR213 10/7/2018 3.4.11.0 Changed MQTT Client ID to be more recognizable as "mcsMQTT on " host name
PR214 10/20/2018 3.4.11.1 Charting of JSON data which was not always being handled properly
PR215 11/7/2018 3.4.11.2 Copied events do not maintain uniqueness
PR216 11/11/2018 3.4.12.0 Publish on receive topic if no transmit topic is entered
PR217 11/27/2018 3.4.13.0 Add TRUE and FALSE as special case payloads for button typing
PR218 11/27/2018 3.4.13.0 Add Wildcard subscription topic template for auto-association with existing HS devices
PR219 11/28/2018 3.4.14.0 Expand Wildcard topic template to all substitution patterns rather than only $$REF:
PR220 11/28/2018 3.4.14.1 Multiple substitutions in wildcard template fail
PR221 11/29/2018 3.4.15.0 Provide option to not HTML-encode space in published topics
PR222 11/30/2018 3.4.16.0 Add option to auto create associations for all HS devices
PR223 12/2/2018 3.4.16.1 Remove workaround that replaced HS CAPI label with plugin-defined VGP
PR224 12/4/2018 3.4.16.3 Non-plugin devices deleted when subscribe topic assigned to two non-plugin devices
PR225 12/6/2016 3.4.16.4 Use UTF8 rather than ASCII encoding for received payloads to accommodate special characters
PR226 12/16/2018 3.4.17.0 XY to RGB color support for lighting
PR227 12/30/2018 3.4.17.1 Publish payload with quote shows us as ^2 after plugin restart
PR228 1/6/2019 3.4.17.2 Additional debug around database operations
PR229 1/7/2019 3.4.17.3 Statistics devices are recreated on each startup when general tab has these selected to be created
PR230 1/10/2019 3.4.17.4 Align new device buttons from left to right in numeric button value
PR231 1/16/2019 3.4.18.1 Provide "_URL_ENCODE" suffix for substitution variables applicable to publish payload templates
PR232 1/20/2018 3.4.18.2 Change "URL_ENCODE" to "URI_ENCODE" and use system.URI rather than webutility in .NET for encoding.
PR233 1/23/2019 3.4.19.0 Added Inactive and Active as predefined payload to create button pairs
PR234 1/23/2019 3.4.19.0 Added 24 icons for LED IR keypad mapping
PR235 1/23/2019 3.4.19.0 VGP definitions are not changed after initial creation to protect subsequent user edits
PR236 1/28/2019 3.4.19.1 MISC edits on Edit tab are not reflected in HS devices if not done from the Edit popup
PR237 1/29/2019 3.4.19.2 Subscribe Topic / Device Ref associations cannot be edited so map Edit subscribe Topic display only
PR238 2/4/2019 3.4.20.0 Added scripting callback on selective received topics
PR239 2/4/2019 3.4.20.1 Fixed handling of non-plugin subscription topics
PR240 2/4/2019 3.4.20.2 Selecting existing non-plugin ref results in crash when non-plugin device status updated
PR241 2/7/2019 3.4.20.3 Added wildcard recognition & optimizations per YoYo for script callback
PR242 2/16/2019 3.5.1.0 Added Express mode to provide low-overhead means to update Device from MQTT
PR243 2/16/2019 3.5.1.0 Added ability to change Topic to Device relationships without creating new Device
PR244 2/16/2019 3.5.1.0 Added ability to remove obsolete topics from database and tables
PR245 2/17/2019 3.5.2.0 Restored the Reject column checkboxes that were removed in 3.5.1.0
PR246 2/17/2019 3.5.2.0 Added ability to update non-plugin devices in Express mode
PR247 2/17/2019 3.5.3.0 Added Log as a HS callback option on Edit tab to enable publish without Device change
PR248 2/20/2019 3.5.4.0 Added features to reduce limitations of Express mode
PR249 2/21/2019 3.5.5.0 Significant improvement in CPU utilization by altering use of HS device object
PR250 2/23/2019 3.5.6.0 Control buttons in HS GUI are not generated when a Button type device is associated
PR251 2/23/2019 3.5.6.0 When a device is un-associated the device is not deleted from HS
PR252 2/23/2019 3.5.6.0 Provide means to substitute underscore for space in published topics rather than URI encoding
PR253 3/15/2019 3.5.6.1 Default for Express mode selected whenever Ref button is clicked
PR254 3/15/2019 3.5.6.1 Delete obsolete does not work correctly unless plugin has been restarted
PR255 3/16/2019 3.5.7.0 Delete Sub and Ref button on edit tab does not delete parent device if it exists
PR256 3/16/2019 3.5.7.0 Group all statistic devices in HS and provide control on parent to update/not update devices
PR257 3/16/2018 3.5.7.0 Improve the relationship of Express Mode and Parent/Child groupings
PR258 3/16/2018 3.5.7.0 Allow user to edit the mcsMQTT Client ID
PR259 3/16/2019 3.5.7.0 Removed the DeviceValue increment on the Parent device for each message received
PR260 3/22/2019 3.6.0.0 Added VSP Clear button and allowed VSP entry for all values on single text box entry
PR261 3/22/2019 3.6.0.0 Added ability to associate multiple topics to single HS device
PR262 3/22/2019 3.6.0.0 Added Topic summary row with indented JSON payload elements
PR263 3/22/2019 3.6.0.0 Express checkbox only enabled on Topic rows and JSON rows slaved to Topic row
PR264 3/22/2019 3.6.0.0 Added Technology Address update based upon MQTT Topic
PR265 3/22/2019 3.6.0.0 Added Association tab Obsolete column checkbox
PR266 3/22/2019 3.6.0.0 Added ability to hide Obsolete, Reject, History and Device checkboxes on Association tab
PR267 3/24/2019 3.6.1.0 Payload value rather than Payload template provided in Edit tab initial value for template
