Smartthings MQTT bridge
This project was spawned by the desire to control SmartThings from within Home Assistant. Since Home Assistant already supports MQTT, we chose to go and build a bridge between SmartThings and MQTT.
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
