SSL Testers
  • SSL Testers
    Need 1-2 more people to finish the testing on SSL for the mcsMQTT plugin. It's been initially tested on a Windows and PI/Mono platform (thanks Jeeves, Pete), but I'd like to test a couple more systems just to be sure there's not some other unique limitations.
    Here's the progress so far:
    -It's been tested with Self-signed certs
    -Supports both IP and FQDN addresses
    -Works on both Windows and PI/Mono platforms
    -Supports Client certs. Not sure how viable an option this is since you'll then be forced to only use devices that support client certificates.
    LMK via PM if you're interested. One Windows tester and one PI/Mono tester would be great.
    If you're not familiar with creating Self-Signed certs, I have a document that will explain how that's done as well.
    Z
    Here using
    1 - 3 Homeseer 3 V.435 boxes all running
    2 - Ubuntu 16.04 / current release of Mono on 64bit OS using an
    3 - ARM CPU (Pine64), AMD CPU (dual core cube PC) and Intel CPU (Haswell iSeries CPU).
    4 - 2 connected to HS3 / mcsMQTT Brokers are RPi2's running Stretch and current version of Node Red.
    5 - New broker to test will be the modded SonOff / Tasmoto firmware device.
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
    Homeseer Zee2 (Lite) - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