PR268 3/24/2019 3.6.1.0 Made obsolete checkbox wait for Delete Marked button click before removing the records
PR269 3/26/2019 3.6.1.1 Non-plugin devices not appearing on Association tab
PR270 3/28/2019 3.6.1.2 Fixed JSON parsing for case when JSON syntax embedded within quotes
PR271 3/28/2019 3.6.1.2 Expanded JSON decoding to handle list of JSON elements
PR272 3/29/2019 3.6.1.3 Handle comma in number payload rather than as JSON item separator
PR273 3/29/2019 3.6.1.3 Allow leading white space in JSON payloads
PR274 3/30/2019 3.6.1.4 Regular Expressions only working in Express mode
PR275 4/1/2019 3.6.1.5 Show received payload rather than regex payload in Express mode
PR276 4/10/2019 3.6.2.0 Added unix_time and unit_date expression functions
PR277 4/10/2019 3.6.2.0 Enabled use of expressions for text formatting
PR278 5/19/2019 4.0.0.0 Added Bluetooth Low Energy Scanner Function with ESP32
PR279 6/6/2019 4.0.1.0 Added NumberChange Control/Status UI type
PR280 6/7/2019 4.0.1.1 Execute low pass filter before numeric expression
PR281 6/7/2019 4.0.2.0 Control brightness from color picker for ColorXY type
PR282 6/7/2019 4.0.2.0 Changed color space model of XY to RGB translation
PR283 6/7/2019 4.0.2.0 Resend ColorXY type commands 2 seconds after the first to assure device reports final status
PR284 6/7/2019 4.0.2.0 No longer require ColorXY to have a Associated parent in HS
PR285 6/7/2019 4.0.2.0 HS parent of MQTT topics no longer hold JSON payload, but have empty DeviceString
PR286 6/7/2019 4.0.2.0 Express mode set when device Accepted if express is default, but now follows root device express mode setting
PR287 6/8/2019 4.0..2.1 ColorXY brightness command range changed from percentage to 8 bit range
PR288 6/12/2019 4.0.2.2 Non-plugin associations do not initialize numeric expressions on startup
PR289 6/12/2019 4.0.3.0 Add ability to add expressions to publish template with << and >> encasing
PR290 7/6/2019 4.0.3.1 Optimize shutdown by saving to database only that which has changed
PR291 7/7/2019 4.0.3.2 Plugin did not shutdown after connection with HS was dropped
PR292 7/19/2019 4.1.0.0 Add Led Messaging Sign
PR293 7/22/2019 4.1.0.1 Assure HTML stripped to Sign when using MQTT Send Message event
PR294 7/25/2019 4.1.0.2 Tolerate spaces after colon separator in JSON payloads
PR295 7/29/2019 4.1.1.0 Added plugin version in header of MQTT Management on General tab
PR296 8/4/2019 4.1.2.0 Changed embedded color delimeter from <> to [ ] for messaging sign
PR297 8/4/2019 4.1.2.0 Provisions to support multiple messaging signs
PR298 8/7/2019 4.1.2.1 Added debug to Event Actions
PR299 8/9/2019 4.1.2.2 Clear DeviceString when Control/Status selection changes from Text
PR300 8/16/2019 4.1.2.3 Event action substitution variables broke
PR301 8/17/2019 4.1.3.0 Added $$LABEL: substitution variable for CAPI labels
PR302 8/17/2019 4.1.4.0 Added $$VSP: substitution variable to lookup mcsMQTT VSP text using HS device value
PR303 8/22/2019 4.1.5.0 Added MQTT trigger topics to subscription list used when discovery is not enabled
PR304 9/10/2019 4.1.6.0 Added $$DATE: and $$TIME: for short format in event action
PR305 9/12/2019 4.1.6.1 Fixed $$DATE or $$TIME being at end of event action
PR306 9/14/2019 4.1.7.0 Added capability to support multiple brokers
PR307 9/15/2019 4.1.7.1 MQTT connect event trigger missing broker selection for multiple brokers
PR308 9/21/2019 4.1.7.2 Init to plugin child device when no info in database and ref property is -1
PR309 9/21/2019 4.1.7.2 Allow additional brokers to be added without restarting plugin
PR310 9/21/2019 4.1.7.2 Broker username not initialized from mcsMQTT.ini
PR311 9/25/2019 4.1.7.3 Edit popup for parent association and VSP entries dont initially populate correctly
PR312 9/25/2019 4.1.7.3 Change parent association does not remove the prior parent's association with child
PR313 9/27/2019 4.1.8.0 Added ability to record changes of MQTT device updates in HS Log
PR314 10/12/2019 4.2.0.0 Added BLE tab for distance from scanner graphics of BLE beacons
PR315 10/18/2019 4.2.0.2 Exception not trapped in broker connection loop
PR316 10/18/2019 4.2.1.0 Added CSV Control/Status UI type
PR317 10/19/2019 4.2.2.0 Added HSB Control/Status UI type
PR318 10/21/2019 4.2.3.0 Continue trying to make broker connection if exception in MQTT thread
PR319 10/21/2019 4.2.3.0 Corrrect HSB to RGB conversion rounding errors
PR320 10/21/2019 4.2.3.0 Provide broker-independent statistics devices
PR321 10/24/2019 4.2.3.1 Protect from error when inner.exeception is null
PR322 11/27/2019 4.2.4.0 Added user entry of LWT topic on General tab
PR323 12/9/2019 4.2.5.0 Add ability to specify multiple pub topics for CSV Control/Status types
PR324 12/11/2019 4.2.6.0 Added slider controls for HSB type and made CSV controls number boxes
PR325 12/12/2019 4.2.6.1 Script callbacks cannot be registered in Linux
PR326 12/14/2019 4.2.6.2 ColorHSB control publishes wrong topic
PR327 12/21/2019 5.0.0.0 Incorporated internal MQTT Broker
PR328 12/21/2019 5.0.0.0 Added TCP Tab and control of 8 Channel Relay/Input IP module
PR329 12/27/2019 5.0.0.1 VSP not cleared when control buttons added. Control use also not set.
