Convert payload from Celsius to Fahrenheit
  • Convert payload from Celsius to Fahrenheit
    I have a sensor sending a payload in celsius. I put in the expression field:
    "$$PAYLOAD * 1.8 + 32"
    In the device list the value returns 0
Name:	Screen Shot 2018-12-03 at 6.19.15 PM.png
    Substitution parameter ends in colon. $$PAYLOAD:
    See if that makes a difference.
    Also make certain that the payload is a number. If it has something like "C" suffix then use the regular expression fields to remove the suffix.
      Thanks. I knew it was something like that. It's working.
      Last time i had empty space in the MQTT Publish Payload Template. Why does "ON " not work? !!@##. Many hours later . . . . "ON" works much better!
