Thank you Pete.
Using text to speech reoccurring event when garage door is open (via OmniPro 2 and Homeseer) with a flag to shut it off if I am in the garage. Using two voices today comparing speed of Omnipro 2 garage door switches and using the Sonoff. First speech to trigger is the alarm wired sensors with the Omni panel plugin.
Today no automation is used to shut the garage door automagically.
Have an outdoor style PIR in the garage which I do not utilize for anything these days.
Way back tested RFID tags to work with the automobiles which would identify which car was present and what functions would happen when the car was present. Tags using 12VDC automobile power with little draw on car battery. (originally configured automobiles with supplimental tank battery and charging circuits). Got it to about 100% but still hesitate on using it. Mixed it too here with the under the driveway sensors wired to the panel CarTel system.
Ideally the car has an unique identity with the RF ID and the automation would acknowledge the automobile then open the door sans the use of a mobile phone.
These are pictures of SonOff add. It is separate from what is there (spaghetti). Using a small PVC junction box adjacent to the garage door for the NC/NO switches using 22/2 and 22/4 cables. The Sentrol sensors have 3 wires (NC, NO). Wanting to keep this stuff / wires separate from the Sonoff stuff. Note that the Sentrol sensors are way overkill for a home garage. (used these in logistics warehouse doors).
If I could utilize 3-4 more GPIO ports then these could be connected to relays connected to a 4 channel RFID reciever for a self contained multiple function Sonoff box. (door sensors, door button, temperature sensor and 4 channel RFID box).
Concurrently redoing lighting in garage to pure LED.
Thinking of using a small DIN rail mounted on the support structure of the GDO.
Dedicated to Sonoff WiFi testing using a custom POE OpenWRT small footprint hardware modded micro router (hardware modifications are just RTC, using test GPIO pins and Mosquitto (not node red though). OS is small and very tight. Bit of a tangent here.
OpenWRT OS
Firmware Version: LEDE Reboot 17.01.4 r3560-79f57e422d / LuCI lede-17.01 branch (git-17.290.79498-d3f0685)
Mosquitto stuff:
mosquitto version 1.4.14 (build date 2018-01-17 16:26:59+0000)
mosquitto is an MQTT v3.1.1/v3.1 broker.
You can utilize Python or LUA to tap in to the GPIO ports / Mosquitto stuff.
Made a little heatsink for the DS18B20 chip and bent it a bit away from the board where as none of the bottom of the chip is touching the board using the idea in this picture. I like the little Arduinio DS 18B20 board Led lamp which lets me know that the Sonoff is on.
Testing it next to a thermostat.
Sonoff #1 with no heatsink
Temperature: 104.4 F
Sonoff #2 with heatsink pictured above.
Temperature: 99.4 F
Thermostat: 92 F
Got it to about 4 degrees F difference using a large ring terminal and gluing it to the DS18B20 chip.
OpenWRT OS
Mosquitto stuff:
Temperature: 99.4 F
Thermostat: 92 F