PR329 12/31/2019 5.0.1.0 Enhanced VSP edit to allow HS Status display to be specified
PR330 12/31/2019 5.0.1.0 List type values now automatically update existing VSP definitions in HS device
PR331 1/2/2020 5.0.1.1 Reformat Edit tab VSP listing for ease of cut/paste
PR332 1/2/2020 5.0.1.1 Change inactive page timeout from 5 minutes to 15 minutes
PR333 1/3/2020 5.0.2.0 Accept JSON keys that are not encased in quotes
PR334 1/8/2020 5.0.2.1 Separate IP Relay command execution into an independent thread
PR335 1/10/2020 5.0.2.2 Non-plugin expressions not initialized until plugin restart
PR336 1/11/2020 5.0.3.0 Added $$TASMOTACMND: as a substitution variable
PR337 1/11/2020 5.0.3.0 Non-blank topic template will cause "A" checkbox to create publish topic
PR338 1/11/2020 5.0.3.0 Added wildcard template for auto-association with HS devices
PR339 1/12/2020 5.0.4.0 Added ability to specify subscription template
PR340 1/12/2020 5.0.4.- Added ability to edit for Edit tab the Floor and Room
PR341 1/12/2020 5.0.4.0 Added ability to select Topic vs. static default room and floor
PR342 1/14/2020 5.0.4.1 VSP entries do not enumerate correctly when one has been deleted
PR343 1/14/2020 5.0.4.1 Changed behavior of Clear VSP button to not change Type to Text when Button or List
PR344 1/15/2020 5.0.4.2 Change room and floor selection from text box to drop down list
PR345 1/23/2020 5.0.5.0 Added ability to use JSON payload key-value as unique identifier
PR346 1/25/2020 5.0.6.0 Added ability to have multiple payload key-value identifiers for same topic
PR347 1/25/2020 5.0.6.0 Changed ajax refresh rate from 2 seconds to 1 second for improved responsiveness
PR348 1/25/2020 5.0.6.0 Changed sequence number hyperlink to not automatically create HS device
PR349 1/30/2020 5.1.0.0 Use of shared dll with mcsShelly
PR350 1/30/2020 5.1.1.1 Edit Action in HS aborts plugin
PR351 1/31/2020 5.1.1.1 Deserialization errors in HS log on startup
PR352 2/1/2020 5.1.1.2 Duplicate key error on some association sorts
PR353 2/5/2020 5.1.1.3 Optimization of use of dictionary to use TryGet rather than Contains followed by Item
PR354 2/5/2020 5.1.1.3 Floor and Room list retained in mcsMQTT.ini after lastest HS device enumeration
PR355 2/5/2020 5.1.1.3 Added auto recognition of WLED topic for HS device creation
PR356 2/9/20220 5.1.1.4 Cleanup of control of Shelly RGB2
PR357 2/9/2020 5.1.1.4 Data not stored to history database if only accepted selected for history
PR358 2/12/2015 5.1.1.7 Action and Trigger text missing when created before version 5.1
PR359 2/12/2015 5.1.1.7 Startup failure and retries under Linux since version 5.1
PR360 2/14/2020 5.1.2.0 Added HomeAssistant Discovery for disclosures provided by Tasmota
PR361 2/17/2020 5.1.3.0 Added HomeAssistant Discovery for disclosures provided by ESPHome
PR362 2/17/2020 5.1.3.0 Add Control/Status type of RGBW
PR363 2/17/2020 5.1.3.0 Added logic to correct HS creating Control rather than Both for List type
PR364 2/17/2020 5.1.3.0 Made URI encoding on a message by message basis (from Edit tab)
PR365 2/18/2020 5.1.4.0 Added homesassistant discovery for messages sourced by HS/mcsMQTT
PR366 2/20/2020 5.1.4.1 Added HS log message for MQTT Actions being executed
PR367 2/27/2020 5.2.0.0 Added Daikin mini-split interface on TCP page
PR368 2/28/2020 5.2.0.1 Changing payloads on same topic between JSON and non-JSON breaks parsing.
