JSON Payload not populating new devices? For sure im doing something wrong.
  • JSON Payload not populating new devices? For sure im doing something wrong.
    I have a JSON payload in a topic, however it doesnt seem to create new devices. What could I be doing wrong?
    the payload looks like this:
    qos : 0, retain : false, cmd : publish, dup : false, topic : 124T11/sensornode1, messageId : , length : 123
    {"state":"OFF","brightness":255,"humidity":"74.50","motio n": "standby","ldr":"82","temperature":"28.00"}
    Current mcsMQTT setup
    1: The payload appears in the statistics page as a recieved payload
    2: The subscribed topic has a dev no
    3: General Tab: JSON Decoding: Decode payload JSON into individual HS Devices
    What I need is individual devices for each of the JSON keys
    Im sure its possible. I just dont know how to do it and what I see in the manual, mcsMQTT should have created the appropriate devices.
    Thanks guys
    Answered my own question and dont know how to delete the post.
    The MQTT Subscribe Topic should be 124T11/sensornode1:motion
      Testing Removal
      You can edit your post above and then while editing hit the delete button.
      Click image for larger version  Name:	removal.jpg Views:	1 Size:	27.8 KB ID:	1245806
      In the start of a post if you are the first poster you can delete the entire thread of posts.
      Click image for larger version  Name:	deletetopic.jpg Views:	1 Size:	22.1 KB ID:	1245807
      Give it a try.
      - Pete
      Auto mator
      HS4 Pro - V4.0.9.0 - Ubuntu 18.04/W7e 64 bit Intel Kaby Lake CPU - 32Gb - Mono 6.8X
      HS4 Lite -
