ws2812 control via mqtt
  • ws2812 control via mqtt
    Ok so ive been pulling whats left of my hair out on this one.
    im trying to control ws2812 leds using a nodemcu (esp8266) and fastled. im currently trying to use this firmware:
    https://github.com/bruhautomation/ES...N-Digital-LEDs
    it apparently needs the following syntax:
    mosquitto_pub -t 'SmartHome/Office/LED/set' -m '{"effect":"sine hue","state":"ON"}'
    i have managed to get it to work by sending topic:SmartHome/Office/LED/set payload: {state:ON}
    what i am trying to work out is how to make mcsMQTT match this payload from a homeseer button.
    does anyone have any ideas, including a new firmware!
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
    I was looks for firmware’s to integrate and landed on this one: https://github.com/Aircoookie/WLED
      It looks like it is expecting a JSON formatted payload from HS/mcsMQTT. I have not tried this, but should be able to set payload template on Edit tab to {state:$$STATUS::}
      $$STATUS: during transmit will pick up the label of ON or OFF assuming the VSP's have this text.
        {state:$$STATUS:} worked! thanks so much!