PR369 2/29/2020 5.2.0.2 KNX publish topic automatically populated
PR370 2/29/2020 5.2.0.2 KNX subscribe topic reformatted for better HS integration
PR371 2/29/2020 5.2.0.2 Force creation of parent topic/devices for better HS4 transition
PR372 3/20/2020 5.2.1.0 Added ramp rate device for Shelly devices that have brightness controls
PR373 3/22/2020 5.2.1.3 Filter shellies/../announce/../status topics as these prevent proper device creation
PR374 3/24/2020 5.2.1.4 Added input to shelly dimmer and made available longpush and timer in association tab
PR375 3/26/2020 5.2.1.5 Updates stopped because of database for ElevateKeys created as int and not string
PR376 3/27/2020 5.2.1.6 Test HomeAssistant discovery for Zigbee2MQTT and adjust for it's quirks
PR377 3/28/2019 5.2.1.7 Change Daikin control from POST to GET
PR378 3/28/2019 5.2.1.8 Add debug for chart filename creation and display
PR379 3/28/2019 5.2.1.9 Cleanup TCP Relay setup page for proper removal of unit/row
PR380 3/31/2020 5.2.1.10 Non plugin device setup not being saved to database
PR381 3/31/2020 5.2.1.11 Change chart filenames and delete older than 1 week on restart
PR382 4/1/2020 5.2.1.12 Daikin iteration update
PR383 4/2/2020 5.2.1.13 Daikin iteration update
PR384 4/3/2020 5.2.1.14 Daikiin update for update of HS devices and Fan Quiet/Auto modes
PR385 4/3/2020 5.2.2.0 Added replacement variable $$LASTCHANGE:
PR386 4/3/2020 5.2.3.0 Moved HomeAssistant discovery publish to General Tab Outbound
PR387 4/3/2020 5.2.3.2 Ignore Daikin temp/humidity reports of "--"
PR387 4/3/2020 5.2.3.2 Init Daikin state from HS devices to handle startup reporting of "--"
PR388 4/5/2020 5.2.3.3 Command topics from non-plugin devices not being saved
PR389 4/5/2020 5.2.3.3 Resubscribe when command topic changes when subscribed to specific topics
PR390 4/6/2020 5.2.4.0 Fixed plugin lockup when subscribe wildcard template used
PR391 4/6/2020 5.2.4.0 Provided separate subscribe templates for each broker
PR392 4/6/2020 5.2.4.0 Add checkbox to disable auto device creation on special topics
PR393 4/7/2020 5.2.4.1 URI encode checkbox on Edit tab was stuck at no-encoding
PR394 4/8/2020 5.2.4.3 Express mode trigger checkbox would not stick on restart
PR395 4/12/2020 5.2.4.5 Stop internal broker when external one selected, start when external deselected
PR396 4/12/2020 5.2.4.5 Parent creation with multiple hierarchy topics have issues
PR397 4/13/2020 5.2.4.6 Button and Sign types disable graphics display
PR398 4/13/2020 5.2.4.7 Added feedback heartbeat and restart to internal broker
PR399 4/13/2020 5.2.4.8 Changed broker monitor timeout from 1 to 3 missed heartbeats
PR400 4/14/2020 5.2.4.9 Statistic tab always shows TOPIC for the last published topic
PR401 4/18/2020 5.2.4.10 Topics without "/" give array bounds error when controlling
PR402 4/18/2020 5.2.4.11 Technology Address restored to full topic except special case topics
PR403 4/22/2020 5.2.4.12 Replace database period in date with colon for time delimiter
PR404 4/23/2020 5.2.4.13 Fix parsing of auto associate template
PR405 4/23/2020 5.2.4.13 Grouping update to delete parent when new parent defined on Edit tab
PR406 5/1/2020 5.2.5.0 Added polling input for the Shelly RGBW2
PR407 5/1/2020 5.2.5.0 Added expressions to event action payloads
PR408 5/3/2020 5.2.5.1 Check if new Shelly endpoints should be created
PR409 5/4/2020 5.2.6.0 Added substitution variables $$DEVICETYPE: and $$DEVICESUBTYPE:
PR410 5/19/2020 5.2.6.0 Added delete function for chart setup
PR411 5/19/2020 5.2.7.0 Chart axis sync not functional
PR412 5/20/2020 5.2.7.1 Chart axis sync setting not restored on chart setup load
PR413 5/21/2020 5.2.7.2 RGB color picker is not updating for non-numeric hex colors
PR414 5/23/2020 5.2.7.3 Publish topics of length under 7 characters do not work
PR415 5/23/2020 5.2.8.0 Added WLED Segment support
PR416 5/26/2020 5.2.8.1 WLED cleanup
PR417 5/28/2020 5.2.9.0 Remove General Tab, Inbound Management JSON options for HS4 compaitbility
PR418 6/3/2020 5,2.9.1 HSB Color parent child relationships not maintained
PR419 6/6/2020 5.2.9.2 Sliders for HSB devices do not publish
PR420 6/7/2020 5.2.9.3 WLED color control of entire strip broke when segments added in 5.2.8.0
PR421 6/12/2020 5.2.9.4 Change of QOS overwrites the publish topic
PR422 6/14/2020 5.2.9.5 Improve handling of multiple broker setup
PR423 6/15/2020 5.2.9.6 Broker password encryption fails with multiple brokers
PR424 6/20/2020 5.3.0.0 Added Rate Control/Status UI type
