Having an issue here as mentioned above.
1 - upload a basic SonOff ino file via Arduinio IDE configured with my AP. Works fine.
2 - next upload this file:
esptool.py --port /dev/ttyUSB0 write_flash -fs 1MB -fm dout 0x0 Sonoff.ino.generic.bin
3 - works fine and remembers my AP and I can get to the menu fine.
4 - then upload this file:
esptool.py --port /dev/ttyUSB0 write_flash -fs 1MB -fm dout 0x0 mcsTasmota.bin
At this point it seems to forget the AP and login and LED starts flashing.
Went back to using WiFi manager as I was doing before. Note when doing the four quick button presses it takes about a minute to go to WAP mode. Just wait until you see the LED flashing then pair with the sonoff device and go to 192.168.4.1 and reconfigure your AP info.
Button usage
Pressing the button for over forty seconds: Reset settings to defaults as defined in user_config.h and restarts the device
The button is connected to GPIO 0 (NodeMCU pin D3)
Looked good for a while then it went back to flashing mode and lost connectivity to AP.
Wondering if this is just a bad SonOff?
So used the default sonoff all sensors bin version 5.14 and tested the DS18B20 connected to GPIO 14 and tested soldered wire to GPIO4.
esptool.py --port /dev/ttyUSB0 write_flash -fs 1MB -fm dout 0x0 sonoff-allsensors.bin
esptool.py v2.3.1
Connecting....
Detecting chip type... ESP8266
Chip is ESP8266EX
Features: WiFi
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Compressed 564912 bytes to 385051...
Wrote 564912 bytes (385051 compressed) at 0x00000000 in 34.0 seconds (effective 133.0 kbit/s)...
Hash of data verified.
I also used the http command line to change C to F on the sensor.
hxxp://192.168.244.221/cm?cmnd=SetOption8 1
Result: SetOption8 "ON"
Looks to be working fine:
16:50:02 MQT: tele/sonoff/SENSOR = {"Time":"2018-06-25T16:50:02","Switch1":"ON","DS18S20":{"Temperature":70.1}," TempUnit":"F"}
Configured GPIO 4 to switch 1.
Tested it by touching it to ground. LED flashes each time
16:54:13 MQT: stat/sonoff/RESULT = {"POWER1":"ON"}
16:54:13 MQT: stat/sonoff/POWER1 = ON
16:54:15 MQT: stat/sonoff/RESULT = {"POWER1":"OFF"}
16:54:15 MQT: stat/sonoff/POWER1 = OFF
16:54:18 MQT: stat/sonoff/RESULT = {"POWER1":"ON"}
16:54:18 MQT: stat/sonoff/POWER1 = ON
16:54:19 MQT: stat/sonoff/RESULT = {"POWER1":"OFF"}
16:54:19 MQT: stat/sonoff/POWER1 = OFF
Then changed over to newer mcs for sonoff wifi basic bin...
esptool.py --port /dev/ttyUSB0 write_flash -fs 1MB -fm dout 0x0 mcsTasmotaC.bin
esptool.py v2.3.1
Connecting....
Chip is ESP8266EX
Features: WiFi
Uploading stub...
Running stub...
Stub running...
Compressed 511664 bytes to 354064...
Wrote 511664 bytes (354064 compressed) at 0x00000000 in 31.2 seconds (effective 131.1 kbit/s)...
Tested ping.
ping 192.168.244.221
PING 192.168.244.221 (192.168.244.221) 56(84) bytes of data.
64 bytes from 192.168.244.221: icmp_seq=1 ttl=128 time=1352 ms
64 bytes from 192.168.244.221: icmp_seq=2 ttl=128 time=343 ms
64 bytes from 192.168.244.221: icmp_seq=3 ttl=128 time=3.02 ms
64 bytes from 192.168.244.221: icmp_seq=4 ttl=128 time=2.78 ms
64 bytes from 192.168.244.221: icmp_seq=5 ttl=128 time=2.87 ms
and web gui console for temperature sensor and GPIO4 connection.
17:05:19 MQT: tele/sonoff/SENSOR = {"Time":"2018-06-25T17:05:19", "Switch1":"ON", "DS18x20":{"DS1":{"Type":"DS18S20", "Address":"10A04713000800D9", "Temperature":70.0}}, "TempUnit":"F"}
17:06:28 MQT: stat/sonoff/RESULT = {"POWER":"ON"}
17:06:28 MQT: stat/sonoff/POWER = ON
17:06:28 MQT: stat/sonoff/RESULT = {"POWER":"OFF"}
17:06:28 MQT: stat/sonoff/POWER = OFF
17:06:30 MQT: stat/sonoff/RESULT = {"POWER":"OFF"}
17:06:30 MQT: stat/sonoff/POWER = OFF
Keep seeing two DS18B20's showing up with the same MAC address:
17:15:04 MQT: tele/GarageDoor2/SENSOR = {"Time":"2018-06-25T17:15:04", "Switch1":"On", "Switch2":"On", "DS18x20":{"DS1":{"Type":"DS18S20", "Address":"10A04713000800D9", "Temperature":71.7}, "DS2":{"Type":"DS18S20", "Address":"10A04713000800D9", "Temperature":71.7}}, "TempUnit":"F"}
As previously mentioned lost the html command line options with this update.
Now see this and it is not working:
RESULT = {"POWER":"Off"}
POWER = Off
Door2 = INDETERMINATE
It was working with the earlier version of mcsTasmota bin and works fine with the tasmota basic sonoff bin version 5.14.
Currently using:
Program Version 5.9.13c
Build Date & Time 2018-06-22T22:27:54
Core/SDK Version 2_4_1/2.2.1(cfd48f3)
On the two Sonoff basic wifi devices with DS18B20's.
I do not want to yet install them for use until I get the PIR running.
Updated mcsMQTT to version 3.4.4.0 this morning.
Button usage
- 1 short press: Toggles the relay either directly or by sending a MQTT message like cmnd/sonoff/POWER1 ON. This will blink the LED twice and sends a MQTT status message like stat/sonoff/POWER1 ON. If cmnd/sonoff/ButtonRetain on has been used the MQTT message will also contain the MQTT retain flag.
- 2 short presses: Toggles the relay 2 if available on the device like Sonoff Dual. This will blink the LED twice and sends a MQTT status message like stat/sonoff/POWER2 on.
- 3 short presses: Start Wifi smartconfig allowing for SSID and Password configuration using an Android mobile phone with the ESP8266 SmartConfig app. The LED will blink during the config period. A single button press during this period will abort and restart sonoff.
- 4 short presses: Start Wifi manager providing an Access Point with IP address 192.168.4.1 and a web server allowing the configuration of Wifi. The LED will blink during the config period. A single button press during this period will abort and restart sonoff.
- 5 short presses: Start Wifi Protected Setup (WPS) allowing for SSID and Password configuration using the router's WPS button or webpage. The LED will blink during the config period. A single button press during this period will abort and restart sonoff.
- 6 short presses: Will restart the module
- 7 short presses: Start OTA download of firmware. The green LED is lit during the update
esptool.py v2.3.1
Connecting....
Chip is ESP8266EX
Features: WiFi
Uploading stub...
Running stub...
Stub running...
esptool.py v2.3.1
Connecting....
Chip is ESP8266EX
Features: WiFi
Uploading stub...
Running stub...
Stub running...
Tested ping.
POWER = Off
Currently using:
