I'm playing with mqtt on my hs3 project.
Sonoff (tasmota) and mqtt is a great solution.
Now I'm testing a NODEMCU with tasmota firmware with connected 2 1-wire sensor.
I don't know if i related to decimal separation, i Italy I use "," not the dot. The payload on mqtt plugin is for example "22.8", but on hs3 devices list show up "228".
I added "$$PAYLOAD:/1" in the Expression tab and now in the HS3 devices list I can see "22,8" (with comma); but if I want to graph the value I see 228-229-232-229. I can see only integer.
Are there any other setting in the mqtt plugin?
I'm checking also on tasmota firmware if are there some local setting (comma instead of dot).
Cris
Cris
