Hardware mods to Sonoff Wifi Basic
    #16
    Thank you Michael.
    So what I noticed here is using first 5 pins:
    1 - VCC 3.3VDC
    2 - RX Pin - serial IN - GPIO 3
    3 - TX Pin - serial OUT - GPIO 1
    4 - Ground Pin
    5 - GPIO 14
    6 - GPIO 4 - soldered wire.
    2nd 3.3 VDC post, one 5.0 VDC and one spare ground pin wired.
    Temperature sensor wired to GPIO 14, ground and 3.3 VCC.
    Garage open and close sensors wired to GPIO4, GPIO3 and Ground pin.
    Initially testing with GPIO 1 (TX Pin) to ground for one door switch. Sonoff did not boot or it went to JTAG mode?
    Configured basic Sonoff WiFi module as follows.
    Click image for larger version  Name:	config2.jpg Views:	1 Size:	37.9 KB ID:	1237058
    Console shows correct stuff when shorting GPIO3 and GPIO4 to ground:
    17:56:41 MQT: /GarageDoor2/POWER = Off
    17:56:48 MQT: /GarageDoor2/STATE = {"Time":"2018-07-29T17:56:48", "Uptime":0 0, "Vcc":3.521, "Wifi"
    17:56:48 MQT: /GarageDoor2/Door2 = CLOSED
    17:56:48 MQT: /GarageDoor2/SENSOR = {"Time":"2018-07-29T17:56:48", "Switch1":"Off", "Switch2":"On"}
    In March of 2017 Theo Arends wrote:
    I do not support GPIO01 as user GPIO as there would be a lot of questions as why it doesn't perform as the user expected as serial input may come along.
    Then later wrote that he did support using GPIO 01 (TX - Serial out) as a user GPIO. This is where I am confused a bit.
    Retested using GPIO3 and GPIO4 as configured above. Reconnected temperature sensor and test remounted it over the GDO. All looks fine now.
    11:35:03 MQT: /GarageDoor1/INFO3 = {"RestartReason":"Software/System restart"}
    11:35:04 UPP: Multicast (re)joined
    11:35:04 MQT: /GarageDoor1/POWER = Off
    11:35:04 HTP: Console
    11:35:11 MQT: /GarageDoor1/STATE = {"Time":"2018-07-29T11:35:11", "Uptime":0 0, "Vcc":3.496, "Wifi"
    OPENED Garage Door.
    11:35:11 MQT: /GarageDoor1/Door1 = OPEN
    11:35:11 MQT: /GarageDoor1/SENSOR = {"Time":"2018-07-29T11:35:11", "Switch1":"On", "Switch2":"Off", "DS18x20":{"DS1":{"Type":"DS18B20", "Address":"282F515C04000080", "Temperature":99.3}}, "TempUnit":"F"}
    Closed Garage Door
    11:35:33 MQT: /GarageDoor1/Door1 = INDETERMINATE
    11:35:44 MQT: /GarageDoor1/Door1 = CLOSED
    11:35:45 MQT: /GarageDoor1/Door1 = INDETERMINATE
    11:35:45 MQT: /GarageDoor1/Door1 = CLOSED
    Installing little terminals to the Sonoff case this
    Can't you swap the temperature sensor and door sensor pins being used in you wiring?
    Trying a change with SonOff #2 device to see if it works.
    Gonna try that next on second SonOff except connect the temperature sensor to GPIO1 instead of GPIO14.week.
    Changing DS18B20 GPIO connection from GPIO 14 to GPIO 1 to see what happens on cold boot and if I can see the temperature sensor connected to GPIO 1
    - Pete
    Auto mator
      #17
      Testing:
      1 - VCC 3.3VDC
      2 - RX Pin - serial IN - GPIO 3 ==> DQ pin on DS18B20
      3 - TX Pin - serial OUT - GPIO 1 ==> DQ pin on DS18B20
      4 - Ground Pin
      5 - GPIO 14 ==> DQ pin on DS18B20
      6 - GPIO 4 - soldered wire - DQ pin on DS18B20
      Click image for larger version  Name:	Test2.jpg Views:	1 Size:	43.1 KB ID:	1237090
      Tested GPIO1, GPIO3, GPIO4 and GPIO14 to DQ of DS18B20
      GPIO1 ==> DQ - does not work with DS18B20
      GPIO3 ==> DQ - does not work with DS18B20
      GPIO4 ==> DQ works ==> "DS18x20":{"DS1":{"Type":"DS18B20", "Address":"280D7E5B04000049", "Temperature":69.5}}
      GPIO14 ==> DQ - does not work with DS18B20
      - Pete
      Auto mator
        #18
        Found a drawing that uses a pull up resistor for GPIO 1. The original drawing was incorrect but the subject was using GPIO 1 for a switch.
        Might give this a try. This way I can use GPIO 4 for PIR or Microwave.
