Zigbee2MQTT on Windows
  • #31
    Originally posted by ServiceXp View Post
    Some days I tell ya, some days...
    Hi ServiceXp
    Can you tell me which Zigbee dongle you ended up with that works?
    BTW
    The only ones I can see on UK Amazon are ones that look like a PCB with a USB connector.
    Is there anything with a more "professional" finish available (i.e. one without the PCB visible)
    Thanks /Marcus
    • #32
      I flashed a Zigbee USB dongle for XP. As part of this I did a 3D print of a case. There is a picture at https://forums.homeseer.com/forum/li...ailable-for-10
      I have also used the unit with an external antenna and RF frontend and came with a case. https://www.aliexpress.com/item/RF-T...27424c4dKshRko
      Figure 49 of http://mcsSprinklers.com/mcsMQTT.pdf shows how it is wired to enable flashing and use.
      • #33
        Originally posted by metkhoo View Post
        Hi ServiceXp
        BTW
        Thanks /Marcus
        I'm using the Dongle that Michael is sending out. If you are referring to the temp/humidity/ect senors then this is the one that worked for me.
        RJ_Make On YouTube
