H801 WiFi LED RGB 5 channel upgrade for use with mcsMQTT
  • H801 WiFi LED RGB 5 channel upgrade for use with mcsMQTT
    Just a quickie DIY on upgrading the H801 LED RGB 5 channel WiFi for use with Mosquitto and mcsMQTT
    Click image for larger version  Name:	H801WiFi.jpg Views:	1 Size:	102.0 KB ID:	1248931
    Hardware:
    - H801 LED RGB WiFi device (< $10 USD)
    - Pins for connectivity for JTAG and Jumper for firmware upgrading
    - USB JTAG programmer - USE 3.3VDC pins
    Click image for larger version  Name:	USBProgrammer.jpg Views:	1 Size:	58.2 KB ID:	1248955
    Step by step
    1 - solder on 6 pins
    Click image for larger version  Name:	solderpins2.jpg Views:	1 Size:	183.4 KB ID:	1248949
    2 - software utilized for Windows 7/10 or Ubuntu 18.04 ==> Visual Studio Code / PlatformIO
    Installed it here on Windows 7 Pro 64 bit, Windows 10 Pro 64 bit and Ubuntu 18.04 LTS 64 bit with no issues.
    Click image for larger version  Name:	PlatformIO-VisualStudioCode.jpg Views:	1 Size:	33.5 KB ID:	1248960
    3 - Updating firmware
    A - put a jumper on J3
    B - connect RX, TX, GND and 3.3 pins from controller to USB programmer. Make sure you utilize 3.3VDC pins.
    C - plug in your USB programmer. The device will boot in in flash mode.
    D - Per Tinkerman's review here ==> A closer look at the H801 LED WiFi Controller
    git clone hxxps://github.com/xoseperez/espurna
    cd espurna/code
    pio run -e h801-debug -t upload
    E - another easy and fast way to do this in Ubuntu Linux is to download the bin file here ===> espurna-1.13.1-huacanxing-h801.bin
    F - install esptool ==>
    pip install esptool
    G - type (note make check to make sure your USB programmer is at ttyUSB0)
    esptool.py --port /dev/ttyUSB0 write_flash -fs 1MB -fm dout 0x0 espurna-1.13.2-huacanxing-h801.bin
    Wait until it is finished flashing. The is fastest and easiest way if you do not want to modify the code.
    H - unplug USB programmer and move jumper off the two pins.
    I - plug in USB programmer
    J - The device will be in AP mode. Connect to the AP. SSID password is fibonacci
    K - go to web page 192.168.4.1 . login with admin and password fibonacci.
    L - configure you WAP stuff and here I used a static IP and configured NTP.
    Click image for larger version  Name:	RGB.jpg Views:	1 Size:	41.4 KB ID:	1248968
    M - configured device for one channel - warm white.
    Click image for larger version  Name:	WW.jpg Views:	1 Size:	26.5 KB ID:	1248969
    N - configure MQTT in mcsMQTT
    Click image for larger version  Name:	mqtt.jpg Views:	1 Size:	26.6 KB ID:	1248992
    xxxxxxxxxxxxxxxxxxx
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e 64 bit Intel CPU - Mono 6.00
    Homeseer Zee2 (Lite) - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e BeeLink 4Gb BT3 Pro - Mono 6.00
    Testing today connected a test strip to channel (01234) 4. Works fine.
    Note: that the + (positive) LED connection goes to VCC and the - (negative) connection goes to WW.
    Channels available are:
    R - channel 0
    G - channel 1
    B - channel 2
    C - channel 4 white
    D - channel 5 warm white
    and up to 4 AMPs per channel.
    In this picture have it dimmed to around 3 (0-255) and its glowing but you cannot tell from the picture.
    Click image for larger version  Name:	RGB3.jpg Views:	1 Size:	98.9 KB ID:	1249167
    If I power off and on the RGB device it remembers last dim value. Same if I use the relay button.
    Michael McSharry
    I want to change the slider value from 0 to 255 to 1 to 100. How would I do that?
    When tweaking the variables I cannot put in graphics for status as it shows that it is not allowed.
    How can I change this?
    Click image for larger version  Name:	RGB2.jpg Views:	1 Size:	38.4 KB ID:	1249165
    Found a small RGB test strip to test with. Might as well test RGB even though I probably will never install RGB lamps here.
    Putting a diffuser on the little RGB test strip and making up a tiny warm and white white with diffuser test strip. It is too bright to play with and bugs me now.
    - Pete
    Auto mator
      Connected little mini bottom WW (white white) and top W (warm) strips and two mini RGB strips to the $8.00 USD RGB controller to test all 5 channels. Works great.
      Not sure though here if I will be using RGB.
      Might utilize the controller for 5 channels (48 watts each) of outdoor LED lamps. Configuration was left at using 12VDC LED lamps outside in to zones and each zone (pair) of zones was connected to a DIN mounted MeanWell 12VDC transformer and controlled by one UPB relay.
      Click image for larger version  Name:	RGB2.jpg Views:	1 Size:	49.6 KB ID:	1250194
      xxxxxx
      - Pete
      Auto mator
        Michael McSharry
        Pete,
        If you click the button under the "ref" column with the device number it opens a page of settings. Uncheck NO_GRAPHICS_DISPLAY to allow setting graphics (I believe it's checked by default) and make sure SHOW_VALUES is checked to allow editing values in the Device settings.
        Great project, I plan to purchase one or two of these myself. Testing with a SONOFF Basic currently, have VSC and PlatformIO installed and working.
          Thank you Martin. Testing this afternoon configured a variable per channels 0,1,2,3,4 and goofing around with color values now even though I will probably not use them.
          xxxxx
          - Pete
          Auto mator
            Posting more pictures here for a new add to the H801 RGB controller which was done by John modifying a MagicHome controller with an on/off and pot connecting to GPIO 0, 2 and 4.
            Click image for larger version  Name:	H801GPIO.jpg Views:	1 Size:	73.0 KB ID:	1251002Click image for larger version  Name:	exp8266.jpg Views:	1 Size:	59.2 KB ID:	1251003
            John's add of an on/off and dimmer pot using GPIO 0, 2 and 4 video.
            xxxxxxx
            - Pete
            Auto mator
