Version 3.3.x.x
  • Version 3.3.x.x
    Version 3.3.0.0 is available in the Updater. The most significant update is a new tab from which time-based chart for MQTT payload items can be produced.
    There has also been a standardization of approach to selecting labels, status, values and strings. Radio and checkboxes associated with specification of what goes into the payload have been removed. Now all specification of the source of payload content comes from the payload template and use of substitution variables.
    Because of this standardization, those who have selected the non-default settings for payload content will need to make edits when using versions after 3.2.x.x. The most likely case is for the Button control that was selected to publish number rather than label. The edit will be to use $$value: in the Payload template to publish the number rather than the label.
    Charts are made from data that has been retained from the collected History. Charting is available for Topics and JSON items that are numeric or can be represented as Value-Status-Pairs. If VSP's have not been setup, the pairs will be automatically assigned as the chart is being generated.
    Two items can be viewed on the same chart. Each item has its own labeled Y axis and share a common X axis.
    For Windows users the charting infrastructure comes with mcsMQTT. For Linux users the GNUPlot distribution needs to be installed. For Debian-based systems it is
    sudo apt-get install gnuplot5.
    Version 3.3.1.0 added a Edit popup that is displayed when an Association row Ref button or row number hyperlink is clicked. Edits made in the popup are synchronized with the Association tab and Edit/Add tabs of the main page.
    The click of the row number and Ref button produce the same result when a HS device exists, but if a received topic has not yet been Accepted then use of the row number click will generate a new HS device and associated it with the subscription topic.
    This addition reduces keystrokes and can be used in lieu of the Accept checkbox to get immediate feedback of all the properties that have been assigned automatically.
      Awesome work, just awesome!
      RJ_Make On YouTube
        Sounds great. Do you think I will have to reconfigure my devices that were created with ver 3.3.0.3. Everything is working perfectly for me.
        Steve Q
          Thank you Michael...gave the new options a spin with one device.
          [ATTACH]68587[/ATTACH]
          [ATTACH]68588[/ATTACH]
          Started with both humidity and temperature and changed it to temperature. Number of temperature readings is now over 100.
          [ATTACH]68589[/ATTACH]
          Wondering if I have an incorrect setting somewhere as I am not seeing any charting yet.
          [ATTACH]68590[/ATTACH]
          - Pete
          Auto mator
          Homeseer 3 Pro - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.00
          Homeseer Zee2 (Lite) - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.00
            This does not affect existing setups. It is just an variation in the UI for the Edit function.
            You do not see Chart tab, items to select for a chart, or chart once selection made?
              I see the chart tab (picture above) but nothing underneath it.
              I have disabled and enabled the plugin and still do not see the items you mentioned.
              Could it be that I installed gnuplot5 while Homeseer was running, then updated the plugin to version 3.3.1.0.
              Should I maybe shut down HS3 and reboot computer / restart HS3?
              Cleared the Firefox cache.
              No charting stuff yet.
              Shut down HS3 and rebooted to restart HS3.
              Running HS3 Pro on Intel Ubuntu 16.04 64 bit (LAMP server)
              That worked and now see the charting options.
              [ATTACH]68591[/ATTACH]
              - Pete
              Auto mator
                Nothing to do with GNUPlot install. I only see History tab screen shots above. I do not see anything from Chart tab.
                  Thank you Michael.
                  Yup here just add GNUPlot, updated plugin and didn't see anything under the chart tab.
                  Then just shut down Homeseer and did a reboot of the server and all appears well now as pictured in post #7.
                  Can I manually write and event to generate the graph for display on Homeseer Touch?
                  /mcsMQTT/plot1.png
                  Similarly to what I was doing using mcsTemperature in Homeseer 2.
                  Well it was a VB script that run the temperature page graphing then grabbed the jpg image of the graph.
                  - Pete
                  Auto mator
                      Thank you Michael.
                      Yes purchased the charting program (Chartdirector) you utilized in mcsTemperature.
                      Not sure if they have free demo anymore. Works in Linux or Windows. (.NET, C#, VB, ASP, COM, Java, C++, PHP, Perl, Python, Ruby, ColdFusion)
                      Here is the script that I used for the charting and images ...thinking you helped me with it a few years back.
                      Sub Main(byVal Parm As Object)
                      Dim Result As String = hs.GetURL("http://127.0.0.1","/Temperature.asp?Page=trend",TRUE,9999)
                      'Wait 40 seconds for page to load
                      For X As Integer = 1 to 50
                          hs.waitsecs(1)
                      Next
                      Dim sLastName as String = “”
                      Dim dLastDate as Date = #1/1/1900#
                      Dim oFileList As String() = System.IO.Directory.GetFiles(hs.GetAppPath & "\html\mcsTemp”, "*.jpg")
                      For Each sFile As String In oFileList
                         Dim oFile As System.IO.FileInfo = New System.IO.FileInfo(sFile)
                         Dim dDate As Date = oFile.LastWriteTime
                         If dDate > dLastDate then
                            sLastName = oFile.Name
                            dLastDate = dDate
                         End if
                      Next
                      If sLastName <> “” then
                          My.Computer.FileSystem.CopyFile(hs.GetAppPath & "\html\mcsTemp\” & sLastName,hs.GetAppPath & "\HTML\Images\wunderground\mcs.jpg",TRUE)
                      End if
                      ' hs.writeLog("Name", "Source: "&sLastName)
                      ' hs.writeLog ("MCSource", "File is"&FileLen("C:\Program Files\HomeSeer 2\HTML\mcsTemp\"&sLastName)&" Bytes at "&filedatetime("C:\Program Files\HomeSeer 2\HTML\mcstemp\"&sLastName))
                      ' hs.writeLog ("MCSJPG", "is "&FileLen("C:\Program Files\HomeSeer 2\HTML\Images\wunderground\mcs.jpg")&" Bytes at "&filedatetime("C:\Program Files\HomeSeer 2\HTML\Images\wunderground\mcs.jpg"))
                      end sub
                      - Pete
                      Auto mator
                        Version 3.3.2.0...
                        I have added HTTP get request for chart. Couple examples below. Note that the file in the \html\mcsMQTT file is returned. If an error occurs then blank is returned. As an example it will return the filename of the plot such as "plot1.png"
                        http://192.168.0.14/MQTT%20Setup?Chart&Y1=HyderonRain/STATE:Wifi:RSSI&StartDate=1-1-2018&EndDate=5-1-2018&Y1Min=0&Y1Max=100
                        http://192.168.0.14/MQTT%20Setup?Chart&Y1=HyderonRain/STATE:Wifi:RSSI&Y1Min=0&Y1Max=100&Duration= 10 20:30:40
                        QueryString parameters are:
                        Chart - required
                        Y1 - required, topic name on left Y axis
                        Y1Min - optional left Y axis minimum
                        Y1Max - optional left Y axis maximum
                        Y2 - optional, topic name on right Y axis
                        Y2Min - optional right Y axis minimum
                        Y2Max - optional right Y axis maximum
                        StartDate - optional start date
                        EndDate - optional end date
                        Duration - optional in format of dd hh:mm:ss (end date is set at current date/time)
                        Duration has priority over StartDate and EndDate
                        If no date is given then period is current day
                        If no Y min or max is given then autoscaling is done
                          Thank you Michael.
                          Testing...
                          /MQTT Setup?Chart&Y1=/26.5CD3F1000000/temperature&Y1Min=0&Y1Max=100
                          Guessing that:
                          /MQTT Setup?Chart
                          should take me to the chart tab.
                          and do not see it going to the chart page via html or generating a png file.
                          - Pete
                          Auto mator
                            This HTTP get function does not render a page, but only returns the text of the file name that is created. If null is returned then there was some issue with the chart such as less that two data points over the range being requested or some typo in the topic.
                            Assure that the chart can be generated manually from the Chart tab. This will require you to specify an explicit date range that could be replicated on the HTTP request.
                              Works...
                              /MQTT Setup?Chart&Y1=26.5CD3F1000000/temperature
                              [ATTACH]68609[/ATTACH]
                              [ATTACH]68610[/ATTACH]
                              - Pete
                              Auto mator