PR425 6/20/2020 5.3.0.0 Made event substitution variables available for general expressions (e.g. $$DVR)
PR426 6/20/2020 5.3.0.0 Separated mcsMQTT and mcsShelly folders and URLs to allow both to run together
PR427 6/21/2020 5.3.0.1 Some topics being commanded as wled segments
PR428 6/22/2020 5.3.0.3 Changed order so all substitutions occur before evaluation in expression
PR429 6/22/2020 5.3.0.4 Sync version numbers between HS3 and HS4 plugins ..... in Updater
PR430 6/25/2020 5.3.1.0 Added PowerMode and Streamer to Daikin mini-split
PR431 6/25/2020 5.3.2.0 Added $$VALUE_EUROPE: replacement variable for comma to period translation
PR432 6/25/2020 5.3.3.0 Added Device Name on Edit tab as part of Location entries
PR433 6/25/2020 5.3.3.1 Daikin special mode values need 1 parameter value
PR434 6/25/2020 5.3.3.2 Daikin normal mode needs to have a kind=1 parameter
PR435 6/25/2020 5.3.3.2 Update HS devices following OK response on command
PR436 6/27/2020 5.3.3.4 Correct Daiken parsing of returned power mode status
PR437 6/29/2020 5.3.3.5 Heartbeat not subscribed when not subscribing to everything (#)
PR438 6/29/2020 5.3.3.5 Internal broker restart fails because port 1883 not freed up
PR439 7/1/2020 5.3.4.0 Added Shelly i3
PR440 7/1/2020 5.3.4.0. Added Shelly Duo
PR441 7/1/2020 5.3.4.0 Added Shelly 3EM
PR442 7/1/2020 5.3.4.0 Added Shelly Button1
PR443 7/1/2020 5.3.4.0 Added Shelly Vintage
PR444 7/3/2020 5.3.4.6 Handle decimal character (. vs ,) for inbound expressions
PR445 7/5/2020 5.3.4.7 Charting only honoring RegEx and Expression on JSON payloads
PR446 7/5/2020 5.3.5.0 Added Shelly Door-Window
PR447 7/8/2020 5.3.5.2 Payload template with colon truncates data in template
PR448 7/9/2020 5.3.5.3 Fixed conversion to upper case in version 5.3.5.2
PR449 7/9/2020 5.4.0.0 Decoupled MQTT initialization from plug-in startup
PR450 7/10/2020 5.4.0.1 Statistics devices incorrectly created and show duplicate in HS4
PR451 7/10/2020 5.4.0.2 127.0.0.1 is treated as internal broker
PR452 7/11/2020 5.4.0.3 IP Relay does not control when no MQTT broker selected
PR453 7/11/2020 5.4.0.3 Autocreate IP Relay parent and child devices
PR454 7/12/2020 5.4.0.4 Link to mcsShelly manual is broken
PR455 7/12/2020 5.4.0.4 Status of IP Relays not reflected in HS
PR456 7/15/2020 5.4.0.5 Reduce shutdown time
PR457 7/23/2020 5.4.0.6 Statistic devices incorrectly named "not-accepted" topic and payload
PR458 7/24/2020 5.4.0.7 Statistics devices are not updating
PR459 8/8/2020 5.5.0.0 Added support for Serial and IP/Serial devices
PR460 8/14/2020 5.5.1.0 Added Tasmota flavor of color temperature to HA discovery
PR461 8/14/2020 5.5.1.0 Enable autodiscovery checkbox not functional
PR462 8/14/2020 5.5.1.0 + sign replaced by space in text box entry in HS4
PR463 8/16/2020 5.5.1.4 Various cleanup in HomeAssistant Discovery for Tasmota ... In Updater
PR464 8/21/2020 5.5.1.5 Fix subscribe to only associated that was broken in 5.3.3.5
PR465 8/21/2020 5.5.1.5 Consolidated HomeAssistant Discovery into single parent
PR466 9/8/2020 5.5.1.7 Serial port status not correct when opening port
PR467 9/12/2020 5.5.1.8 Multiple topics into same HS device not sticking
PR468 9/12/2020 5.5.1.8 DVR and other similar replacement variables not parsed correctly
PR469 9/12/2020 5.5.1.8 Status-only numbers did not have number range setup in HS4
PR470 9/14/2020 5.5.2.0 Change nomenclature from Floor Room to Loc2 Loc ... In Updater
PR471 9/17/2020 5.5.2.1 Subscribe to wildcard template aborts the plugin
PR472 9/25/2020 5.5.3.0 Added Event conditions to HS4 version only
PR473 9/25/2020 5.5.3.0 Enabled all substitution variables in Event Actions
PR473 9/25/2020 5.5.3.0 Added SRound in expressions for Number to String conversion
PR474 9/25/2020 5.5.3.0 Change Chr to Char in expression (Chr yields stack overflow)
PR475 9/25/2020 5.5.3.0 Added ValueSet to ValueChange for device change callback
PR476 9/26/2020 5.5.3.1 HTML in text boxes is not HTML-encoded for HS4
PR477 9/27/2020 5.5.3.2 Auto-replace number decimal to match regional settings
PR478 9/27/2020 5.5.3.2 Added Event conditions for HS3
PR479 9/29/2020 5.5.3.4 Automatically recognize regional settings for numeric decimals
PR480 9/29/2020 5.5.3.4 VSP not being setup for Buttons
PR481 9/29/2020 5.5.3.4 Automatically change DeviceString vs. DeviceValue setting on Contorl/Status UI change
PR482 9/29/2020 5.5.3.4 Use gear icon as the default status graphic icon
PR483 9/29/2020 5.5.3.5 Unable to select Extract on RegEx for HS4
PR484 10/4/2020 5.5.3.7 Unable to send device changes to HS log
