Looking for a MQTT thermostat
  • Looking for a MQTT thermostat
    Looking to purchased a new WiFi thermostat that I can update using ESP or Tasmota and control it via Mosquitto.
    I want it to have a hard switch to turn on an off wireless and manually manage it.
    Does one exist?
    - Pete
    Auto mator
    Homeseer 3 Pro - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e 64 bit Intel Haswell CPU - Mono 6.4X
    Homeseer Zee2 (Lite) - 3.0.0.534 (Linux) - Ubuntu 18.04/W7e - CherryTrail x5-Z8350 BeeLink 4Gb BT3 Pro - Mono 6.4X
    https://youtu.be/beSIUfOL7io
    HS 2.2.0.11
      Thank you Pete.
      Yeah looking for a WiFi thermostat that I can modify to utilizing Mosquitto.
      I do now have my connected OmniStat (serial) to OmniPro 2 panel talking Mosquitto right now and it works nicely with Home Assistant and Homeseer.
      The picture below related to devices connected to my OmniPro 2 panel.
      Click image for larger version  Name:	OmniPanel.jpg Views:	1 Size:	36.6 KB ID:	1254649
      Adding Tasmota based Sonoff temperature / humidity sensors here to the mix and try to add a Mosquitto based Thermostat.
      Went to building a new Home Assistant server running Node Red and maybe Broker next. I could also run this stuff on the HS3 server with no issues. Goal here though is to run it all on a Rock64 server inside of the Alarm / Security panel. It will also be a firewall and out of band management device.
      - Pete
      Auto mator
