Hello
I want to control my projector with HS3.
DrhsIpPlugin don't work.
I found a node-red flow with PjLink protocol to control my Epson TW7300 (or 5040UB in US)
I have installed plugin McsMqtt on HS3, Mosquitto docker on my NAS qnap TS-451, and Qnap QIOT lite (Node-red by Qnap).
I added module pjlink in Qiot, and loaded flow from https://flows.nodered.org/node/node-red-contrib-pjlink
Now, i receive statut from my projector(On = 1, Off = 0, Lamp Status , Name, and Inputs),
and in can power on or Off from HS3
Several problems:
The Status lamp is not good, i want only 375H in device Lamp
The status Input is not good , I want each input in several devices HDMI1, HDMI2, RGB, Network
Can help me, please
For Power On, Off, HS3 send 1 or 0, in node-red i use a node "CHANGE" to change 1 = on, and 0 = off and inject it in node PjLink
That is ok and i can power ON or OFF by Google Home
How can i improve my flow between HS3 and My projector?
I want to select inputs by an event called "Cinema ON" or "Cimena OFF" to start my projector, select input HDMI1 or HDMI2 on projector, close the blind, start my home cinema ,Chose correct input on Home cinema, put Yeelight in mode Cinema, etc...
Can you help me,
My flow in Node-red:
Jean francois.
Several problems:
Can help me, please
Can you help me,
PHP Code:
[{"id":"b51823a5.1b8bb","type":"tab","label":"Flow 2"},{"id":"716eee9.a31361","type":"inject","z":"b51823a5.1b8 bb","name":"","topic":"POWER","payload":"on","payloadType":" str","repeat":"","crontab":"","once":false,"x":118,"y":120," wires":[["b37d889.6eb2978"]]},{"id":"a4df02e2.bd90d","type":"debug","z":"b51823a5.1b8bb" ,"name":"Error","active":false,"console":"false","complete": "payload","x":784,"y":434,"wires":[]},{"id":"6266a80c.0db038","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"POWER","payload":"off","payloadType":" str","repeat":"","crontab":"","once":false,"x":118,"y":160," wires":[["b37d889.6eb2978"]]},{"id":"b37d889.6eb2978","type":"pjlink","z":"b51823a5.1b8b b","ip":"192.168.50.65","port":4352,"name":"TW7300","x":550, "y":379,"wires":[["e121ead8.b98668","fdafcd17.12b1f8","8f3c166c.9a6cf8"],["a4df02e2.bd90d"]]},{"id":"af1f53d7.4bf438","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"TW7300/Name","payload":"getname","payloadType":"str","repeat":"","c rontab":"","once":false,"x":150,"y":440,"wires":[["b37d889.6eb2978"]]},{"id":"e121ead8.b98668","type":"debug","z":"b51823a5.1b8bb ","name":"Out","active":false,"console":"false","complete":" payload","x":782,"y":375,"wires":[]},{"id":"83f46eec.4fee9","type":"inject","z":"b51823a5.1b8bb ","name":"","topic":"","payload":"getmanufacturer","payloadT ype":"str","repeat":"","crontab":"","once":false,"x":124,"y" :320,"wires":[["b37d889.6eb2978"]]},{"id":"2ebcb973.223cde","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"TW7300/Lampe","payload":"getlamps","payloadType":"str","repeat":"36 00","crontab":"","once":false,"x":161.5,"y":360,"wires":[["b37d889.6eb2978"]]},{"id":"d92ea5ab.f9737","type":"inject","z":"b51823a5.1b8bb ","name":"","topic":"TW7300/Sources","payload":"getinputs","payloadType":"str","repeat": "","crontab":"","once":false,"x":161.5,"y":400,"wires":[["b37d889.6eb2978"]]},{"id":"427ee6e2.cc9508","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"","payload":"getinfo","payloadType":"s tr","repeat":"","crontab":"","once":false,"x":98,"y":520,"wi res":[["b37d889.6eb2978"]]},{"id":"16136b7c.9a551d","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"TW7300/Power","payload":"getpowerstate","payloadType":"str","repeat ":"","crontab":"","once":false,"x":167,"y":560,"wires":[["b37d889.6eb2978"]]},{"id":"4534b074.9daf8","type":"inject","z":"b51823a5.1b8bb ","name":"","topic":"","payload":"getinput","payloadType":"s tr","repeat":"","crontab":"","once":false,"x":98,"y":480,"wi res":[["b37d889.6eb2978"]]},{"id":"f00e62f7.1ba1b","type":"inject","z":"b51823a5.1b8bb ","name":"","topic":"","payload":"getmodel","payloadType":"s tring","repeat":"","crontab":"","once":false,"x":102,"y":600 ,"wires":[["b37d889.6eb2978"]]},{"id":"7074a4f2.ae25fc","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"","payload":"getmute","payloadType":"s tring","repeat":"","crontab":"","once":false,"x":98.5,"y":28 0,"wires":[["b37d889.6eb2978"]]},{"id":"517162b.c73ea9c","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"","payload":"getclass","payloadType":" string","repeat":"","crontab":"","once":false,"x":98.5,"y":6 40,"wires":[["b37d889.6eb2978"]]},{"id":"1b48c710.89ee41","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"","payload":"geterrors","payloadType": "string","repeat":"","crontab":"","once":false,"x":101,"y":6 80,"wires":[["b37d889.6eb2978"]]},{"id":"c9fc8fb5.47f1a8","type":"template","z":"b51823a5.1b 8bb","name":"Set input","field":"payload","fieldType":"msg","syntax":"mustach e","template":"{"setinput": {"source": 3, "channel": 3}}","x":224,"y":720,"wires":[["d1a03915.f35128"]]},{"id":"78448cc0.3d4334","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"","payload":"","payloadType":"str","re peat":"","crontab":"","once":false,"x":98,"y":720,"wires":[["c9fc8fb5.47f1a8"]]},{"id":"d1a03915.f35128","type":"json","z":"b51823a5.1b8bb" ,"name":"","x":358,"y":720,"wires":[["b37d889.6eb2978","b8f0162b.58e478"]]},{"id":"b8cb4adc.b61cf","type":"inject","z":"b51823a5.1b8bb ","name":"","topic":"","payload":"muteon","payloadType":"str ing","repeat":"","crontab":"","once":false,"x":98,"y":200,"w ires":[["b37d889.6eb2978"]]},{"id":"af2ef125.734cc8","type":"inject","z":"b51823a5.1b8b b","name":"","topic":"","payload":"muteoff","payloadType":"s tring","repeat":"","crontab":"","once":false,"x":98,"y":240, "wires":[["b37d889.6eb2978"]]},{"id":"8f3c166c.9a6cf8","type":"mqtt out","z":"b51823a5.1b8bb","name":"TW7300","topic":"","qos":" ","retain":"false","broker":"bad7c286.5f0da","x":783.6785888 671875,"y":143.82142639160156,"wires":[]},{"id":"fdafcd17.12b1f8","type":"debug","z":"b51823a5.1b8bb ","name":"","active":true,"console":"false","complete":"true ","x":781.8571166992188,"y":306.1428527832031,"wires":[]},{"id":"3a44968a.dba7da","type":"mqtt in","z":"b51823a5.1b8bb","name":"TW7300 IN","topic":"TW7300/#","qos":"0","broker":"bad7c286.5f0da","x":78,"y":823,"wires ":[["4d81297a.78b4"]]},{"id":"b8f0162b.58e478","type":"debug","z":"b51823a5.1b8bb ","name":"","active":true,"console":"false","complete":"true ","x":791,"y":705,"wires":[]},{"id":"4d81297a.78b4","type":"change","z":"b51823a5.1b8bb" ,"name":"","rules":[{"t":"change","p":"payload","pt":"msg","from":"0","fromt":"n um","to":"off","tot":"str"},{"t":"change","p":"payload","pt" :"msg","from":"1","fromt":"num","to":"on","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x" :310,"y":822,"wires":[["b37d889.6eb2978"]]},{"id":"bad7c286.5f0da","type":"mqtt-broker","z":"","broker":"192.168.50.220","port":"1883","clie ntid":"Qnap-Qiot","usetls":false,"compatmode":true,"keepalive":"60","cle ansession":true,"willTopic":"","willQos":"0","willPayload":" ","birthTopic":"","birthQos":"2","birthPayload":""}]