PR485 10/5/2020 5.5.3.9 Accum device for delta since midnight does not work
PR486 10/13/2020 5.5.3.10 Upper case required on replacement variables in payload template
PR487 10/13/2020 5.5.3.10 CAPI control for SelectList returns wrong label (workaround HS bug)
PR488 10/15/2020 5.6.0.0 LastChange property update honors MISC LastChange property setting
PR489 10/15/2020 5.6.0.0 Debug now creates backup on each restart
PR490 10/15/2020 5.6.0.0 CAPI control on HS4 only working with range VSP
PR491 10/16/2020 5.6.0.0 Added RGB expression function to convert from decimal to RRGGBB
PR492 10/16/2020 5.6.0.1 Non-plugin device control from MQTT message does not work
PR493 10/18/2020 5.6.0.2 Explicitly manage LastChange based upon MISC LastChange property
PR494 10/19/2020 5.6.1 0 Added timeout input for Bluetooth beacon
PR495 10/19/2020 5.6.1.0 Change MISC property default to include Set does not change LastChange
PR496 10/19/2020 5.6.1.0 Added four scripting methods to edit mcsMQTT topic properties
PR497 10/20/2020 5.6.1.1 Scripting edit does not handle multiple topics mapped to same HS Ref
PR498 10/21/2020 5.6.2.0 Add Reject Topic template
PR499 10/22/2020 5.6.3.0 Added transform properties to scripting edit capability ... In Updater
PR500 10/25/2020 5.6.3.1 Format broker connect time in days, hours, mins, secs
PR501 10/25/2020 5.6.3.2 Chart does not process expressions correctly
PR502 10/26/2020 5.6.3.3 Second Y axis scaling setup is ignored
PR503 10/30/2020 5.6.3.4 Default room and floor swapped on new device creation
PR504 10/30/2020 5.6.3.5 Autocreate new HS mcsMQTT device if missing on startup
PR505 11/1/2020 5.6.4.0 Underscores displayed for device names that have spaces
PR506 11/1/2020 5.6.4.0 URI encoding setting on Edit tab for non-plugin devices generates error
PR507 11/1/2020 5.6.4.0 Added option on General tab to assign a static Device reference for new Features
PR508 11/1/2020 5.6.4.0 Changed from PED to mcsMQTT database for CSV, HSB and similar Status/Control UI types
PR509 11/1/2020 5.6.4.0 Added Beacon option to store in-range vs. out-of-range rather than RSSI value
PR510 11/1/2020 5.6.4.0 Only update Beacon device with the Device Value will change
PR511 11/6/2020 5.6.4.1 Auto create device setting cannot be turned off for shellies topic
PR512 11/6/2020 5.6.4.1 Confusion on parent device for topics like relay/0 and relay/0/energy where relay/0 is both child and parent
PR513 11/7/2020 5.6.4.2 Initialize beacon last report time based upon HS status at startup
PR514 11/8/2020 5.7.0.0 Add provision to store into HS energy database
PR515 11/8/2020 5.7.0.0 Add $$PAYLOADTopic): substitution variable
PR516 11/9/2020 5.7.0.2 Revise handling of energy data in HS database
PR517 11/9/2020 5.7.0.2 extra /g and /c topics listed on Association tab for WLED
PR518 11/10/2020 5.7.0.3 dvRef not stored in energy database, device not selectable on energy page
PR519 11/11/2020 5.7.0.4 allow expressions for VSP payloads in buttons and lists
PR520 11/11/2020 5.7.0.7 fix regressions caused by expressions in text, number and button types
PR521 11/14/2020 5.7.0.8 Internal broker restarts when not subscribing to all topics
PR522 11/14/2020 5.7.0.9 Fixes for storage into HS energy database
PR523 11/14/2020 5.8.0.0 Add Daikin with WMP protocol
PR524 11/14/2020 5.8.0.0 Button expressions always return -1 or 0
PR525 11/17/2020 5.9.0.0 Updates to WMP to address initial integration findings
PR526 11/17/2020 5.9.0.0 Added provisions for multiple types of controls/topics on single HS feature
PR527 11/17/2020 5.9.0.1 Fixed HSB control from HS slider and color picker for HS4
PR528 11/17/2020 5.9.0.1 Fixed unassociation of HSB topic not deleting all HS features
PR529 11/18/2020 5.9.1.0 Added ability to have status and control for shutter in single feature
PR530 11/19/2020 5.9.2.0 Added Toggle Control/Status UI type (to support shutter vs dimmer)
PR531 11/19/2020 5.9.3.0 Added * wildcard for obsolete topic removal so partial segments can be specified
PR532 11/19/2020 5.9.3.1 Added Slider control to shutter setup
PR533 11/20/2020 5.9.3.2 Merged 5.8 and 5.9 changes into HS3 plugin, cross-check updates
PR534 11/23/2020 5.9.3.6 Revise JSON key elevation to topic
PR535 11/24/2020 5.9.4.0 Add Shelly Door Window version 2
PR536 11/25/2020 5.9.4.1 Plugin restart needed for new HS4 triggers to be recognized
PR537 11/25/2020 5.9.4.1 Error in HS4 log when trying to put icon on a Device
PR538 11/27/2020 5.9.5.0 Allow beacon parameters to be edited for each beacon
PR539 11/27/2020 5.9.5.1 Sliders are not being updated
PR540 11/28/2020 5.9.5.2 Restore regional setting consideration to original technique
PR541 11/28/2020 5.9.5.3 Charts are not being displayed with null string to double error on page
PR542 11/28/2020 5.9.5.4 Restore two pass initialization to improve init time
PR543 11/29/2020 5.9.5.5 Elevated topics do no show on charts
PR544 11/29/2020 5.9.5.5 Out of memory error when charting 100,000's of records (use sub-sampling)
PR545 11/30/2020 5.9.6.0 Add MqttReceiveMessage to simulate MQTT message reception
PR546 12/1/2020 5.9.7.0 Add $$TIMEL: and ##DATEL: for long format date and time
PR547 12/1/2020 5.9.7.0 Use globalization namespace to identify decimal character
PR548 12/3/2020 5.9.7.1 Phantom parent devices created
PR549 12/4/2020 5.10.0.0 Added Linux BLE Beacon support for HS4
PR550 12/5/2020 5.10.2.0 Publish status of a device if status topic received with a null payload
PR551 12/5/2020 5.10.2.1 HS Event Trigger callbacks cannot be selected on HS4
PR552 12/6/2020 5.10.3.0 Add status response to query with null payload
PR553 12/6/2020 5.10.4.0 Allow query with null payload of either command or status topic
PR554 12/6/2020 5.10.4.1 Do not store in HS DeviceValue when WLED devices are created
PR555 12/6/2020 5.10.42 Round UNIX replacement to be an integer
PR556 12/8/2020 5.11.0.0 Added WLED Playlist support
PR557 12/10/2020 5.11.1.0 Added WLED Preset support
PR558 12/10/2020 5.11.2.0 Added ToHex and FromHex expression functions
PR559 12/11/2020 5.11.2.1 Fixed internal broker reset when subscribing to specific topics
PR560 12/13/2020 5.11.3.0 Discard non-hex characters in FromHex function
PR561 12/14/2020 5.11.3.0 Added MQTT Topic filter for Chart selection
PR562 12/14/2020 5.11.3.0 Added Default option for MISC property
PR563 12/15/2020 5.11.4.0 Added VGP Max user selection
PR564 12/15/2020 5.11.5.1 Fixed Shelly Duo On/Off vs. IsOn true/false
PR565 12/15/2020 5.11.5.1 Fixed HS3 VGP Edit submit popup not showing
PR566 12/16/2020 5.11.6.0 Fixed short WLED effects list
PR567 12/16/2020 5.11.6.0 Added HS Device for WLED Palette
PR568 12/16/2020 5.11.6.1 Give feedback on VSP edit for duplicates (and show duplicates)
PR569 12/17/2020 5.11.6.2 LastDate hyperlink does not show chart on HS4
PR570 12/17/2020 5.11.6.2 RegEx parsing on chart return last data rather than first data
PR571 12/17/2020 5.11.6.3 Shelly devices cannot be commanded with HS3 plugin
PR572 12/19/2020 5.11.6.4 Don't update HS device if no change unless MISC flag not set (loop on VDs)
PR573 12/21/2020 5.12.0.0 Added InfluxDB as a recipient of HS Device/Feature values
PR574 12/22/2020 5.12.0.1 Use LastChange MISC flag as criteria for updating HS device
PR575 12/23/2020 5.12.0.2 Devices imported from HS3 sometimes show as unknown name
PR576 12/24/2020 5.12.0.3 HS4 chart on demand fails unless all parameters specified
PR577 12/24/2020 5.12.0.3 Chart failure when only one of YMin and YMax are explicitly specified
PR578 12/24/2020 5.12.0.3 Lock Y right to left axis setting ignored on chart on demand
PR579 12/25/2020 5.12.0.4 Non-plugin device cannot be controlled with VSP status
PR580 12/25/2020 5.12.0.4 Looping on non-plugin device when status is changed
PR581 12/26/2020 5.12.0.5 Debug for aqualinkd added
PR582 12/26/2020 5.12.0.6 VSP charts do not work
PR583 12/29/2020 5.12.0.7 Modify receive queue throttling algorithm
PR584 12/29/2020 5.12.0.8 CAPI control labels get text rather than status
PR585 1/6/2021 5.13.0.9 Added ability to view HS device history in tabular format
PR586 1/6/2021 5.13.0.0 Added Shelly1L
PR587 1/7/2021 5.13.1.0 Added ability to use null payload as status request or store null in DeviceString
PR588 1/7/2021 5.13.1.0 Error trap placed inside receive queue thread so errors will not kill thread
PR589 1/7/2021 5.13.1.1 Replaced spaced in names being written to InfluxDB with underscores
PR590 1/7/2021 5.13.1.2 InfluxDB field name selection not sticking
PR591 1/8/2021 5.13.1.3 InfluxDB names can now have spaces, decimal values always use period
PR592 1/18/2021 5.13.3.0 InfluxDB write without ContentType
PR593 1/18/2021 5.13.3.0 MQTT messages not initialized for selection for InfluxDB
PR594 1/18/2021 5.13.4.0 Chart updated to allow multiple items on same axis, added legend
PR595 1/18/2021 5.13.5.0 Various initialization updates for InfluxDB selected items
PR596 1/18/2021 5.13.5.0 Charting update to allow mixture of Infux and SQLite items on same chart