        - Pete
        Auto mator
          #19
          [quote]Is there a way to adjust the mcsTasmota firmware to show local time and date once it starts to chat?[/quote[]
          if is not an areas I explored. I notice that it starts then eventually does NTP to update the time. If you have specific suggestion then I can see if it can be implemented.
            #20
            Thank you Michael.
            Tested the quote function. It is on the top of the first advanced bar. I see this above: []QUOTE]
            Console commands are sticky.
            Commands in mcsMQTT would be propietary to the (mcs)Tasmota firmware.
            Originally used the console commands to change Centigrade to Fahrenheit. Easy peasy stuff.
            Console commands did work a few versions back.
            Click image for larger version  Name:	time.jpg Views:	1 Size:	54.4 KB ID:	1237139
            Commands -
            - Pete
            Auto mator
              #21
              Pete, are you just documenting the reference to console commands? Are you indicating that they stopped working with mcsTasmota a few versions back? Have you tried to access some of the added features, such as irrigation schedules, via the console?
                #22
                Yes console, http and Mosquitto in the command reference wiki. I used the http commands a while back. I dunno why they quit working as the commands are part of the Tasmota core.
                No.
                I am only testing stuff right now with the Sonoff basic Wifi Module.
                Most of the time it's been adding hardware mods - soldering wires / posts.
                It's been a couple of months ago that I changed the default temperature setting from C to F.
                The temperature change thing was all I ever did with the command line interface. I did test status and stuff and all of that worked fine a few mcsT
                asmota versions back.
                - Pete
                Auto mator
                  #23
                  Waiting now to solder posts to Sonoff Wifi module as the wires I am using are 26 guage and difficult to deal with outside of the box.
                  I was using alligator clips for my testing and working on a ladder over the GDO which is a PITA.
                  Relating to the command stuff it is easiest for you to see for yourself uploading current Tasmota basic firmware to the SonOff device and try the commands using http and then watching the console responses to what you type.
                  I have read how easy it is to expand the flash from 1 Mb to 2 Mb. Wondering if I should do this with next purchase more Sonoff modules?
                  - Pete
                  Auto mator
                    #24
                    BTW looks like HST is restructuring the forum and I couldn't find my posts from yesterday here....did find them eventually...
                    - Pete
                    Auto mator
                      #25
                      Drilled 3 small holes, glued and soldered 3 terminal post to top of case today on the the Sonoff Basic WiFi modules.
                      Used a bit of liquid nail and a toothpick to glue the terminal to the case. Soldered 3 wires and used hot glue on the underside of the case to keep the wires in place.
                      GPIO 4 - Ground - GPIO 3
                      Found today that the temperature sensor mounted on the case of the Sonoff reads about 10 degrees higher than the ambient temperature tested by opening the case and checking temperature of the DS18B20 sensor.
                      Click image for larger version  Name:	mods2.jpg Views:	1 Size:	65.8 KB ID:	1237869
                      - Pete
                      Auto mator
                        #26
                        I ended up using the AM2301 devices glued to the case of the weatherproof sonoff basic box for temp and humidity sensing, the thermals from the sonoff basic impacted less. Also I had a play running the tasmota code on a wemos and made my own DS18b20 hat, again to get away from thermal impact from the electronics, that worked well however it does get away from the "all in one" sollution....
                        HS 2.2.0.11
                          #27
                          Thank you Pete.
                          Yeah will be upgrading the one I installed to an AM2301. The Sonoff is mounted right now over the garage door opener near the ceiling of the garage.
                          Type":"DS18B20", "Address":"282F515C04000080", "Temperature":102.0
                          Not sure how accurate I am making it subtracting numbers with it. (93.8).
                          Are you utilizing the Sonoff DIN case for mounting on a DIN rail?
                          - Pete
                          Auto mator
                            #28
                            Hi Pete
                            Here are a few piccies, stuff I'm playing with. The one in the case is out on my balcony that drives a light, has the local switch and the AM2301. The garage one hanging from the roof is the quick one I put together when I first started. The final one mimics the lighting controller in tasmota, it drives the RGB strip behind a wall feature, I've got a new one coming in a slim case that will fit behind the screen :-)
ID:	1238048Click image for larger version
ID:	1238050Click image for larger version
                            HS 2.2.0.11
                              #29
                              Thank you for the pictures Pete.
                              I was curious about the outdoor boxes.
                              Been a bit paranoid about garage door automation from the 1990's where I had automated the garage door which was separate from the house automation and wife pulled in garage, didn't shut off car or alarm in garage while on a conference call kept talking while the garage door shut. I am still today reminded of that automation.
                              - Pete
                              Auto mator
                                #30
                                Pete, my garage door doesnt shut automatically however I've set it that if its open for more than 30 mins it sends me an SMS.....just to make sure I dont go to bed without shutting the door.....
                                HS 2.2.0.11