PR597 1/18/2021 5.13.5.0 Added option for publish encoding to replace special characters with underscore
PR598 1/20/2021 5.14.0.0 Added pool Controller
PR599 1/22/2021 5.14.1.0 Added charting using InfluxDB data
PR600 1/24/2021 5.14.2.0 Fixed grouping with HS4 4.1.11.0 ... in Updater
PR601 1/24/2021 5.14.2.1 Tasmota discovery of energy devices
PR602 1/25/2021 5.14.2.2 Add space before homesasstant discovery suffix to separate from number
PR603 1/30/2021 5.14.2.2 Swap $$VSP: and default substitution variables for publish template commands
PR604 1/30/2021 5.14.2.2 Fix Shelly Uni topic to be shellyuni
PR605 1/31/2021 5.14.2.3 Decimals not showing correctly on Shelly devices ... in Updater
PR606 2/7/2021 5.14.2.5 $$LABEL: no longer works correctly so wrong command sent
PR607 2/9/2021 5.14.2.5 poolController (Pentair) integration with intellicenter equipment
PR608 2/10/2021 5.14.3.0 Added Shelly Motion Sensor
PR609 2/12/2021 5.14.3.1 Suffix missing on devices auto-created with homeassistant discovery for HS3 plugin
PR610 2/13/2021 5.14.3.2 ShellyUni input/0 and input/1 devices not auto-created
PR611 2/15/2021 5.14.3.3 Association Category filter on HS4 duplicate when cateory is changed
PR612 2/15/2021 5.14.3.3 Topic filters do not handle pub topics correctly
PR613 2/16/2021 5.14.3.4 Added poolController logic for -60 model of chlorinator
PR614 2/16/2021 5.14.3.4 Create separate status and control text based upon VSP key vs. status
PR615 2/16/2021 5.14.3.4 Parent ref not deleted from database when parent device deleted from HS
PR616 2/17/2021 5.14.3.5 pool topics remain in database for renamed circuits
PR617 2/17/2021 5.14.3.5 pool heatMode status updated to include Solar Priority and Solar Only
PR618 2/17/2021 5.14.3.5 plugin does not fully shutdown if InfluxDB being used on HS shutdown
PR619 2/17/2021 5.14.3.5 added final abort at shutdown of all threads that may still be active
PR620 2/17/2021 5.14.3.5 unassociated devices get reassociated on restart
PR621 2/17/2021 5.14.3.6 renamed pool topics not fully saved to database, causes vsp issues
PR622 2/23/2021 5.15.0.0 Added direct support of Broadlink IR and IF
PR623 2/23/2021 5.15.0.0 Chart Y axis min/max not honored
PR624 2/26/2021 5.15.0.0 Added Shelly Duo RGB ... in Updater
PR625 3/1/2021 5.15.1.0 Completed RF learning for Broadlink device
PR626 3/4/2021 5.15.1.1 Non-plugin devices not updated when Expressions are used for payload
PR627 3/5/2021 5.15.1.2 Non-plugin sub topic entry does not delete the same topic as a plugin device.
PR628 3/5/2021 5.15.1.2 Remove white space at front and end of user-entered topics
PR629 3/9/2021 5.15.1.3 define pool temperature setpoints to be reasonable range
PR630 3/9/2021 5.15.1.3 Allow existing non-plugin ref to be entered into unassociated ref cell to make association
PR631 3/9/2021 5.15.1.3 Additional fixes to PR627 for proper management of non-plugin command/sub topic
PR632 3/11/2021 5.15.1.4 Creating non-plugin device association from plugin sub topic leaves orphans
PR633 3/15/2021 5.15.2.0 Accepting nonplugin devices no longer sticks with 5.15.1.4
PR634 3/15/2021 5.15.2.0 Added mcsMonitor for independent restart of mcsMQTT
PR635 3/15/2021 5.15.2.0 Expanded debug backup to last 10 restarts
PR636 3/16/2021 5.15.2.1 Allow same pub and sub topics if MISC for Last Change is checked
PR637 3/16/2021 5.15.2.1 Pool controller updates for Next version 6.5.2
PR638 3/17/2021 5.15.2.2 Pool controller chemController pH and lightgroups remove dim level from HS display
PR639 3/19/2021 5.15.3.0 Added option to remove unassociated records on shutdown to improve startup performance
PR640 3/19/2021 5.15.3.0 Optimized handling of HSEvent callback to blacklist unused references
PR641 3/19/2021 5.15.3.0 IP address in payload treated as number
PR642 3/22/2021 5.15.3.1 Chart does not produce device lines for devices with names containing colon
PR643 3/28/2021 5.15.4.0 InfluxDB writes were blacklisted if not also published via MQTT
PR644 3/28/2021 5.15.4.0 Added Appliance to Broadlink IR/RF for better organization
PR645 3/28/2021 5.15.4.0 Implemented import of Pronto Hex IR codes for Broadlink IR
PR646 3/29/2021 5.15.4.1 Provide work-around for virtual device not responding to CAPI control
PR647 4/5/2021 5.15.5.0 Move statistics into Association tab on MQTT/Statistics pseudo-topic
PR648 4/5/2021 5.15.5.0 Normalize SQLite device storages to be same as InfluxDB device storage
Documentation/Manual http://mcsSprinklers.com/mcsMQTT.pdf
How-To Guides from post #250, #259 & #304 by taylormia attached
Change Log
